| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
#1 | |
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
I figure some here might enjoy my AE86 build (A lot of pics)
As suggested by someone in another thread, since people here seem to enjoy the AE86, I might as well show what it takes to keep a 25 year old car in Canada! I did significantly less work on the car in 2011 as I'd liked to, basically just out of pure laziness, and because I was enjoying/modifying my new IS250, but I hope to get some work done this winter.
Important: I've pieced this thread together from various posts I've made in various forums over the years, so it might not be as cohesive as I'd like, but just look at the pretty pictures! I just started posting here, so not a lot of people know me yet, but I thought I'd post my AE86 up for now. Maybe I'll post some Supra stuff in a while . Here it goes...I bought the car from my uncle who owned it since new, he bought it in April 1986 from Stampede Toyota (where I now work in parts), from Todd Brown (who was the General Manager up until around 2008 I think). I paid $1800 for the car, and drove it for 2005. I don't have pictures of everything, and it's all random, but it's worth taking a look through I think anyways . I don't have my custom "stock" exhaust (stock exhaust with the piping replaced with mandrel bent and with a flex section -- will be ceramic coated). Or things like my new OEM fenders, replacement rust-free AE86 JDM Levin doors (no side impact beam), etc.Enjoy! I'll start from the beginning. The day the car came home from the dealership, May 2, 1986: ![]() Couple more pics from the late 80's/early 90's: ![]() ![]() ![]() Car had hail damage in around 1991'ish. Was repainted locally: ![]() After the repaint they put the door decals back on in the wrong spot at the front of the door. :![]() MAD nostalgic picture of myself and my uncle in 1992 (I was 6 years old in this photo): ![]() Now, onto my ownership of the car, these are the "before" shots. These are from 2004, when the car had 122,000 miles. ![]() ![]() ![]() I cleaned it up real nice during 2005, but the rust still got worse during that one half winter I drove it (04-05). I took it off the road at the end of 05, looking like this: ![]() ![]() ![]() ![]() I stripped the car down to begin rebuilding it, after the strip down, it looked something like this: ![]() ![]() ![]() ![]() ![]() ![]() I worked on it for a bit, doing some repair here and there, the bug for ordering brand new EVERYTHING was in the works at this point. ![]() ![]() ![]() Now it was time to start ordering more and more and more and more parts. Eventually leading to myself getting a job at Toyota, getting a mad discount, and ordering more and more and more parts. My TRD header: ![]() ![]() My new side trim: ![]() Next, my new trunk trim, upper windshield trim, new wipers (500mm and 425mm), and my new rad shroud, and don't forget that sweet 4A-GE sticker: ![]() ![]() My Japanese OEM toolkit, all of these parts came standard on Japanese AE86's (except the flashlight (Celsior) and the pressure gauge (Celica)): ![]() ![]() ![]() ![]() ![]() From DoriKaze.com: Quote:
![]() I also added power windows, which was a process as well... ![]() ![]() ![]() ![]() ![]() ![]() ![]() I've also added a complete JZA80 stereo/amp setup to the car: ![]() ![]() Someone shown in the last post was the new shift boot I got, which was for an MA61 Supra, I modified my shifter to fit it correctly as well. ![]() ![]() ![]() I also ordered a factory exhaust tip: ![]() I've also added the Japanese variable intermittant wiper switch: ![]() ![]() ![]() ![]() ![]() ![]() Random new stuff (horn button, brakes, etc): ![]() New decals for the car: ![]() New wheel centre caps: ![]() I also decided I needed to be a bit more JDM... (Yes that is new door plastic -- the stuff that goes between the door panel and the door frame): ![]() ![]() ![]() Now... onto that pesky rust... ![]() ![]() ![]() Onto those quarter panels... I was told over and over again, no new quarter panels. I wouldn't take no for an answer! ![]() Outer wheel housings: ![]() Quarter panels: ![]() ![]() ![]() This is worth posting: ![]() Yes... I also added cruise control: ![]() Knowing that I am the OEM guy that I am, doing some of these things was difficult for me. I've tried to stay as OEM as possible, doing things as I think Toyota would (albeit without the research dollars and casting abilities, lol). Everything on the car is either Toyota OE, TRD, or custom made to make things work. Engine is an smallport MAP-DLI type 4A-GZE from a 90-91 AE92 GT-Z (has the nice oil drain hose and the piston squirters with the coated pistons). Came with a transmission and all the engine accessories on it, but no harness, ECU, igniter, SC