Old 03-02-2013, 10:45 PM   #1
zooki
Drives: waiting on a 2021...
Question about BRZ foglights.
First off, I don't own a BRZ, I have an FR-S. I am going to be installing fog lights in my car and was wondering where the relay for the fog lights are on a BRZ. I have the wiring diagram for the BRZ, and it shows a relay for the front fog lights, but where is it physically located? The FR-S has fuses installed in the underdash fuse box for fog lights, and wiring up to the headlight switch, even though the headlight switch has no provision for the foglight switch. I have a Tundra switch which I believe will bolt right in, but am wanting to use as much of the factory wiring as may be there. The fusebox under the hood has no spot for a fog light relay as far as I can tell. Even the BRZ wiring diagram has no spot listed for a front fog light relay. Anybody know where this relay is?
zooki is offline   Reply With Quote
Old 03-04-2013, 11:15 AM   #2
toddj55
I have been curious about this too!
toddj55 is offline   Reply With Quote
Old 03-04-2013, 11:24 AM   #3
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
it could be external like the signal light relay?
Old 03-04-2013, 11:43 AM   #4
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
relay location is on the engine bay but body harness is different from the brz-l you need to make your own to make foglights work
GT86drifter is offline   Reply With Quote
Old 03-04-2013, 09:35 PM   #5
zooki
Can you post a pic of where its at? I have a wiring diagram for a BRZ, and it doesn't show the location anywhere. I just find it interesting that the wiring is there for the headlight switch, and the under dash fuse box has fuses and wiring already there. I installed a Tundra switch today and the fog light indicator comes on in the dash , so there's some wiring there. Just trying to figure out how much.
Does anyone in the US with an FR-S have Foglights??? pituala Cosmetic Modification (Interior/Exterior/Lighting) 42 01-30-2014 11:15 AM
Replaced my OEM foglights with 3000k HIDs Tye300 DIY (Do-It-Yourself) Guides 37 10-10-2013 01:26 AM
GT86 foglights installed but no switch? derka-derka Electronics | Audio | NAV | Infotainment 8 08-16-2013 03:13 PM
Feeler: JDM OEM FRS Foglights & Bezels DC-FRS Exterior Parts (Aero, Lighting, Etc.) 9 01-10-2013 01:49 PM
FOGLIGHTS/HEADLIGHTS on 86, CANBUS or normal? WTF AUSTRALIA 3 06-21-2012 03:55 AM
