Old 02-23-2013, 07:18 PM   #1
swift996
swift996's Avatar
Is 1mm worth a hub centric ring?
If I read correct, the stock bore is 56.1mm.
I have wheels that have a 57.1mm whole. Is it worth it to buy hub centric rings for the new wheels?
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-24-2013, 03:29 PM   #2
Scott
Drives: 1971 Datsun 510
Basically without the spacer your riding on the lug nuts alone and not on the hub bore the way vehicles were designed. not worth the risk of spending the $20. ask a machinist if 1mm is a lot.
Scott.
Scott is offline   Reply With Quote
Old 02-24-2013, 04:00 PM   #3
D1cker
Drives: B9 S4/ND2
Most aftermarket wheels (read all) are lug centric, and quite a few of them recommend to not use hub rings and they can crack from track use (i.e. enkei)
Just make sure to torque the wheels while the car is on the ground.
D1cker is offline   Reply With Quote
Old 02-24-2013, 04:07 PM   #4
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Should be fine without i don't even know if anybody makes any that thin.
JoeBoxer is offline   Reply With Quote
The Following User Says Thank You to JoeBoxer For This Useful Post:
cruzinbill (02-24-2013)
Old 02-24-2013, 04:40 PM   #5
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
You're fine. That's only .5 MM difference edge to edge.
Old 02-24-2013, 05:06 PM   #6
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
it doesnt matter if its 57,58 or 59. its not 56.1 so its not 'fitting', so youre no longer hubcentric
Huehuecoyotl is offline   Reply With Quote
Old 02-24-2013, 05:29 PM   #7
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
You'll be fine for street or track duty without hubcentric rings. I highly doubt you could find any that thin anyways, and even if you could, they would be so fragile, they wouldn't last long at all.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
The Following User Says Thank You to Miniata For This Useful Post:
JoeBoxer (02-24-2013)
Old 02-24-2013, 05:57 PM   #8
ayau
Drives: Some rust bucket
Scott.
Wheels don't ride on hub bore even if it's hub centric. Do you think those flimsly plastic rings can actually support the physical abuse?
A properly torqued lug nut will provide enough clamping force between the wheel and the wheel hub.
If you track your car, it's often not recommended to use rings because they can melt/crack. Properly install your wheels in a star pattern and torque them to the proper specs and you won't have any issues.
More info can be found in this thread.
http://www.ft86club.com/forums/showthread.php?p=639898
The Following 2 Users Say Thank You to ayau For This Useful Post:
D1cker (02-25-2013), markitect (02-25-2013)
Old 02-24-2013, 06:37 PM   #9
Scott
After a little research of my own it seems your right, apologies for misinforming anyone.
Scott.
Old 02-25-2013, 08:49 AM   #10
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Originally Posted by xomp View Post
you are wrong
You are an idiot.
(I won't provide any supporting evidence either.)
Chewie4299 is offline   Reply With Quote
The Following User Says Thank You to Chewie4299 For This Useful Post:
chuy21 (02-25-2013)
Old 02-27-2013, 03:43 PM   #11
seeclass
Drives: WRX
You don't need hub rings if the wheels have a conical seat, making it lug centric. If you properly torque your lug nuts, the weight of the car sits evenly on all 5 studs/nuts. Many, many cars run without hub rings. Most Rays wheels come with either a 73.1 or 65.1 center bore and a lot of people don't use hub rings. On European cars you NEED hub rings because they don't use lug nuts, they use lug bolts.
Since it's only a .5mm difference get some electrical tape and wrap it around the hub a couple time. I did this to fix some vibration issues I had with some wheels meant for a VW ( 57.1 cb) since they use ball seat lug nuts.
seeclass is offline   Reply With Quote
Old 02-27-2013, 04:28 PM   #12
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
ive been tracking my s2000 for years without hub centric rings and never had an issue. Not to say you absolutely, positively don't need them, but I'm not going to say you are going to do a lot of harm to the vehicle or yourself if you don't use them.
GTM_Challenge is offline   Reply With Quote
Old 02-28-2013, 04:00 PM   #13
funbeatsfast
funbeatsfast's Avatar
Drives: '13 FR-S
It may go without saying, but I'll say it anyways. Don't just torque to spec, but torque in the appropriate order.
http://autorepair.about.com/od/quick...ight_order.htm
funbeatsfast is offline   Reply With Quote
FS: Brand New Centric Premium Rotors Texas BRZ Brakes, Suspension, Chassis 6 07-21-2013 11:57 PM
SSR Type C RS hub centric rings Justkiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 02-14-2013 09:34 PM
FS: Hub centric rings 63 > 56.1 mm JDMSushi Australia Classifieds 3 02-09-2013 09:52 PM
Size of Centric Hub Ring wheel? Akired86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-08-2012 12:19 AM
