Old 03-27-2013, 07:13 AM   #1
frosty86
frosty86's Avatar
Drives: '13 FR-S (Whiteout) Manual
Question Dreaded lights went away
So, I've been plagued by this CEL and Slip light for a couple months, and now they went away altogether without changing the ECU. I thought i'd ask you guys since I'm not too sure what happened..
Anyway, I usually store a box that carries my auto detailing equipment in my trunk. Sometimes that box presses against the trunk light wire and the lining against back seats. My CEL and Slip light tends to light up when the box presses against them.
So I folded my rear seats down, removed the box and the slip light went away. I assumed it was pressing against a sensor of some sort, not sure what and why... Probably the car detected something pressing against the wire?? I really don't know but at least my slip light went away..
Then I cruised for a few days with only the CEL until one day I decided to clean my engine bay. While cleaning, I accidentally wiggled (or shook) this thing while wiping it down...
I initially thought it was defective or something.. so i slightly lifted it up and then left it alone. Anyway, I got back in my car and drove for a few blocks. Soon, my CEL turned off.
I thought I was hallucinating so I tried to replicate the result by doing the same thing; pressing the box against the trunk lining with the seats up. As expected, the CEL and Slip warning lights came back. So i repeated the steps I took and wiggled that pipe thing... Both lights disappeared AGAIN.
In return, my A/C started smelling like shit for a day... but my car isn't in limp mode anymore.
I know this sounds strange but it made my CEL and slip warning light disappear. So, what happened?
Thanks in advance.
frosty86 is offline   Reply With Quote
Old 03-27-2013, 08:21 AM   #2
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
Someone on here installed LEDs into their tails or reverse or (?) and had a CEL that they believed had something to do with the wiring in the back. I wish I could remember more details (super vague, sorry). It could be related, then again maybe not. I'm trying to find the thread right now...
Chimpo is offline   Reply With Quote
Old 03-27-2013, 09:06 AM   #3
OrbitalEllipses
Drives: Attitude
http://www.ft86club.com/forums/showthread.php?t=24246
Similar thread. Rear fog install where a wire in the bumper was disturbed.
Old 03-27-2013, 09:09 AM   #4
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
If it's anything like a 350Z, the car's stability system/VSC uses the rear light / brake pedal switch as an input for various calculation, aftermarket tail lights were a big no no on that car. So maybe a short/ground in the brake light circuit is enough to trigger a VSC system malfunction? Just throwing this out there.
Rayme is offline   Reply With Quote
Old 03-27-2013, 09:22 AM   #5
OrbitalEllipses
Drives: Attitude
I think the car has grounding issues to begin with; I get shocked every time I get out of the car. One of these days I won't ground myself and blow up the pump...
Old 03-27-2013, 09:34 AM   #6
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
Ive noticed that a couple of times as well. This car has some serious character some days
RandomHero is offline   Reply With Quote
Old 03-27-2013, 10:40 AM   #7
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
You used to have a WRX, you should know that its a Subaru thing.
Ranatsu is offline   Reply With Quote
Old 03-27-2013, 11:01 AM   #8
jimbobrand
jimbobrand's Avatar
Drives: 2013 Subaru BRZ Premium
^This! All three of my Imprezas would shock me upon getting out of the car almost every day. Never experienced it in the BRZ though.
Jim Brand
2013 Subaru BRZ Premium 6MT WRBP
Oklahoma Subaru Crew-OKSC.org
TXIC San Antonio
jimbobrand is offline   Reply With Quote
Old 03-27-2013, 11:03 AM   #9
OrbitalEllipses
Drives: Attitude
Didn't happen with this much frequency in my WRX. Guess I'll make a grounding kit for the engine bay or something.
Old 03-27-2013, 11:37 AM   #10
Ranatsu
Cone basher
The BRZ hasn't really shocked me yet like the Impreza would. Every single day in the winter I would get shocked while getting out of my WRX or STI.
Subaru actually made a door grounding kit for those cars in Japan.
Found a thread about them.
http://www.northursalia.com/modifica...ic/static.html
Old 03-27-2013, 11:51 AM   #11
OrbitalEllipses
Drives: Attitude
Ah, thanks Ranatsu. Maybe it's because it's winter-ish, but I get shocked EVERY day. Will report back in the summer.
Old 03-27-2013, 10:04 PM   #12
greenguy101
VMFIC ORLANDO SCIKOTICS
greenguy101's Avatar
For what it's worth I changed my front and rear blinkers to led's and several hours later my SL and CEL came on. It ended up being a coincidence though. When I took the car to the dealership, they said the code was due to lean fuel and ordered one of the new fuel pumps.
"Silence is acceptance so start talking or quit bitching!"
greenguy101 is offline   Reply With Quote
Dreaded CEL/SCL Combo IceCreamMan Issues | Warranty | Recalls / TSB 36 08-01-2022 08:24 PM
**PHASTEK** HID Headlights, Reverse Lights, Fog Lights (FR-S / BRZ) PhastekSport Exterior Parts - Lighting 18 07-09-2014 07:42 PM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
Everyone in W.A get ready for that dreaded phone call... I just got mine.. FT-86GOD AUSTRALIA 141 10-05-2012 01:13 AM
The Dreaded Wait. H8R GTS AUSTRALIA 46 07-19-2012 10:54 PM
