Old 03-29-2013, 02:35 AM   #1
Tyson
Drives: black FT86
street fx GT low beam 6000k HID upgrade
just wondering if anyone has this :/ I attempted to install this as per the manual and it didn't work so I tested it by hooking it directly to the battery and they HID lamps lit up :/
Tyson is offline   Reply With Quote
Old 03-29-2013, 10:05 AM   #2
RZ86
RZ86's Avatar
Drives: 2012 Toyota GT 86 Manual
I've installed them on my 86 GT. Didn't really have an issue. You just need to follow all the instructions. Make sure the polarity is reversed aswell, and you'll need a cable tie to hold the clips together as once they're reversed, you'll find they don't clip in properly anymore. Most Toyotas are like this for some reason.
Current: '12 Toyota GT 86 Pearl White Manual
Previous: '96 Toyota Supra SZ-R
RZ86 is offline   Reply With Quote
Old 03-29-2013, 02:54 PM   #3
Tyson
Drives: black FT86
that's why I'm confused I made sure I swapped the polarity and it still didn't work :/
Old 03-30-2013, 05:10 AM   #4
crook
crook's Avatar
Drives: storm black GT
I got them and never had an issue? Use thier pics as a guide and re run over everything is all I'd suggest? And make sure you are plugging into the right plug (low beam not high beam)
crook is offline   Reply With Quote
Old 03-30-2013, 11:15 AM   #5
vault
86TUP
Drives: 86 GT
streetFX has a video where they do the install... check with that if u havent already...hope that helps
I put mine in last week without a problem....strangely, i didnt need to reverse the polarity so cable ties werent required and it clipped straight in
vault is offline   Reply With Quote
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
FS: H11 6000k HID kit abutterman Exterior Parts (Aero, Lighting, Etc.) 9 03-18-2013 05:36 PM
55W 6000k HID kit seven Exterior Parts (Aero, Lighting, Etc.) 1 02-21-2013 03:17 AM
Cusco Street Zero-A & Street Spec A Coilovers - In Stock And Ready To Ship Enjuku Racing Brakes, Suspension, Chassis 0 09-12-2012 05:12 PM
