| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
Pedals over Paddles.
Drives: Celica GT-S | 89 Supra | 07' Accent
I'm wondering about ETC.
Or Electronic Throttle Control, drive-by-wire. I've seen that newer car have this and i'm wondering the pros and cons to the car enthusiast. Does it take away more control of the car from the driver? I foresee a situation such as pulling the fuse to the TCS for a trackday or something and the car denying you the ability to use the gas pedal. Anyways, what can you tell of the pros, cons and personal opinions?
![]() 2002 Celica GT-S Track Car | 1989 Supra Track Car | 2007 Hyundai Accent AutoX | 2003 Cadillac CTS Daily |
4g63>rotards
Drives: 98'GSX 11'Tundra 10'Wrangler
I hate drive by wire personally, almost every car ive driven (without a flash) has a noticable delay, I would compare to turbo lag for a new turbo driver.
#3 | ||
Ninja Cat Mod
Don't know much but this is from wikipedia and more can read there if that helps.
[ame="http://en.wikipedia.org/wiki/Electronic_throttle_control"]Electronic throttle control - Wikipedia, the free encyclopedia[/ame] Quote:
Education is Important, but Race Cars are more Importanter |
Drives: 1985 P-Type
One thing I dislike are switchable modes that tweak throttle curve. "Sport mode" just boosts values in the middle of the pedal's range of motion which makes the throttle more touchy. You lose resolution by doing this. And for most people who drive around in standard mode all the time, this serves only to make the car react differently than they anticipate. Which can have negative results for not just the driver but also those around them.
Sometimes less is more. |
To me it sounds like, 'If you can avoid getting a car with it, do.'
#6 | |
Drives: 2012 VW GLI
However.. you guys do know where I'm going with this next now right (regarding the DBW problem)? Guess what?? Our tune completely takes care of this lag, providing what feels like a more direct connection to the throttle. This is a good example of one of the positive advantages of everything seemingly being takin over by computers; at least we have the ability to easily make tweaks right??Just another good reason to check out our tune. I'm willing to bet it takes care of all the little gripes you have with the stock performance of your car (which I'm assuming it must be). |
#7 | |
Did you just offer cogent, logical advice, and then slide in a plug for your product? Very unethical behavior, morally reprehensible, even. I'm close to a tantrum. (jk) From the sound of it, i'd rather stick to old-fashioned cars. I still have my eyes set on a bare-bones 2009 Hyundai Accent Hatchback. *swoon*
#8 | |
Drives: 2012 VW GLI
Spaceman
Drives: 2013 Firestorm Scion FR-S
#10 |
Drives: 2012 VW GLI
#11 |
Drives: '06 AM V8V Coupe
I don't think it's accurate to say electronically controlled throttles are taking away your connection to the car or making things easier. You can change the "throttle map" on a cable throttle by changing the shape of the intake tract near the throttle body or the shape of the plate itself, and the e-throttle maps are designed to soften response but still try to emulate a throttle body; The torque it gives you at the same pedal position decreases as the engine speed goes up. When I drive my car with its cable throttle, I don't think "gee, my foot directly controls the throttle, the torque the engine gives me is so intuitive!", because the amount of air going through a throttle plate at some position relative to another is not intuitive to the human mind.
The reason it feels like there is less response is because that's how it's programmed. On some cars you can give the throttle a jab and the engine literally does not respond. Safety feature. Doesn't have to be that way, I think BMW M cars have electronically controlled throttle with very good response. The benefits are hard to see, but having the computer take one input and spit out instructions to the various engine subsystems is much better than having a computer attempt to respond to unpredictable changes in airflow controlled by a valve directly modulated by the driver. |
#12 |
Drives: 2015 GTI
Think pedal position and the amount the throttle body is open.
With the standard cable throttle, it is all mechanical. If you graph the pedal position versus the amount the throttle body is open, you'll get a linear curve. For instance, pedal fully down is 100% open. Pedal half down is 50% open. (Could actually be different but that's the simplified idea). Now if you take drive by wire (dbw) and graph it out, for most cars, you'll get curve that fits better to an exponential curve or some polynomial curve. The pedal has a position sensor which senses the position of the pedal and coverts that position into a specific voltage which is used to determine how much the throttle is open. This is why there are multitudes of comapnies (Blitz, etc) that sell these throttle controllers. It is something that is easy enough to make that you could actually go to radioshack and build one yourself. You just need to know your circuits. Either way, these throttle controllers basically goes between the voltage from the position sensor and the input to determine the amount the throttle is open to adjust the voltage as needed. The overall result is a more linear behavior.
2013 GTI - Gone
2015 GTI |
#13 | |
From my experience, the actual throttle mapping with ethrottles is better for actual driving because you get much more resolution with the softened low end response, whereas the lightest tap of the throttle gives you a huge jolt with cable throttle. |
#14 |
Drives: 2015 GTI
I believe 50% open means that the throttle is letting 50% of maximum flow through.
Maybe I was a bit unclear in what I was saying. http://www.blitzpowerusa.com/product...n/throcon.html Here is the site to the Blitz website. Not sure if this clears anything up or not.
2013 GTI - Gone
2015 GTI |
| JUST WONDERING WHEN IS THE NEXT FRS MEET? | 8ight6ix | Southern California | 10 | 11-29-2012 11:18 PM |
| Wondering if I'm the only one with this problem | xxmaryduhxx | Northwest | 15 | 11-29-2012 09:39 AM |
| Wondering about the BRZ in Scion Night | F-Bomb | Southern California | 8 | 06-16-2012 12:54 AM |
| Wondering if this car will herald a new automotive age... or be a flop? | rifleshooter | Scion FR-S / Toyota 86 GT86 General Forum | 43 | 01-10-2012 11:16 PM |
