Old 02-06-2013, 04:39 AM   #1
Frsexxxy
Drives: White Virgin frs
So what is e85
And what do tunes do? Do you have to change the gas your using? Is it worth it? Bad for engine? And will it get me laid? I also order an srt header back. Will it work fine w/ it? How do you resset ecu? Is there a how to install e85 vid? Please help I'm a very stupid chill person
Frsexxxy is offline   Reply With Quote
Old 02-06-2013, 08:18 AM   #2
Opposed
Drives: 2013 Asphalt FR-S
Start educating yourself in this thread.http://www.ft86club.com/forums/showthread.php?t=13307 A lot of pages I know, but there is a lot of tuning info.
You can tune on regular gas and expect gains of 10-20 whp
E-85 tunes are seeing 30+ whp gains (but less MPG) Requires special tune and switching fuels
Is it worth it? Of course, I will never go back to stock tune.
Better low end torque, better top end power, torque dip is minimalized, better throttle response, smoother idle (fixes idle dip) Other special features can include launch control, flat foot shifiting ect...
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 02-06-2013, 08:34 AM   #3
xjohnx
Grip>Slip
xjohnx's Avatar
E85 is a different kind of fuel for your car. It is 85% ethanol and 15% gasoline. It will provide big gains in power (but only when accompanied with a tune, you can buy a tune from any number of tuners, @Visconti and @FA20Club.com are two that I use and would recommend.).
There are downsides though, in cold weather when the car has been sitting for 5-6 hours it can be difficult to start the car.
edit: fixed brainfart.
Old 02-06-2013, 08:35 AM   #4
_F-R-S_
Drives: 13 whiteout scion frs
Christmas noob. Lol jk
_F-R-S_ is offline   Reply With Quote
Old 02-06-2013, 10:07 AM   #5
Allch Chcar
Drives: N/A
You might start with the wikipedia entry for E85.
[ame="http://en.wikipedia.org/wiki/E85"]E85 - Wikipedia, the free encyclopedia[/ame]
Hey, we were all new once.
Originally Posted by xjohnx View Post
E85 is a different kind of fuel for your car. It is 85% ethanol and 15% alcohol. It will provide big gains in power (but only when accompanied with a tune, you can buy a tune from any number of tuners, @Visconti and @FA20Club.com are two that I use and would recommend.).
Uh, minor correction. E85 is up to 85% Ethanol(98% Ethanol with a denaturant) and 15% low octane Gasoline. The blend changes with the seasons in your area. For example, "winter" blend is 70% Ethanol, 30% Gasoline. There's even a schedule for when they change depending on region.
Cold starting is not as good as Gasoline but it depends on the tune with E85. If you live in a really cold climate, you could use a block heater or just add some more gasoline to the blend.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 02-06-2013, 10:20 AM   #6
xjohnx
Grip>Slip
xjohnx's Avatar
err, i meant to type gas, no clue why i typed alcohol. sorry about that.
Old 03-08-2013, 05:10 PM   #7
husker741
Do we need new injectors or any additional internals to run e85, other than a tune? Say when the unichip comes out with an e85 map, will I need to add parts to the car or will the tune map take care of everything? Although I'm a Cornhusker fan, I know nothing about this corn gas shit
husker741 is offline   Reply With Quote
Old 03-08-2013, 05:26 PM   #8
wheelhaus
wheelhaus's Avatar
Not necessarily, but possibly yes if your tune/upgrades require significantly more fuel than the stock injectors can deliver. Research E85 threads for exactly what prople have had to do at different tuning stages/goals. E85 is higher octane so it's easier to tune more aggressively, but it requires a richer ratio to air, so it requires more fuel delivery.
wheelhaus is offline   Reply With Quote
Old 03-08-2013, 06:02 PM   #9
Xdragonxb0i
Drives: ex500r
On the frs / brz application. I believe you can use e85. Without any modification. You just have to get a tune. Make sure e85. Is available on your area as well. The only downside is less fuel economy and limited supplier
Xdragonxb0i is offline   Reply With Quote
Old 03-08-2013, 08:18 PM   #10
Opposed
You can run E85 on the stock fuel system if you stay N/A. You only need to upgrade injectors if you go force induction and want to run E85.
Old 03-08-2013, 08:51 PM   #11
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
I was always wondering, what happens if you travel (take road trips) and cant find a supplier? Are you just fucked?
Old 03-08-2013, 08:54 PM   #12
nickmaster
me
e85 = $3.09 (iowa) = whp gain = ftw
nickmaster is offline   Reply With Quote
Old 03-08-2013, 09:35 PM   #13
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
With Ecutek and two maps, one for pump and one for e85, you can utilize map switching to switch back to a pump map once you are almost completely dry on e85 (and vice versa). Flex fuel sensor, harness, map (again Ecutek) makes this much easier by eliminating map switching altogether (although you can still implement map switching for other uses/features). It will dynamically adjust based on ethanol content (as seen by the sensor). In other words, with ff you can mix and match pump and e85 as you see fit.
tech4pdx is offline   Reply With Quote
Old 03-08-2013, 09:40 PM   #14
tech4pdx
Make love
tech4pdx's Avatar
Not necessarily on the injector part. Upgraded injectors become a requirement once your boost levels reach a certain point. E85 is certainly possible with low/moderate boost and stock injectors.
e85, ecutek, exhaust, srt, tune
