Old 03-27-2013, 01:58 PM   #1
brocktwalker
Drives: Scion FR-S Black
Exhaust and turbo comparable ?
So this is either going to be a good question or a really stupid question!
Do you need to have a special mid pipe or over pipe in an exhaust system when you plan to have a turbo?
brocktwalker is offline   Reply With Quote
Old 03-27-2013, 02:14 PM   #2
GTerran
GTerran's Avatar
Depending on the placement of the turbo, it could radically change the position and flow of the exhaust.
If you buy a kit, most will come with flanges that replace the stock part in the exhaust that the turbo will be inserted to. Custom setups may require you to do some modifications to get the turbo in there.
simple answer: yes :P the car wasn't designed with a turbo in it, so the exhaust does not have the hookups for it to be installed.
GTerran is offline   Reply With Quote
Old 03-27-2013, 04:58 PM   #3
brocktwalker
I thought so that is where the dump pipe is for, right? If I buy borla exhaust what kinda modifications am I going to have to do?
Old 03-27-2013, 05:24 PM   #4
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
The BRZ/FRS exhaust is as follows:
When going turbo, a majority of kits will replace the header with a turbo manifold AKA a header that's reworked to connected to the turbo. Directly off the turbo is the downpipe(most commonly known as) that is I believe every case thus far connects to the factory front pipe. "Header-back" exhaust kits will bolt up to pretty much every turbo kit, your only real decision you have to make is if you want single exit, duel exit etc. You mentioned Borla exhaust, what components do you have?
Tansey86 is offline   Reply With Quote
Old 03-27-2013, 09:46 PM   #5
brocktwalker
I was going to just purchase their catback system
Old 03-27-2013, 09:52 PM   #6
ajrcow
ajrcow's Avatar
Drives: Scion FRS
Just a thought. I think T1R dual exhaust will do the job ! I used to have it on my s2k with Greddy turbo kit and it works very well !
ajrcow is offline   Reply With Quote
Old 03-27-2013, 09:56 PM   #7
Tansey86
Tansey86's Avatar
Catback will be directly compatible with every kit, minus a rear mounted turbo, which I only know of one kit like that anyway.
Old 03-28-2013, 05:42 AM   #8
brocktwalker
That is all I wanted to know. Ty so much. I can buy my exhaust knowing I am not fucking up
Old 04-09-2013, 04:19 AM   #9
VBrz
Drives: Subaru BRZ
This thread (and OP question) were incredibly helpful to me! as i have an amazing catback invidia exhaust, and I'm considering getting the other header back components.
VBrz is offline   Reply With Quote
Treadstone FR-S/BRZ Turbo Kit Exhaust Pictures David2.0@Treadstone Engine, Exhaust, Transmission 21 03-28-2013 05:46 PM
Coilover make and setting comparable to stock VENOM~ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 03-03-2013 03:13 AM
Best Exhaust for turbo application Jamifra Engine, Exhaust, Transmission 23 09-19-2012 06:57 PM
Comparable test drives? ucmecheng FR-S / BRZ vs.... 18 04-26-2012 05:38 PM
FT-86 may be comparable to... a Saturn Sky? iff2mastamatt Scion FR-S / Toyota 86 GT86 General Forum 122 06-14-2011 02:45 AM
