Old 02-28-2013, 09:33 AM   #1
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
Tom's Advox Coilovers
http://www.tomsracing.co.jp/news/2013/0206-131812.html
PTKDA No.T130202
13/02/06
Coil Damper Unit "Advox" for 86 (ZN6)
New Release of Information
Since February 2013, our company is pleased to launch the coil damper unit "Advox" for 86 (ZN6) this time.
Thank you we both conventional patronage please guests.
■ coil damper unit "Advox"
Suspension Kit was born from racing technology fee back. Achieve a supple ride and unparalleled maneuverability. Together embody the high ground of the flat ride, we won the lightweight sports suitable for nimble handling.
■ Details
Coil damper unit "Advox": Name
Specifications: Adjustable length, steel case, single tube, twin piston, rubber chamber type
■ Compatibility Chart
Part Name Model grade car model year engine type
Name you would like (48000)
Retail
Price hope
Retail
Price
Reference (without tax)
Mounting
Time
86 ZN6 GT-LIMITED/GT/G/RC
H24 (car MT). 2 ~ FA20 TZN60 Advox ZN6 MT ₯ 294,000 ₯ 280,000 4.0h
H24 (car AT). 2 ~ FA20 TZN61 Advox ZN6 AT ₯ 294,000 ₯ 280,000 4.0h
※ height adjustment range F (ratio of standard vehicle): factory-5mm ~-25mm / height set F (ratio of standard vehicle)::-5mm ~-25mm R-15mm R:-15mm. If you lower the ride height from the time of shipment, please make adjustments in the rules but to the extent possible.
※ Fr insulator, Rr dust cover must be processed quickly.
※ genuine nut on the right, we recommend the exchange of a new one. Front damper rod nut (part number: SU003-00375 x2) / front upper support nuts (Part No.: SU003-03642 [SU003-04500] x6) / Front stabilizer link nut (part number: SU003-02887 [SU003-04506] x2) / Front damper lower nut (part number: SU003-02889 x4) / rear damper rod nut (part number: SU003-00386 x2) / Rear upper support nuts: SU003-02869 [SU003-04505] x4) / rear lower arm nut M12 Part Number (: SU003- 02870 x6) / rear lower arm nut M8 Part Number (: SU003-02883 x2)
★ Please check, please arrange your new part number as described in [] vehicle after July H24 car verification.
※ alignment is required separately.
※ Advox The overhaul is possible. Please check here for more information from the page.
※ Due to the differences in grade, vehicle weight, and vehicle solid difference, change the vehicle height. Minimum ground clearance and set forth in the law, please adhere to the standard height of the lamp type.
Beyer Subaru is offline   Reply With Quote
The Following User Says Thank You to Beyer Subaru For This Useful Post:
schtebie (02-28-2013)
TOM'S 86 parts are available now!! nigel-jdmparts Exterior Parts - The Rest 6 09-14-2012 06:15 AM
M7 JAPAN COILOVERS for SCION FRS SUBARU BRZ, JDM COILOVERS AMPLIFIED MOTORSPORT Brakes, Suspension, Chassis 0 08-16-2012 02:45 AM
Tom's body kit DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 20 08-03-2012 01:31 AM
Wheel Directory: Tom's Racing EP-2 17x7.0 +47 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-29-2012 10:08 AM
Tom's parts announced for 86 Nardi330 Scion FR-S / Toyota 86 GT86 General Forum 36 02-04-2012 05:21 AM
