Old 03-22-2013, 09:52 PM   #1
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
CEL with new intake
Just installed the FA20club CAI the CEL instantly came on. I've only driven 20 miles and it's still on. Will ECU adjust to the extra air or is something wrong? Thanks!
EDIT: I also have the FA20club tune but it won't be installed for a few days. I have to drive 12 hours to GA tomorrow and I don't want to take the chance of something messing up with the tune and end up stranded here.
Bg8780 is offline   Reply With Quote
Old 03-22-2013, 10:10 PM   #2
FA20Club.com
Drives: 2013 White Out FR-S
you know you can call or pm me right im usually available just like when you called me this morning for the filter part number.
FA20Club.com is offline   Reply With Quote
Old 03-22-2013, 10:11 PM   #3
mad_sb
Drives: 2013 Asphalt FR-S
Instantly as in as soon as you cranked up the the car or did you drive it a bit first?
if it came on as soon as you cranked it I would check the maf harness is properly connected and the sensor is in the pipe the correct way.
If you had to drive it for a bit before it can on then make sure you don't have any leaks between the maf and the throttle body.
Either way you need to pull the code asap. I don't see how the tune could cause any issues, but you need to see what the code is before your flash it... can't you use ecutek to check the codes?
Old 03-22-2013, 10:11 PM   #4
Bg8780
Bg8780's Avatar
I've called twice in the past 30 minutes I got voicemail each time. I figured you guys went home for the night.
Old 03-22-2013, 10:19 PM   #5
Bg8780
Bg8780's Avatar
The llight came on as soon as the engine was started. Pulled the battery but that didn't change anything. I do have a the whole ECUtek kit. But I have no idea how to pull any data from it. I've enver used this software before.
Old 03-22-2013, 10:37 PM   #6
TyperRspec789
Version 2 Coming Soon...
TyperRspec789's Avatar
Drives: Turbo Argento FRS, Asphalt FRS
If the light came on as soon as the engine was started. Check all the clamps and the MAF sensor (as mentioned before). You probably just have a leak or an opening somewhere.
This same thing happened to me when my MAF sensor wires got damaged by the serpentine belt. Do you have an Ecutek cable? You can pull the code through their software.
TyperRspec789 is offline   Reply With Quote
Old 03-22-2013, 10:37 PM   #7
mad_sb
did you drop the sensor while you were swapping it from one pipe to the other by chance?
You can unhook the negative terminal of the battery, un plug and re plug the maf connector (check the pins and connector etc for damage), wait a few minutes, then re connect the negative terminal.
There really isn't much that can go wrong but you do need to be careful with the sensor and the harness.
I would go ahead and install the ecutek software and read the manual real quick to see how to pull the codes.
Old 03-22-2013, 10:39 PM   #8
wootwoot
Drives: FRS
double check the MAF harness to make sure it is plugged in correctly.
wootwoot is offline   Reply With Quote
Old 03-22-2013, 10:54 PM   #9
Bg8780
Bg8780's Avatar
Just pulled the codes with help from Tony. Turned out to just be a brainfart (lack of a better term) and the code was associated with the AC. I cleared it and all is well now. FA20club support is second to none!
Old 03-23-2013, 01:29 AM   #10
FA20Club.com
yeah it was a simple process. if you guys need me the phones dont forward calls after 8pm EST but you can still pm me or email if you need me to answer any questions or call you back
The Following 2 Users Say Thank You to FA20Club.com For This Useful Post:
Bg8780 (03-24-2013), veuxx (03-23-2013)
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 01:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 09:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 02:31 PM
