Old 03-14-2013, 08:24 PM   #1
Tamoor
Tamoor's Avatar
Drives: Frs- white out
Ding and Paint Chips! how to fix it?
I got a small ding in my back driver side quarter panel with 2 small paint chips. Not sure how it got there but now i want to fix it, the ding isnt too bad and the chip is small but it still bothers me. Im going to get a DPR to fix the ding but for the paint should i ust use the touch up paint with a tooth pick? and if I do i have no experience with sanding or buffing. Or should i take it to a body shop for touch up paint?
Tamoor is offline   Reply With Quote
Old 03-14-2013, 09:05 PM   #2
stilletto
Drives: 2008 Mitsubishi Eclipse GS
Most Paint Chip Kits (Dr. Color Chip, LANGKA, etc) yield mixed reviews. Match the paint pretty well, but don't actually fill the chip itself. Best results would come from a body shop, where they'd re-spray the area, then sand and wet sand for a perfect finish.
stilletto is offline   Reply With Quote
Old 03-14-2013, 10:05 PM   #3
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
I also have a ding in the same area, want to hear how you fix the ding on yours too.
LeeMaster is offline   Reply With Quote
Old 03-14-2013, 10:07 PM   #4
stilletto
Paintless Dent Removal. ..or Dry Ice.
Old 03-14-2013, 11:08 PM   #5
Tamoor
Tamoor's Avatar
The ding can be removed for about $90 from paintless ding removal it's fixing the paint that I am worried about. If I take it to a shop for a repaint do you think the repaint will be noticeable? I'd rather have a small white spot than an uneven paint
Old 03-14-2013, 11:09 PM   #6
stilletto
Shouldn't be noticeable on such a new car. Doubt the paints started to fade this quick.
Old 03-14-2013, 11:23 PM   #7
Xdragonxb0i
Drives: ex500r
thats why i got clear protection film!
Xdragonxb0i is offline   Reply With Quote
Old 03-15-2013, 10:43 AM   #8
Tamoor
Tamoor's Avatar
Do you think touchup paint will blend in ok then? Or should I take it to a body shop?
Old 03-15-2013, 11:07 AM   #9
whaap
whaap's Avatar
Don't have your car resprayed. It's very likely that the paint won't be an exact (perfect) match and a large area could be more noticeable. Just use the tooth pick with touch-up. Just be sure not to get any overlap on the existing paint. Keep the paint inside the chip. Let the first coat dry and then add a second coat and if necessary a third. I would not get involved with wet sanding, etc.
whaap is offline   Reply With Quote
Old 03-15-2013, 11:12 AM   #10
sierra
Drives: Skoda Yeti DSG diesel 4x4
If it doesn't work you can still take it to a body shop. I would get a touch up and try to fill it with paint. Get a small plastic blade to wipe it flat before it dries and do it a few times to fill it and I bet it wont be worth worrying about after you polish it, especially on pearl.
My pearl paint got hit by a small rock from the opposite side of the road on a 110kph limit, so it was moving and hit the pissing bonnet! It left a tiny dent and 3 small scratches but apart from my dentist, who spends all day looking for imperfections on pearl teeth, nobody else has been able to find it in the sun until I point it out.
sierra is offline   Reply With Quote
Old 03-15-2013, 12:17 PM   #11
stilletto
Professional Body Shops, and even a few talented side guys, should be able to blend body panels if necessary.
The only paint I've ever had a time matching was Nissan's Pikes Peak White, which is a pearl with gold flake, on my Z33. Took two body shops and three attempts before it was just decent.
Old 03-16-2013, 03:28 AM   #12
Tamoor
Tamoor's Avatar
Thanks
Thanks for all the replies guys! i am just going to use touch up paint, it comes in a package of 2 the clear coat and the white any tips on how to apply it? should i apply the white 3/4 of the way then fill with clear coat to make even? Also i noticed i had quite a few small rock chips on my front bumper. Im guessing there is no way to avoid this w/o getting a clear bra right?
Old 03-16-2013, 03:34 AM   #13
sierra
Can you let me know how it works out?
I would fill it with the white, as you describe and finish with one coat of clear.
That way it can't look like a dent still as it might if you use the clear to fill it on top of a layer of white.
Did you get it from the dealer?
Old 03-16-2013, 03:47 AM   #14
LeeMaster
Red wine
Apply using a toothpick, you can easily work your way around the damaged area without accidentally using overexessive paint on the clear coat.
chip, ding, scratch
Guess it was bound to happen... (rock chips) r4m3n Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 26 08-10-2013 12:03 AM
Door ding prevention! smbrm Cosmetic Modification (Interior/Exterior/Lighting) 16 01-29-2013 06:22 PM
My First Ding :[ Vicious LED Scion FR-S / Toyota 86 GT86 General Forum 32 10-24-2012 05:21 AM
Left some deep chips dabocx Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 06-20-2012 12:53 AM
Received my FR-S with a small ding Neurytic Scion FR-S / Toyota 86 GT86 General Forum 10 06-03-2012 12:53 PM
