View Poll Results: If Toyota made a convertible FR-S for the US, would you buy one?
No I like coupe version of the FR-S better. 133 39.82%
Yes I think it looks great; plus a soft top should help keep the weight and price down. 44 13.17%
Maybe, could we get a hardtop convertible as well like what Mazda does with its MX-5 Miata. 67 20.06%
No I personally wouldn't want one because I already have a coupe, but would like it built for others. 90 26.95%
Voters: 334. You may not vote on this poll
Old 03-05-2013, 12:04 PM   #1
vh_supra26
Site Moderator
Drives: Supra
Live Photos Geneva: Toyota FT-86 Open Concept would make a mighty fine droptop FR-S
There's nothing wrong with going topless. And Toyota is proving that its FT-86 (read: Scion FR-S/Toyota GT86/Subaru BRZ) coupe is just as excellent with its roof removed. It may only be a concept, but this FT-86 Open previews a new droptop from the Japanese automaker to round out the Toyobaru sports car family. We're finally getting the chance to see the open-air FT-86 in person here at the Geneva Motor Show, and we're already yearning to take it canyon-carving.
Interestingly, the FT-86 retains the Toyota coupe's two-plus-two seating arrangement (we'd prefer a proper roadster setup here), but things still look good for this droptop two-door. We'll be curious to see how the car looks with its folding soft top in place (operated by fancy-shmancy electronics, by the way).
As for production intent, rumors have been flying about a production Scion FR-S convertible, but until we hear it directly from Toyota. Consider our hopes in check but our fingers crossed.
http://www.autoblog.com/2013/03/05/t...t-geneva-2013/
vh_supra26 is offline   Reply With Quote
The Following 2 Users Say Thank You to vh_supra26 For This Useful Post:
BobDigi5060 (03-07-2013), Giccin (03-06-2013)
Old 03-05-2013, 12:05 PM   #2
vh_supra26
Site Moderator
Drives: Supra
Press Release
WORLD DEBUT FOR TOYOTA FT-86 OPEN CONCEPT
KEY POINTS
- Toyota to unveil new FT-86 Open at Geneva motor show
- Concept created to gauge reaction to possible development of a cabriolet version of the GT86 sports coupe
- Soft-top design allows 2+2 seating format to be retained, with minimal impact on boot space
- Unique colour scheme created in Milan to reflect the city's world-leading design status
- Toyota will present its new FT-86 Open concept for the first time at the Geneva motor show, a car created to test the water for the possible introduction of a convertible version of its globally acclaimed GT86 sports coupe.
The concept has been designed to deliver the lively, highly engaging and accessible performance and dynamic abilities of the GT86 with the added appeal of top-down motoring.
Its external dimensions match those of the coupe (length 4,240mm, width 1,750mm, height 1,270mm), with the fixed hard-top replaced by a multi-layered fabric roof with a glass rear screen. Inside it has the same 2+2 seating format, with the roof folding down behind the fixed rear seats, with minimal impact on the space available for luggage.
The show car has a special pure bright white and navy blue colour scheme designed by Toyota Boshoku Milan Design (TBMD) to capture the spirit and atmosphere of Milan, one of the world's leading centres for fashion and design. The bodywork is finished in white, contrasting with the blue of the roof. Inside, the perforated white leather upholstery is layered over a navy blue backing, with golden yellow accent stitching and carpets.
The FT-86 Open uses the same platform and powertrain as the GT86. At its heart is the naturally aspirated, horizontally opposed 1,998cc four cylinder "boxer" engine. Equipped with Toyota's D-4S direct injection technology, this compact unit is set low, helping lower the car's overall centre of gravity, and is capable of producing 100bhp per litre. It drives the rear wheels through a short-throw, six-speed manual gear shift or a six-speed automatic – the latter with the world's fastest paddle shift speed, just two tenths of a second.
As with the production GT86, it features MacPherson strut front and double wishbone rear suspension to give a direct handling feel, instant response and a high level of control. The electric power steering has a quick 13.1:1 ratio that's on a par with racing models, while large ventilated disc brakes fore and aft deliver excellent pedal feel for car control finesse.
Toyota has pinpointed numerous areas that will need further engineering evaluation to assess the impact of the cabriolet design on performance, vehicle rigidity, balance, weight and aerodynamics. However, with features such as frameless doors, the GT86 was designed with the development of a cabriolet in mind, which means the impact on structural rigidity by converting to an open-top design should not be great. Efficient measures to preserve rigidity are being analysed, such as the use of door lock reinforcements.
GT86 has a near-perfect 53:47 front-to-rear weight distribution, helping deliver ideal response to even subtle steering, throttle and brake inputs, and a low, 460mm centre of gravity. While introducing a fabric roof is likely to bring the centre of gravity even lower, further engineering analysis will be needed to match the balance of the coupe.
