Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 02-19-2013, 09:41 PM   #1
chaotichoax
chaotichoax's Avatar
Drives: 2013 SWP BRZ
BRZ/FR-S Getaway Car
Yup...
http://www.app.com/article/20130219/...ll-Wawa-worker
chaotichoax is offline   Reply With Quote
Old 02-19-2013, 09:43 PM   #2
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
The robber was described as a thin, white male, who was about 5 feet 9 inches tall, and had facial stubble and curly, dark brown hair. He wore a black zip-up hoodie and blue jeans.
That sounds just like me.
Fuck.
Guess i'll never stop at a Wawa.
Old 02-19-2013, 10:23 PM   #3
chaotichoax
I frequent this Wawa a lot so I am friendly with a few employees. One gas attendant ran over to me today and asked me if I knew anyone with a black one, then he told me why he asked. Crazy nonsense. Shouldn't be too hard to find.
Old 02-20-2013, 12:01 AM   #4
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
ONLY problem:
When the 21-year-old worker handed over the money, the thief fled in a car, believed to be black or purple Subaru BRZ or a Scion FR-S.
unless it got repainted or wrapped or something
dori. is offline   Reply With Quote
Old 02-20-2013, 12:11 AM   #5
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
Could've been an asphalt as well as the crazy amount of metallic flake could make it appear somewhere between purple and black... now that i mention that i should probably stay clear of Howell until they catch that guy
abutterman is offline   Reply With Quote
Old 02-20-2013, 12:17 AM   #6
was385
Drives: MT WRB BRZ Limited, 2007 911s
The stupidity of using this uncommon of a car in committing a crime... it's mind-blowing. I'm guessing a partial plate and the description shouldn't make this guy too hard to find.
was385 is offline   Reply With Quote
Old 02-20-2013, 08:57 AM   #7
Originally Posted by was385 View Post
The stupidity of using this uncommon of a car in committing a crime... it's mind-blowing....
Or it could be pure genius since the 86 apparently has some sort of stealth technology built into it. I have only seen 1 other on the road in Atlanta since I got mine in May....
Laika (02-21-2013)
Old 02-20-2013, 09:33 AM   #8
xDBOYx
xDBOYx's Avatar
Drives: 2013 SWP BRZ Limited
Wow. Why would someone use a 200hp car as a getaway car Lol. Good luck getting away from a trooper
xDBOYx is offline   Reply With Quote
Old 02-20-2013, 09:45 AM   #9
was385
Ehh, that's not an issue. Remember, it's not about outrunning the cars behind you, it's about outrunning a radio signal.
Old 02-20-2013, 11:02 AM   #10
gily25
Drives: Silica BRZ 6MT
Holding up a Wawa? It was probably a Genesis coupe lol.
gily25 is offline   Reply With Quote
Old 02-20-2013, 11:29 AM   #11
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
My coworker calls my WRB wrx purple all the time. I'm guessing it was a WRB BRZ, in which case the guy should be pretty easy to find. I actually got pulled over in my wrx once by like 8 cop cars because someone had just robbed a bank in a blue sedan and they thought it was me.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 02-20-2013, 03:06 PM   #12
xDBOYx
xDBOYx's Avatar
Which will not be an easy task in a 200hp car. Gotta lose the car behind you. Then outsmart the radio or helicopters if it gets to that extreme.
Nj turnpike & parkway is all straight wih very few slight turns so u can't use the 86 handling attribute to its advantage.
Old 02-20-2013, 03:15 PM   #13
Which will not be an easy task in a 200hp car. Gotta lose the car behind you. Then outsmart the radio or helicopters if it gets to that extreme...
I see a future episode of Top Gear in the making here....
was385 (02-21-2013)
Old 02-20-2013, 04:45 PM   #14
sbxjap
sbxjap's Avatar
Drives: '95 Honda Civic HB/'13 Subaru BRZ
in one of the most uncommon cars ever....
should've used a Civic or a Corolla....
sbxjap is offline   Reply With Quote