relay or VSV's. Bought it here in town from someone who was going to swap it into their AE86, but decided to go KA24 (I think) instead. Came with coils, MAP sensor, injectors, and all that good stuff, but not some of the stuff I really needed. Lucked into finding a harness on eBay that came with the ECU, igniter, VSV's, relays, resistors, everything. Beautiful! Got it shipped here. Pulled apart the 4A-GZE, found some rust inside cylinder #1, not excessive, but it was clear that the engine had been sitting for a long period of time! Ordered myself a new set of piston rings for the smallport, and a gasket set for an AW11 4A-GZE, plus an intake manifold gasket for the smallport 4A-GE. I honed the cylinders to clean them out and get some nice crosshatching back. Cleaned the head up and changed all the valve seals. I'm using the RWD water pump front half with the FWD rear half. This gives me the extra strength of the larger bearing in the RWD water pump to use the clutch fan, as well as the appropriate rear housing to clear the SC12 supercharger. I will be keeping all accessories on this engine, the car will be modified to accept the complete GZE assembly with A/C and Power Steering. Chances are I will need to lower the front sway bar and perhaps change the end links, we'll cross that bridge when I can lower the engine into the car and check clearances. Cruise control will also be functional as well. On to the pictures. Original largeport T-VIS 4A-GE removed: Started cleaning up the engine bay (more cleaning/painting to come): ![]() And it begins: ![]() Getting the longblock assembled, with RWD water pump, and the cams from my original largeport 4A-GE: Clutch/fan test installed just to make sure everything was fitting, other stuff needs to be installed first obviously: Test fitting the 2JZ VVT-i ignition coils in the 4A-G head. The fit is fantastic, still need to make some holding brackets for them, but it will come: ![]() Test fitting the spark plug wires to the ignition coils, to make sure it's all kosher: ![]() The valve covers will be powder coated silver and repainted with the stock bluetop colours. I much prefer this look to any other (including my own black valve covers). The ones on the engine in these pics are in rough shape, but give me an idea of how it will look. I love it: ![]() Ordered myself a new smallport 4A-GE spark plug wire cover. It fits with quite a bit of room over top of the coils and wires I've installed: ![]() In this shot you can see the TRD header, which was installed to get positioning for the O2 sensor on the wiring harness. Also apparent is the vacuum valve on top of the power steering pump. On the AE86 this valve is mounted on the power steering pump itself, on the AE92, it is mounted on the steering rack. While using the AE92 PS pump with an AE86 rack, I had nowhere to mount the valve, so I ordered a banjo bolt for the power steering pressure line on a 1MZ-FE. It allows me to mount the valve on the top of the PS pump, retaining factory idle-up on the 4A-GZE. It later turned out that this probably wouldn't work, as the lines won't quite reach. I have since ordered the 1JZ-GTE factory setup from Japan. Don't have any pics of it right now though. :![]() Coolant piping modified to mount the remote thermostat housing on the side of the engine. In the AE92, this housing sits on top of the transmission. That won't work for a RWD mounting setup. In this first picture, you can see the two pipes bolted to the water pump and water neck, they used to extend to the back of the block: ![]() Holding the thermostat housing in place you can see where it will sit. The heater core pipe was modified so that stock AE86 heater hoses can be used without modification. I had new ones installed a while back, there was no way I wasn't using them, haha: ![]() You can see in this picture the nice welding my brother did to get these pipes to fit properly. Mad props :![]() Hoses in place on the piping going to the heater core and the ISV (idle speed valve). Need to make sure everything works like from the factory :![]() Now came the (what I thought was going to be) hard part: modifying the wiring harness to fit the AE86. I expected to spend at least a couple of weeks on this, however when actually diving into it, I realized it would probably be easier than I thought. Spent a couple nights mapping the connectors on the AE86 harness and removing extra connectors from the GZE harness (battery terminal, alternator wiring, etc). I came up with this abortion as the staring point for the GZE harness: ![]() Positioning things on the engine and so on, I organized the new harness into this: ![]() Finally, I loomed everything up and extended a couple wires going to the starter and body harness power source near the battery: ![]() For suspension, I've gone with TRD Japan sport springs, shocks, struts, front sway bar, and the complete bushing set. I have only installed the front sway bar so far, but will be installing the rest soon. ![]() ![]() ![]() For the rear end, I've gone with a TRD 2-way Limited Slip Differential, as well as a TRD solid pinion spacer. I am keeping cruise control, so I needed to find a throttle cable that would work for that (from the cruise bracket to the throttle body - stock AE86 is too long). I found that the SV21 and VZV21 cables seem to work not too badly. The SV21 is about 28-inches or so, while the VZV21 is about 29-30'ish. I grabbed the VZV21 one, but I think the SV21 would be fine as well. ![]() ![]() ![]() ![]() ![]() Photo from Japan of wheels I ordered: ![]() New outside door handles (already replaced the inners and all the foam, etc.): ![]() Headlight "eyebrows" and buckets/retainer rings: ![]() Door, trunk and rear window weatherstripping: ![]() Some of my new suspension parts: ![]() New OEM windshield: ![]() ![]() Installed my TRD shocks, struts and springs, along with the TRD sway bars (front and rear) and the new end links and TRD end link bushings. Also installed my new Goodridge stainless brake lines with some ATE Super Blue Racing DOT4 brake fluid. Sorry for the crappy pics: ![]() ![]() Crappy cell phone photo of the wheels installed on the car. Sorry for the poor quality, though it actually hides all the rust still on the quarter so it looks not too bad, haha. ![]() Got my windshield adhesive set in from Japan. After various experiences I no longer really trust anyone to install windshields, so I'm going to be doing it myself. Kit comes with piano wire, body and glass primer as well as the adhesive. I've got a pair of suction cups on order to help install the glass. ![]() ![]() It's really the only way I can ensure my factory glass gets installed the factory way using OE adhesive. I don't want a ton of extra urethane stuck all over my mouldings, or the clips not positioned correctly, etc, etc, etc, whatever else glass guys like to screw up. Jeff
![]() 2011 Lexus IS350 F-Sport 6MT with LSD 1986 Toyota Corolla GT-S Supercharged Last edited by Jeff Lange; 04-21-2016 at 12:48 AM. |
soon . . .
![]() 2011 Lexus IS350 F-Sport 6MT with LSD 1986 Toyota Corolla GT-S Supercharged |
Now w/ over 400 womprats!
Drives: BRZ LZR
This is awesome!!!
Def. the best Hachiroku build i've seen! I love how you are sticking to original stuff!!
- The Ancient BRZ Sacrament by Zaku |
Drives: FRS :D
wow this is a awesome build and i cant wait to follow your progress with it
i enjoy your oem as possible theme
Out of the FRS game
Hook 'em
This thread is awesome! Looking forward to the rest of it!
You're not the only one. I've been having ignition issues with the 4A-GZE though, which have plagued me for the better part of this year. If I could just get it running well, I think everything would fall into place.
Jeff
Cool story!
1987 Corolla AE82 4AGTE - Sold
1988 Starlet EP71 4EFTE - Current 2008 Ford Fiesta ST150 - Current 2010 Peugeot RCZ - Current Visit: http://www.4agte.nl |
Drives: Tacoma
i love how you put in some clasic pics in there... but nice
Wiring Nerd
Drives: 1994 Supra
awesome build. The lack of new OE parts is what keeps me away from restoring one of these. I'm an OEM freak when it comes to trims, etc.
#10 |
Troll Feeder
Drives: boosted scion tc.
looks great man. in for updates. lovin this car man.
#11 |
Drives: IS300
Loving the full oem restoration!
also, coupe ftw! |
#12 |
Drives: 1998 Subaru
Thats awesome that the car has been in the family since new. I'm hoping thats what my soon to be mine BRZ will be.
#13 |
Gundam Meister
Drives: A Gundam
I agree. This is very awesome. I'm also in for more updates.
#14 |
Drives: None Yet
http://en.wikipedia.org/wiki/AE86
Damn you have a good history with that car! Guess what, your car was so clean someone put a picture of your car to represent the AE86 on Wikipedia! At first, I thought, "Have I seen this car somewhere? Oh yeah, it was on Wikipedia, wasn't it?" You should be proud, your car's famous. ![]() This build is AWESOME, it's very long and detailed. Keep it up! ![]() |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 09:59 PM |
| Anyone AE86 owners here? Can FT86 improve on AE86? | Kenji | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 05-17-2014 02:52 PM |
| Top Gear Online Subaru BRZ review - if you enjoy driving, this is the car for you | Hachiroku | BRZ First-Gen (2012+) — General Topics | 54 | 12-13-2011 06:32 PM |
| Engine build | Maxim | Engine, Exhaust, Transmission | 41 | 10-03-2011 09:22 PM |
| What else do you think Toyota can build on the FT86 Plaform? | Matador | Other Vehicles & General Automotive Discussions | 36 | 02-17-2010 08:55 PM |
