Old 03-11-2013, 04:39 PM   #1
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Sub Installed
Decided to go with a 10" sealed enclosure. Still powered by my workhorse Kicker 750.1 amp (rated at 1000 RMS).
ecko04 is offline   Reply With Quote
Old 03-11-2013, 08:16 PM   #2
AlexTheGreek
AlexTheGreek's Avatar
Drives: BRZ Premium Black
Amp install pics???
AlexTheGreek is offline   Reply With Quote
Old 03-11-2013, 08:58 PM   #3
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Originally Posted by AlexTheGreek View Post
Amp install pics???
Personally, I would've preferred to do an install like the one in my Camaro, but the weather hasn't improved to the point where I can really get going on woodworking as I would like.
http://www.camaro5.com/forums/showthread.php?t=209155
http://www.camaro5.com/forums/showthread.php?t=214181
So for now, i'll deal with the vanilla 10" sub enclosure and amp mounted to the box approach. It does the job for now.
The amp slightly hangs off the side of the box so I used some backstrap to secure it and screw the backstrap into the side of the box for support.
As I was doing the install, I completely forgot to run my remote turn-on wire from behind the radio. I had already re-installed the radio and as I was wiring up the amp, it dawned on me.
Oh well, I grabbed my multi-meter since the factory amp for the Bespoke system that drives the front door speakers is in the back, quickly located its 12v amp turn on so I used it.
I used the factory amp ground as well.
This little addition, that took about an hour from beginning to end, substantially improved the sound of the vehicle. I usually change all the interior speakers with coaxial speakers in the rear and components in the front then drive those with a 4 channel amp. As I take a listen now, I may forgo that all together as the sound has improved that much by just adding a sub.
While I was at it, I hardwired a radar detector as well.
Old 03-12-2013, 08:52 PM   #4
midnightfrolic
Drives: Scion FRS A/T raven
looks pretty slick. I like it.
midnightfrolic is offline   Reply With Quote
Old 03-12-2013, 10:08 PM   #5
cruzinbill
Drives: Argento 6spd FR-S
I see youre using my fav kicker fuse block.
cruzinbill is offline   Reply With Quote
Old 03-13-2013, 07:40 AM   #6
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
I swear by Kicker subs, monoblock amps, distribution blocks & wiring.
Old 03-13-2013, 08:47 AM   #7
itdansharpe
itdansharpe's Avatar
Nice setup!
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
Old 03-13-2013, 09:07 PM   #8
AlexTheGreek
Nice man. Simple and to the point.
Old 03-13-2013, 11:14 PM   #9
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
I don't really like the way the amp is mounted. I like the setup in my Camaro but I have more space to work with. I think i'll dust off my JL XD 400/4 & JL XD 600/1 and do a stealth mounting job.
For now, it'll work until I get my Polk speakers in. At that point I plan on doing the entire audio system in 1 take.
Old 03-13-2013, 11:32 PM   #10
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
I want your box!
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 03-13-2013, 11:41 PM   #11
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Originally Posted by Missourifornian View Post
I want your box!
PM me
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
Old 03-26-2013, 08:49 PM   #12
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Loved my Dayton, it's by far the best sounding sub but I have a lot of subs so I switch quite often. I removed the Kicker mono and replaced it with an JL XD 600/1. I also installed the 4 channel JL XD 400/4. While I was at it I swapped subs from the Kicker CompR to the HiVi SP10...look at the surround & magnet!
86 Airbag installed! Trojan_SC Cosmetic Modification (Interior/Exterior/Lighting) 218 02-09-2015 03:45 AM
KDT 925 installed. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 54 08-14-2014 03:29 PM
JDM Fog Light ON and installed! 86design BRZ Photos, Videos, Wallpapers, Gallery Forum 111 09-20-2013 12:23 AM
Just Installed RS-3 Dezoris Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 12-27-2012 09:41 AM
BRZ LED lights installed KI_ZN6 Cosmetic Modification (Interior/Exterior/Lighting) 24 07-04-2012 05:34 PM
