Old 02-04-2013, 10:14 PM   #1
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
Paint quality
So when i was getting my fr-s opticoated, a meter was used to check the thickness of the paint at various points. At some points it was in the 130-150 range which seems normal but it was pointed out that the front end of the hood into the front bumper went as low as 80 microns. The car had never been polished or compounded or anything before this. Has anyone else checked theirs out?
abutterman is offline   Reply With Quote
Old 02-05-2013, 12:14 AM   #2
Jlin
Drives: FRS
subarus and most japanese cars are known for thin paint. I've had several rock chips on the hood, fender and front bumper not counting the pitting that's been happening when stones are hitting the bumper.
Get a clear bra if you can afford it.
Jlin is offline   Reply With Quote
Old 02-07-2013, 12:33 PM   #3
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
either get paint protection film or repaint later.
since my friend owns bodyshop, i am just gonna get repaint later.
Old 02-09-2013, 04:18 PM   #4
NOHOME
Drives: RAVEN
Out of curiosity: What is your line of reasoning that equates the 80 microns (3 thouandths of an inch) with poor quality? As long as the clearcoat is UV resistant enough to last the journey, you are good to go.
If the paint is going to be chipped by a rock. I can't see where another 3 thou is going to make any difference.
NOHOME is offline   Reply With Quote
Old 02-09-2013, 07:28 PM   #5
fistpoint
Drives: Supercharged Golf Cart
Tell that to a mosquito hitting your bumper at 100+mph(combined speed).
fistpoint is offline   Reply With Quote
Old 02-09-2013, 10:30 PM   #6
alan.chalkley
Drives: 4wd zooks
LOL - worried about mosquito + car = friendly meet?
Here down under we worry about kangaroo + car = friendly meet.
alan.chalkley is offline   Reply With Quote
The Following User Says Thank You to alan.chalkley For This Useful Post:
russv (02-10-2013)
Old 02-09-2013, 10:44 PM   #7
abutterman
abutterman's Avatar
I was actually thinking the massive difference in thickness might be contributing to the noticeable difference in color in the bumper. When it was completely clean under the lights, it was easily seen that the paint fades into a much lighter shade towards the front of the hood into the bumper where the paint is thinner
Old 02-09-2013, 11:44 PM   #8
Wasabi
おい、だいじょうぶ?
Wasabi's Avatar
Drives: BRZ Limited 6 Speed
one of the most common problems, especially with Subaru, has terrible paint. I'm definitely investing in a clear bra.
Wasabi is offline   Reply With Quote
Old 02-10-2013, 10:56 AM   #9
NOHOME
Drives: RAVEN
Then you DO have a paint issue that may or may not be related to total paint thickness. Recall that the car has a color coat and a base coat. The color coat might be too thin. With al the other teething issues the Twins have, I would not be surprised if the paint robots are still learning their trade.
Does the dealer see the issue when you bring it up to them?
Old 02-10-2013, 12:11 PM   #10
abutterman
abutterman's Avatar
I'm going to point it out when i schedule it for service. That along with the damn window squeaking and freezing When it was in for detailing/opticoat, he pointed out how much different the front end looked as well as the side fender pieces (where the 86 pistons are) and how scattered the thickness of the paint was. He tried to avoid doing too much work on the front end just in case the clear was at a critical point. When i bring it in for service, i'm going to make sure it's nice and lean and make them look at it in direct lighting, whether it's out in the sun or whatever and see if they'll do anything about it.
Old 02-10-2013, 09:46 PM   #11
fistpoint
Alan, I was pointing out that a rock(or a Kangaroo) would still mess up your front end regardless of paint thickness. But insects and sand and other tiny objects most likely will penetrate thin paint at half the thickness of the other areas whereas it most likely wouldn't cause damage if it were the proper thickness.
Old 02-13-2013, 01:16 AM   #12
Gavin Albright
Drives: Scion FRS Whiteout
the Paint thickness testers are sketchey at best. I have ran countless Gage R&R tests on every tester I can get my hands on and my conclusion is thickness testers cannot be trusted. If you truly want to know the thickness of the paint you have to cut a cross section and measure it under a microscope.
That being said I have been able to find a paint defect on the front right portion of my hood. It can only be seen if the light is perfect. It looks like small dents in the clear coat. The dealiership has commited to paint it, i am just not sure when
Gavin Albright is offline   Reply With Quote
Old 02-19-2013, 09:28 AM   #13
gily25
Drives: Silica BRZ 6MT
I'm not surprised by the thickness of the paint...it's a Japanese car...people always talk about how they're so much more economical to buy yet never consider where the money is saved. It's especially true of Asian cars but recently American car companies have started to do it too to meet MPG standards...they pay engineers to look at things like door handles to literallly redesign them as cheap and flimsy as possible but still meet the functional needs. When people go to test drive a car they're careful (they don't own it and don't want to be billed for the car) sure maybe they give it a little gas to test accelartion/braking/shifting but they don't yank on the door handles, slam the trunk and doors, shake the seats, lean on the center console, etc. etc. I like to do all that BEFORE I test the drivability...because if pieces are going to fall off/break you can have the most economical engine but it's still a POS. By comparison to the Focus and Genesis our car is fairly well built. *2 cents*
gily25 is offline   Reply With Quote
Old 02-19-2013, 10:36 AM   #14
whaap
whaap's Avatar
I get a chuckle out of the "poor paint talk" on our cars. I'm approaching 7000 mile and I have yet to get a single blimish on the front of my car. My 02' Miata had 38000 miles when I traded it in and the front in looked like it had been thru a sand-blaster. (Perhaps a slight exageration!)
whaap is offline   Reply With Quote
Paint Correction, Opti-Coating, Car Wraps, Paint Protection & Tinting - LI Detailers LI Detailers Cleaning and Detailing 1 12-27-2012 04:12 PM
Another opticoat thread, and the quality of unmolested paint rusty959 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 08-12-2012 01:41 PM
2006 Acura TL Minor Paint Correction ( volume vs quality ) OTD Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 07-06-2012 06:23 PM
Subaru paint quality speed-wiz BRZ First-Gen (2012+) — General Topics 61 04-02-2012 05:56 PM
