Old 03-27-2013, 02:06 PM   #1
Mike86
Drives: Scion frs
Perrin crank pulley is this normal???
I installed my perrin crank pulley about 2 weeks ago and followed all instruction meticulously. After install i cheked to see if there was a wobble and everything seemed fine!
Yesterday i deceided to do a little rechek on my pulley and noticed that the head of the bolt is offset from the bolt?? The pullley is perfectly straight no wobble or anything but the bolt in the center is not turning very symmetrically maybe 1 or 2 mm offset and is turning in kinda of an oval shape??
I doubt i could have warped the bolt with a 1.5 foot breaker bar so im just wondering if it is normal or if i should have the bolt replaced
Thanks mike,
Mike86 is offline   Reply With Quote
Old 03-27-2013, 02:14 PM   #2
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
I'd replace it
Huehuecoyotl is offline   Reply With Quote
Old 03-27-2013, 02:17 PM   #3
NorseLegend
A Very Annoying Person
Drives: Subaru Impreza :( Hopefully BRZ
Originally Posted by Huehuecoyotl View Post
I'd replace it
+1 for replacing.
NorseLegend is offline   Reply With Quote
Old 03-27-2013, 02:19 PM   #4
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
Thanks mike,
Nope, they are all like that. It was not caused by anything you did. You must not have noticed that when you first installed it.
The hex and sometimes the outside of the bolt are not centered over the threads. It's just the way they make the bolt and it is nothing to worry about.
PERRIN_Mladen is offline   Reply With Quote
Old 03-27-2013, 02:53 PM   #5
Mike86
Drives: Scion frs
Thanks for the quick replie!! Great products great customer service as always!!
Old 03-27-2013, 10:42 PM   #6
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
I have the same "issue"... Glad to know it's normal!
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
PERRIN Crank Pulley Impressions eriktherod Engine, Exhaust, Transmission 15 03-25-2013 04:11 PM
