Old 03-29-2013, 07:47 PM   #1
rainmonkey
Drives: BRZ - Dark Grey
Stock wheels?
Hi,
Curious, but is there any disadvantage to just using the stock wheels but switching out the tires?
Is there anything particularly 'bad' or 'lacking' with the stock wheels? I know some people switch em for larger ones or because they don't like the look, but aside from that...?
You can still lower the car on stock wheels right?
rainmonkey is offline   Reply With Quote
Old 03-29-2013, 08:14 PM   #2
BigJyoungblood
Enthusiast
BigJyoungblood's Avatar
Drives: 2013 Scion FR-S (37J)
They are kind of heavy, you can find some upto 5+ lbs lighter and unstrung weight is "worth" more than unsprung weight.
BigJyoungblood is offline   Reply With Quote
Old 03-29-2013, 08:26 PM   #3
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Yeah you can lower the car with stock wheels.
As said above you can get lighter wheels and more "track" oriented wheels that are known for taking more abuse.
So far i haven't heard anyone say not to use them for track use.
When it comes to stock tire though... everyones got an "expert" view on that as well...
The Following User Says Thank You to dem00n For This Useful Post:
BigJyoungblood (03-29-2013)
Old 03-29-2013, 09:02 PM   #4
wparsons
wparsons's Avatar
The stock wheels really aren't that heavy, especially for OEM wheels. You can find lots of 17" or 18" wheels that weigh more than the stock wheels, but you can also find a bunch that weigh less.
The RPF1's I picked up are almost 5lbs per corner lighter (20.4 stock, 15.6 for 17x8 RPF1's), but the tires I'm getting weigh a couple lbs more each (dunlop Z2), so my net savings isn't as much.
flickr
Old 03-29-2013, 10:41 PM   #5
Gearhd79
Gearhd79's Avatar
Drives: Scion FR-S
there is nothing wrong with the stock wheels other than they are "stock". Yes they are a bit on the heavy side compared to Enkei's but as said above, they are not the heaviest. I dont actually find the stock wheeels that bad looking but if i had a choice I might have gone with a different style wheel. I am going to Autocross this season with stock wheels with Dunlop stickey tires.
Gearhd79 is offline   Reply With Quote
Old 03-29-2013, 11:16 PM   #6
rainmonkey
Hmm, interesting, it's just that if there's nothing terribly wrong with the OEM wheels, why bother changing em and dropping a bunch of cash on it and then getting new rubber too...
at least that's what I'm thinking.
Old 03-30-2013, 12:10 AM   #7
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Nothing really wrong with the stock wheels, but aftermarket wheels that are noticeably lighter and have a better offset will really work to increase the handling and ride of the FR-S. The suspension (struts mainly) will last longer as well due to the less force acting against it; 20lbs is kind of heavy for a 17x7 wheel. 15-16lbs for a 17x8 wheel will give a much nicer ride (because of less mass trying to react against the suspension and upset the chassis...) and have less wear/tear on components due to less force being applied.
Instead of keeping the stock wheels and upgrading tires (which will add even more weight), I'd rather keep the stock tires and upgrade to lightweight wheels. Once you wear out the stock tires get new, better performing tires...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 03-30-2013, 11:48 AM   #8
rainmonkey
damn my hesitation from changing wheels are as follows:
1. Which ones?
2. I think I need to do a buttload of research on this 'offset' stuff - no idea what numbers to look for.
3. costs...
4. Advantages/Disadvantages of different radii and width.
Old 03-31-2013, 02:41 PM   #9
Gearhd79
Gearhd79's Avatar
Drives: Scion FR-S
i bought a second set of stock wheels ($100.ea) for my sticky tires only because i race in stock class autocross (muct be stock width) and i keep my stock wheels with stock tires the way they are for long trips and daily driving etc.. the stock tires suck for agressive driving but work well for highway and gas milege.
Old 03-31-2013, 03:24 PM   #10
rainmonkey
Isnt offset just the amount by which the wheel protrudes from the rest of the car's body?
Assuming the same width, why would wider spaced tires (from the very edge of the left to the very edge of the right) necessarily be better? Just because of a 'wider stance'?
Old 03-31-2013, 07:24 PM   #11
frz86
frz86's Avatar
Drives: 2013 Argento Scion Frs
Honestly, there is nothing wrong with the stock wheels other than the size and offset, strictly from an asthethics stand point. I personally went with 18x8 et35 to achieve more of a flushed look without going too aggressive. If you do not want to spend money on a set of wheels now, just wait until your tires wear out and upgrade your wheels/tires then.
frz86 is offline   Reply With Quote
The Following User Says Thank You to frz86 For This Useful Post:
husker741 (03-31-2013)
Old 03-31-2013, 09:10 PM   #12
husker741
This. I figure that if I want to throw the car around some corners, these are the rims and tires to do so. Then in the future when hopefully I have more power that requires more rubber, I will get wheels and tires then.
husker741 is offline   Reply With Quote
Old 04-01-2013, 12:13 PM   #13
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I bet the stocks would look good powdercoated white.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 04-01-2013, 01:58 PM   #14
tennisfreak
Drives: 2018 BMW M240i
I had planned on switching out tires/wheels as soon as I took delivery.
But then I saw that the wheels looked pretty danged good on the whiteout FR-S. That combo looks much better in person than it does in pictures.
If had gotten any other color besides a whiteout FR-S I would have upgraded the wheels and tires immediately. The dealer I picked mine up from had both the Raven and Asphalt colors as well and I did not think the stock wheels went well with those colors.
As it stands now I will wear out the stock tires and then look to upgrade both tires and wheels. I see no sense in wasting money with perfectly good rubber on there already.
Which 18" wheels will weigh the same or less than the stock wheels? mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 05-16-2013 03:07 PM
FS: Stock Wheels+Stock Tires+TPMS sensor Pin Flare Wheels and Tires 1 03-26-2013 11:07 AM
WTB stock wheels Grishbok Mid-Atlantic 1 03-19-2013 02:35 PM
WTB: Stock Wheels only jflogerzi Wheels and Tires 3 03-18-2013 09:11 PM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 10:26 PM
