Old 02-27-2013, 10:02 PM   #1
aceangel
aceangel's Avatar
Drives: 13 BRZ WRB LTD 6AT
Unhappy Unpainted spot on wing
Hi all- I took my 1-month old WRB Limited BRZ to the detailers to get it Opti-Guarded and he found an unpainted spot (primer showing) on the left edge of the wing. It's not very visible unless you look for it. Should I try to get the dealer to fix it or should I just leave it? I don't know how I can prove it came from them. It looks like the error came from the factory, doesn't look at all like a scratch.
I will put a pic up soon.
Angel
aceangel is offline   Reply With Quote
Old 02-28-2013, 12:08 AM   #2
asia_minor
Superleggera
Drives: 2016 Mazda MX-5
you have nothing to lose. go see what the dealer says.
asia_minor is offline   Reply With Quote
The Following User Says Thank You to asia_minor For This Useful Post:
aceangel (03-07-2013)
Old 02-28-2013, 12:17 AM   #3
whaap
whaap's Avatar
It has a warranty. Have them repaint it. If they do a good job, fine. If not, have them replace it with a new one from the factory.
whaap is offline   Reply With Quote
The Following User Says Thank You to whaap For This Useful Post:
Old 02-28-2013, 12:51 AM   #4
Greg Gellas
Greg Gellas's Avatar
Drives: S2000, Acura TSX
Sure its not a burn through from polishing? If its on an edge it could be from improper polishing.
Greg Gellas is offline   Reply With Quote
The Following 3 Users Say Thank You to Greg Gellas For This Useful Post:
aceangel (03-07-2013), LeeMaster (03-01-2013), notFRS (02-28-2013)
Old 03-01-2013, 02:47 PM   #5
djdnz
1337
Drives: 2013 BRZ WRB S/C
I would have guessed from a polisher if I saw that. It's easy to do too, polishing the rear quarter without raising the trunk - I know I've hit that spot while doing mine but thankfully I use a PC7424XP so not a huge risk.
How does the underside of the spoiler look?
djdnz is offline   Reply With Quote
The Following User Says Thank You to djdnz For This Useful Post:
Old 03-01-2013, 03:11 PM   #6
Greg Gellas
Is it smooth to the touch? Meaning is the paint around it higher? If not probably a burn.
The Following User Says Thank You to Greg Gellas For This Useful Post:
Old 03-01-2013, 03:17 PM   #7
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Hmm whether it is a factory blemish or not (by the looks I'm inclined to think paint was originally there and got scraped off after the fact), I would just apply touch up. Repainting could result in other defects (dust flakes, craters) and a non-factory consistency/finish. Plus you have to remove the adhesive then reapply, unbolt/rebolt with potential to overtorque, strip threads, scratch more paint (unlikely but the chance is there). Not to mention the time and effort for the whole process. Plus it's not metal so it's not like it runs a higher risk of rusting. I'd rather keep the defect isolated to that nondescript spot and mask with touch up. I wouldn't let imperfections in that high air flow area bother you. I already have knicks on my trunk in front of the spoiler. If you repaint it may get random knicks anyway.
The Following User Says Thank You to switchlanez For This Useful Post:
Old 03-01-2013, 03:36 PM   #8
aceangel
aceangel's Avatar
Yeah, It does look like it got scraped off. I guess the BRZ paint is softer than I thought. It's going to be hard to prove who did it, so I might just get it touched-up. Thanks. Where can I get touch-up paint? Should I just let a pro do it?
Old 03-01-2013, 03:45 PM   #9
switchlanez
Best quality touch up should be from a Subaru parts department but there are cheaper alternatives out there. You can DIY by cleaning thoroughly to prep (alcohol helps ensure it's free of grease) then apply first coat. After 15 or so minutes apply another coat. Do not apply two coats back to back without letting first coat dry because that can ruin consistency. This is from my memory but instructions should be on the bottle or do a Google search to see how pros would do it. Or just let a pro do it lol
Old 03-05-2013, 11:48 AM   #10
aceangel
aceangel's Avatar
Do you guys think it would look better with a little bit of DrColorChip? I mean, that section is barely noticeable and I just want it filled to prevent more damage to the area. Or is the OEM subiepaint a better idea?
FS: unpainted Five Axis Rear spoiler MF_DEUCE Exterior Parts (Aero, Lighting, Etc.) 4 11-27-2012 12:59 AM
New Parking Spot raul Scion FR-S / Toyota 86 GT86 General Forum 7 09-05-2012 12:42 AM
FS: unpainted Five Axis Rear spoiler MF_DEUCE Southern California 7 09-01-2012 12:16 AM
Wing or no wing? (rear spoiler) quik1987 Scion FR-S / Toyota 86 GT86 General Forum 123 12-12-2011 06:11 PM
