Old 03-12-2013, 05:15 AM   #1
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Is pre-locking the seat belt a no go?
I had a Cobra one piece seat in my previous car. Even just using the standard inertia reel seat belt it kept me firmly in place. I am finding the seat in my BRZ to be somewhat lacking by comparison. I can't but help think that pre-locking the seat belt is a bad idea but is this correct? Does any one know why I shouldn't do this? (And no, I can't legally replace the seat and keep it road worthy )
Old 03-12-2013, 09:19 AM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
cg-lock!
The Following 2 Users Say Thank You to 7thgear For This Useful Post:
whataboutbob (03-19-2013), WillRacer1jz (03-14-2013)
Old 03-12-2013, 10:05 AM   #3
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
I used to try and pre-lock the seat belt, but it never really worked that well. I think I'd shift or relax tension on it and it would let go. The CG lock was an improvement for sure, but the problem is that your upper torso still moves laterally. I never feel completely comfortable and relaxed unless I'm strapped in with a harness. It's a bummer for sure, but the reality in my case.
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
Old 03-12-2013, 10:28 AM   #4
ayau
Drives: Some rust bucket
Without a rollcage, I don't think you'd want your upper torso to be locked in place. If your car rolls over and your upper torso is locked in place, your spine mine get crushed. The CG Lock is probably the best solution without compromising safety.
Old 03-12-2013, 11:04 AM   #5
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
Originally Posted by 7thgear View Post
cg-lock!
have you used one? How does it mount to the oe rails, or does it?
Huehuecoyotl is offline   Reply With Quote
Old 03-12-2013, 11:12 AM   #6
funbeatsfast
funbeatsfast's Avatar
Drives: '13 FR-S
CG Lock attaches to the seat belt, allows you to tighten and "lock" the lap portion of the belt. It's easy to use and works pretty well. Definitely not a replacement for a harness.
Anyone look into this? -> http://www.ft86club.com/forums/showthread.php?t=30225
funbeatsfast is offline   Reply With Quote
Old 03-12-2013, 11:14 AM   #7
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
rail what?
no a cg-lock is a small device that locks the length of your belt's lap portion.
you know how your seatbelt moves through the slit in the seatbelt clip? well it prevents the lap poriton from moving. Next time you'r ein the car, pull up on your belt as hard as you can to get a feel or what it would be like.
http://www.cg-lock.com/
The Following User Says Thank You to 7thgear For This Useful Post:
Huehuecoyotl (03-12-2013)
Old 03-12-2013, 11:46 AM   #8
kos
Drives: 04 UCF30 / 05 GDA-E / 06 GDA-F
cg-lock!
THIS.
I may have one laying around that I have no use for anymore now that I have an Autopower cage and harnesses...
2005 RS Impreza Airlift Bagged
2006 WRX Street AWD Time Attack
kos is offline   Reply With Quote
Old 03-12-2013, 02:58 PM   #9
Huehuecoyotl
rail what?
Ah, I see. thanks
Old 03-12-2013, 03:51 PM   #10
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I've used CG-Locks in a couple different cars for both autocross and track duty. Love them. Planning on eventually getting one for my BRZ too. I'm a really big guy, but have never had an issue with my upper body moving around on track or autocross course with my butt locked firmly in place with the CG-Lock. I've had Schroth 3/4 point as well as 5-pt (with a cage) in other cars in the past, but don't miss them for autocross and HPDE/PDX track days.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 03-12-2013, 04:04 PM   #11
Captain Snooze
Drives: Red Herring
Ummm.. Wouldn't you be locked in place any way when the inertia reel locks? I thought they locked up at sudden deceleration or more than so many degrees pitch/roll and if the pre-tensioner kicks in I am hypothesizing you would be in a similar position to having the belt pre-locked.
Old 03-12-2013, 05:54 PM   #12
brz7400
brz7400's Avatar
Drives: Subaru BRZ
i like to pre-lock during autocross. to prevent it from loosening, you really have to cinch yourself in tight before pre-locking.
my other car has a child seat holding type of reel for the driver, so i can easily get locked up by pulling belt fully out and then allowing it to retract back click by click (only loosens when you pop the buckle).
brz7400 is offline   Reply With Quote
Old 03-12-2013, 06:08 PM   #13
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
I think he was referring to a full harness. A shoulder belt, even locked, isn't going to lock your upper body into a vertical position the way a 4 or 5 point harness will.
Without a cage, I could see using one of those Shroth harnesses that hook up to the rear seatbelts for something like Autocross, but I probably wouldn't use a harness without a cage for anything high speed or involving other cars.
Nathan
SubieNate is offline   Reply With Quote
Old 03-12-2013, 11:47 PM   #14
Captain Snooze
Drives: Red Herring
Nathan
Ahhh... Check
No seat belt. Mo707 Cosmetic Modification (Interior/Exterior/Lighting) 40 11-16-2012 08:07 PM
Seat and seat belt torque specs TheSt|G Scion FR-S / Toyota 86 GT86 General Forum 2 11-01-2012 09:52 PM
CG Lock - Seat Belt Retainer to Hold You Firmly in Seat Jimbo Miscellaneous 0 07-23-2012 01:27 AM
Red Seat Belt - where to get? MarkMash Cosmetic Modification (Interior/Exterior/Lighting) 11 06-24-2012 11:55 AM
You wish you were this seat-belt! YukiHachiRoku Off-Topic Lounge [WARNING: NO POLITICS] 13 05-03-2012 07:43 PM
