Drives: Subaru BRZ
Suspension stiffening up?
I've noticed that the suspension in my BRZ has seemed slightly stiffer in the past month, with increased harshness over poor pavement. Some of my regular passengers have noticed this as well, and I'm wondering if this can be attributed to tires being firmer in the winter or just roads getting worse this time of year. I don't think I've blown a damper or anything, but it is a possibility. Has anyone had any issues with the BRZ's suspension bits?
Drives: asphalt FR-S
It's probably the roads. A few freeze/thaw cycles really do a number on them. You don't really notice it until you get a car with a stiff suspension. It gets even worse in the spring as the roads thaw out.
Drives: Subaru BRZ
That's the answer I was looking for, being in New England doesn't help either.
Drives: whiteout FRS
your suspension is also fluid damped.. colder means thicker fluid.. most cars feel a little stiffer when cold. Tires are also less compliant when cold (unless you're running winters) .. roads too.. but that's already been covered.
Hot Dog
Drives: quicker than arghx7
It's also possible the dampers are stiffer. Some damper oils thicken in viscosity at lower temperatures, causing greater damping force and a harsher ride quality.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
Drives: Silver AT Limited
I get stiff when its cold hrhrhr...
Drives: '15 WRX '13 Legacy '07 Colorado
My drive to work really has it's uncomfortable moments. But the roads in my town are more pothole than pavement.
Drives: BRZ DGM Limited
Check your tire pressure..I notice that at 39 just too too harsh a ride. 34 better. 32 seems just right even when cold out and on poor roads. (32 is below the recommended 35 tire pressure however)
| The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
| KW suspension | jdzumwalt | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 02-13-2013 12:38 AM |
| Need some suspension help | JoeBoxer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 24 | 01-19-2013 03:02 PM |
| OEM suspension FR-S | Vonsamhain | Brakes, Suspension, Chassis | 0 | 11-27-2012 12:42 AM |
| Suspension | Toyobaru808 | Hawaii | 14 | 10-17-2012 11:46 PM |