GT86 tips the scales at only 1257kg, thanks to comprehensive weight-saving measures, giving the car a power-to-weight ratio of around 160bhp per tonne This is crucial to performance, given the car uses an engine with a relatively small capacity. Engineering the cabriolet to be "weight-neutral" relative to the coupe will be a key area of study should Toyota decided to progress with the project.
The Following User Says Thank You to vh_supra26 For This Useful Post:
Giccin (03-06-2013)
Old 03-05-2013, 12:11 PM   #3
vh_supra26
Site Moderator
Drives: Supra
Toyota FT-86 Open Concept Previews Scion FR-S Convertible
Giving us a preview of the Scion FR-S Convertible, Toyota has officially unveiled its FT-86 Open Concept today at the 2013 Geneva Motor Show.
Though plenty of photos of the FT-86 Open Concept were leaked onto the Internet prior to the vehicle’s official debut, the Japanese automaker spilled more details on the four-seater convertible at its debut. Since the GT-86 was built on the premise of delivering high levels of driving excitement, Toyota managed to add just 13 pounds to the convertible model while still delivering a near-perfect 53:47 front-to-rear weight distribution. In fact, the removal of the hard-top roof improves the sports car’s center of gravity.
As of yet, Toyota has not confirmed a convertible version of its new sports car, though considering the hype its getting, and the fanboyism around the coupe, it’s all but certain. After all, Toyota has already officially said the chassis itself was designed to be a convertible from the start.
Old 03-05-2013, 12:42 PM   #4
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Smaller wheels and were good to go.
Old 03-05-2013, 12:53 PM   #5
xxscaxx
Drives: 2013 SWP BRZ
I know the whole point of showing off a convertible is with the top down, but are they ever going to post a damn picture of it with it closed? It might look ok down but usually IMHO convertibles look like complete shit when the top is closed lol
xxscaxx is offline   Reply With Quote
The Following 6 Users Say Thank You to xxscaxx For This Useful Post:
86BRZ (03-07-2013), dori. (03-06-2013), Ingen (03-07-2013), kertong (03-06-2013), Lawnik (03-06-2013), oxygen (03-06-2013)
Old 03-05-2013, 12:54 PM   #6
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Agreed. Those buggy wheels look ridiculous. What is it with manufacturers these days that think bigger wheels makes it better?
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 03-05-2013, 12:59 PM   #7
gymratter
Drives: BMW
i think it looks great with the top down. but with post above, would like to see pics of it with top closed as well.
gymratter is offline   Reply With Quote
Old 03-05-2013, 01:52 PM   #8
Verge
Verge's Avatar
Drives: 2013 Scion FRS
if this becomes a 2 seater w/ hardtop i think my wife will definitely want one lol
Verge is offline   Reply With Quote
Old 03-05-2013, 03:02 PM   #9
DarkSunrise
DarkSunrise's Avatar
Interesting how the white interior gives the car a much more expensive appearance.
2022 BRZ Build
2013 FR-S Build
Old 03-05-2013, 03:19 PM   #10
Retro86
Retro86's Avatar
Drives: Awesome
wheres the top up?
Retro86 is offline   Reply With Quote
Old 03-05-2013, 06:53 PM   #11
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
If it becomes that I will want one. Hahaha
Though I'm still dreaming of a targa
Old 03-05-2013, 07:04 PM   #12
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Convertible version should be a 2 seater. If they kept the boot space and kept the length of the car the same that means its still going to be uncomfortable to ride in. Why not delete the back seat and give it more boot space?
SubaSteve is offline   Reply With Quote
Old 03-06-2013, 09:41 AM   #13
gymratter
Drives: BMW
is the US even getting a convertible FR-S?
Old 03-06-2013, 10:05 AM   #14
vh_supra26
Site Moderator
Drives: Supra
Live Photos With Top Up
The Following 14 Users Say Thank You to vh_supra26 For This Useful Post:
FRSupra (03-06-2013), garf (03-08-2013), Guff (03-06-2013), Hawk77FT (03-06-2013), kertong (03-06-2013), lazyluka (03-06-2013), MannyO (03-06-2013), merlin2111 (03-06-2013), MoarGeesPlease (03-08-2013), ranisron (03-07-2013), Sushi (03-06-2013), tomato86 (03-06-2013), tripjammer (03-08-2013), Zaku (03-06-2013)
FT-86 II Concept Photos from Geneva!! Motherload of photos. Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 496 03-15-2013 12:31 PM
Toyota FT-86 Open Concept (2013) Matt_RSA AFRICA 1 03-01-2013 07:10 AM
Jeep Mighty Fc Concept old greg Other Vehicles & General Automotive Discussions 23 04-03-2012 01:53 PM
Toyota FT-86 II Concept to be unveiled at Geneva!!! yera Scion FR-S / Toyota 86 GT86 General Forum 266 02-20-2011 10:17 PM
FT-86 production version NOT at 2010 Geneva (yet). Photos of FT-86 concept from show. Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 132 03-08-2010 03:40 PM
