Old 03-26-2013, 08:42 PM   #1
SVThis
SVThis's Avatar
Drives: Scion FRS
Rear toe ?
I've got everything bolted onto the car and am ready for an alignment. I'm wondering where to initially set the rear toe. I'm not a big fan of a loose setup but don't want to understeer like a pig either. Any suggestions?
Will be running RTR with the following setup:
17 x 7 Enkei RPF1
225/45R17 Dunlop Z2's
22 mm Strano front bar
Koni Sport SA
Toyota crash camber bolts
Zero toe on the front
We're not happy till you're not happy
2013 Scion FRS Whiteout 6MT
SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover.
SVThis is offline   Reply With Quote
Old 03-26-2013, 08:54 PM   #2
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
.2 to .3 total degrees toe in is what id start at.
GTM_Challenge is offline   Reply With Quote
Old 03-26-2013, 08:59 PM   #3
D1cker
Drives: B9 S4/ND2
Is there rear toe adjustment from the factory on this car?
D1cker is offline   Reply With Quote
Old 03-26-2013, 09:07 PM   #4
coyote
coyote's Avatar
Drives: Slowly
Yes
coyote is offline   Reply With Quote
Old 03-26-2013, 09:46 PM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
if you want more stability you want toe IN
because that means the tires point towards the center of the car and as such applying their forces towards the center, thereby stabalizing the vehicle.
some racers prefer zero toe but for a daily driven car this could make it prone to snap oversteer during adverse conditions, you don't want to go sideways on an onramp.
toe out, well, that's crazy land.
Old 03-26-2013, 10:03 PM   #6
xwd
You can look in the past threads but most have gone with 1/16 toe in on each side or 1/8 total or 1/32. With zero rear toe the rear end is a little loose. You might be able to tune that out with the shocks but some rear toe in is probably a good thing.
With the Strano bar zero toe in the front will probably work best.
rear brake light in the rear fog light section FR-Shadow Cosmetic Modification (Interior/Exterior/Lighting) 34 12-13-2012 10:52 AM
Boo boo on the rear noc Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 11-12-2012 05:19 AM
Help Removing Rear Seats and Rear Part of Center Console ZC6BRZ Cosmetic Modification (Interior/Exterior/Lighting) 2 08-27-2012 03:11 PM
New rear spoiler choice: Carsmo rear spoiler Ray@Carsmo Cosmetic Modification (Interior/Exterior/Lighting) 46 08-10-2012 02:20 AM
