Old 03-05-2013, 09:56 PM   #1
Trog
My BRZ Build - Vancouver Canada
My goal was to continue the fine work of the Subaru/Toyota designers without changing the handling characteristics of the car. I understand that factory designers are constrained by certain limitations. These may include; regulations, cost, practicality, and marketing. I of course, have no such constraints. OK, perhaps cost, but what the wife doesn't find out about is fair game.
To that end, here's by build to date:
1- Tein Flex coilovers. Lowered car approx 30mm (1.25-inches) Excellent feel. About the same on smooth surfaces, a bit firmer when the road gets choppy. Set the valving at 10-clicks.
2- Cusco rear camber bars
3- Perrin cat-back exhaust
4- Magnagrafik stone guards
5- 4th brake light
6- LED trunk lighting
7- WeatherTech floor liners.
8 - Volume knob for AVIC- Pioneer radio (ordered from Tom Hohl thomashohl@comcast.net.
9 - OZ Ultraleggera wheels (18x8, ET 48) Fitted with 225/40 Potenza RE760's
10- Brakes... I've got a set of AP Racing brakes on order. Front 6-Pot, rear 4-Pot. Pics to follow.
Trog is offline   Reply With Quote
Old 03-06-2013, 11:15 AM   #2
sklimo
Sweet!!!
Old 03-06-2013, 11:33 AM   #3
L3P47
L3P47's Avatar
Drives: Firestorm FR-S
Looking good so far man... What other performance/ cosmetic mods you planned?
Chattanooga Scikotics MFIC
Red Robin Build
L3P47 is offline   Reply With Quote
Old 03-06-2013, 03:01 PM   #4
fumii
Drives: Subaru
nice and clean. love it
fumii is offline   Reply With Quote
Old 03-06-2013, 08:12 PM   #5
Trog
AP Racing brakes.... 6-POT in front, 4-POT in the rear.
Old 03-08-2013, 12:39 AM   #6
Fresh86
Fresh86's Avatar
Drives: 2013 Scion FRS
looks good
Fresh86 is offline   Reply With Quote
Old 03-09-2013, 11:10 PM   #7
Trog
Did a 4-wheel alignment yesterday. I'm starting with some rather benign settings and will adjust as testing dictates. Baseline settings were:
Front camber: -1deg
Front Toe: 0
Rear camber: -1.5deg
Rear Toe: 0
Driving impressions: The car doesn't turn in nearly as well as with the stock settings. Which I find odd given that the stock front and rear camber were pretty much 0-degrees. I did notice that the original toe was slightly positive. That would make turn-in pretty quick at the expense of high speed stability.
Next week, I'll increase the front camber to: -1.5deg, plus add some toe-in to improve the high speed stability. I'll take rear camber to: -2.0deg, however I'll leave rear toe at 0.
My AP Racing brakes are scheduled to arrive next week (6-Pot front and 4-Pot rear).
Stay tuned for more progress photos.
Old 03-16-2013, 03:38 PM   #8
Trog
Them's the brakes!
AP Racing Brakes.
DOT 5.1 brakes fluid. Stainless lines.
Front: 6-POT, 355mm (14-inch) x 32mm, slotted, 2-piece rotors)
Rear: 4-POT, 330mm (13-inch) x 25.5mm) slotted 2-piece rotors
Front clearance is about 2mm from wheel spokes and wheel weights!
Old 03-16-2013, 04:43 PM   #9
that_guy
Dances with Cones
that_guy's Avatar
Drives: 2013 Scion FR-S Raven
Front camber: -1deg
Front Toe: 0
Rear Toe: 0
Increasing your front toe in will only make the car twitchy to drive. The rear needs toe in so that the rear gains stability, not the front. If you want front turn in to increase, you need to toe out the front, not in.
Camber should also be measured but by getting heat ranges from the tires. Simply adding more wont solve anything unless you have data to support it's improved something.
Brakes and car look good though.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD
that_guy is offline   Reply With Quote
Old 04-07-2013, 03:39 PM   #10
Trog
AP Big Brake Update
I've been enjoying my AP brakes for a few weeks now; however a couple of issues have developed.
The first problem was that once warmed up, the brakes squealed like a stuffed pig being dragged to slaughter. It was getting so bad; I was embarrassed to drive the car.
And just yesterday, one of the brake pads on the passenger side started dragging against its rotor.
The first problem was easy to solve. I deglazed the pads, and smeared some copper based anti-seize compound on the backside of the pads.
The dragging pad was more of a concern. Where the AP Racing 4-pot rear calipers have a threaded bolt that retains the pads in the caliper, the 6-pot front caliper uses 2x15mm pins that are held in place with friction. The passenger side forward pin had worked its way out, and allowed the outboard brake pad to cock-over and grind against the rotor. Further inspection revealed that the driver's side was just about to pop-out as well. In addition, there was considerable corrosion on the pins.
To prevent the pins from popping out again, I drilled a 1/16-inch hole in the pin and locked them in place. I've ordered replacement "R" Hair-Pins to replace the cotter pins to facilitate track side pad changes. In addition, I lubricated the pins liberally with aluminum based anti-seize to mitigate corrosion.
I see this as a design defect.
Old 04-07-2013, 03:50 PM   #11
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Man i want those brakes and cusco arms! Nice project!
Silverdub is offline   Reply With Quote
Old 04-07-2013, 04:03 PM   #12
Trog
Bonjour Silver..... take note that with all the salt used back east, you'll have to stay on top of corrosion. I've read that some have had to get those pins machined out when they rusted in place.
Any snow on the gound?
Old 04-07-2013, 04:06 PM   #13
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Snow disapeared for good a week ago and no worries fir the salt. I dont drive my car during winter time...actually, i dont even drive it in the rain!
Old 04-07-2013, 04:15 PM   #14
Trog
Nice turbo project, good job!
What are you using for engine management? I used Electromotive on my 911 and have been very happy with it.
WTB: FR-S MT in Vancouver Dispect Canada Classifieds 13 03-20-2013 05:17 AM
Vancouver BC !!!! FRS fog light ft86.frs CANADA 4 11-27-2012 09:36 PM
Plasti Dip Vancouver? Dispect CANADA 12 11-15-2012 08:44 AM
BRZ/FR-S Article in the Vancouver Sun diddy CANADA 3 08-26-2012 11:45 PM
Build and Price is up in Canada Calum Scion FR-S / Toyota 86 GT86 General Forum 15 05-29-2012 08:37 AM
