Old 03-19-2013, 09:59 AM   #1
pdreams
"TAC" sound when moving off
Hi,
Had my car, RHD BRZ, for around 10 months now.
1) Recently, the car started to emit a "TAC" sound from the driver side door area when the car is moving off from a stop. Sounds as if there is some movement due to slack between 2 pieces of metal. Its the kind of sound that I believe either tightening or lubrication can help, just need to find a spot.
Been trying to locate the sound. At first I thought it could be the bolts holding down the driver seat but it doesn't seem to be as I could not replicate it.
I tried to WD40 the door hinges, but the sound still comes and go.
2) Also, there is a kind of light tapping sound from the left rear. Sprayed all the WD40 and all as per the rear deck rattling sound. Its not that kind of sound. Sound comes out typically when the left rear goes over a bump or the car is travelling onto a slope.
Wonder if anyone has experience in the above areas.
Cheers
pdreams is offline   Reply With Quote
Old 03-19-2013, 10:44 AM   #2
SloS13
Drives: 2013 FR-S whiteout
wiggle door up and down, see if its door latch.
Also, WD40 is not a lubricant.
SloS13 is offline   Reply With Quote
The Following 2 Users Say Thank You to SloS13 For This Useful Post:
pdreams (03-19-2013), Subie (03-19-2013)
Old 03-19-2013, 10:49 AM   #3
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
If you want to lubricate it find some White Lithium Grease
The Following User Says Thank You to norsamerican For This Useful Post:
Old 03-19-2013, 09:48 PM   #4
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
The sound coming from the trunk could be part where the jack is, and it moves up and down as you go over bumps. I've heard other people having the same "issue" and that was the cause.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 03-19-2013, 09:57 PM   #5
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
http://www.ft86club.com/forums/attac...1&d=1352827748
LeeMaster is offline   Reply With Quote
Simple Sound Tube Switching "on/off" Tech DIY (Do-It-Yourself) Guides 266 03-10-2021 04:12 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
