Old 01-31-2013, 12:52 PM   #1
FR-Z STI
XXR 962s on FR-S
I have a question, I am thinking about buying XXR 962 rims. Im thinking about also doing it in a staggered set up and dont know too much about doing it. If I bought 17x7 fronts and 17x9 rear are we supposed to use the same tire size all four corners? Because my OEM tires are brand new and seems pointless to waste fresh tires, any idea if its okay/safe to stretch those on all four corners? A bit far fetched from 7" to 9" stretch but any advice is greatly appreciated.
Please no flaming
Thanks
Also anyone else running these rims please post pics please.
FR-Z STI is offline   Reply With Quote
Old 01-31-2013, 01:09 PM   #2
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Too much stagger. Not sure on available sizes, but I'd keep it to 17x8 and 17x9.
If you want to stick with your OEM tires, then go 17x8 on all four corners. The point of going staggered (other than cosmetic) is to fit more tire on the back.
Slick is offline   Reply With Quote
Old 01-31-2013, 01:45 PM   #3
FR-Z STI
Would running the OEM 215/45/17s be alright to fit on XXR 527s in these sizes:
Front: 17x8.25 +35 and Rear: 17x9.75 +25
If im running +25 in the rear im assuming im going to need camber bolts correct? I will also be running on Fortune Auto 500 Coilovers.
Old 01-31-2013, 05:09 PM   #4
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
yeah, you'll need to camber the rear @ 9.75 width and 25 offset
furthermore, the stretch on that size (stock 215) is ridiculous. If you really want that width it's best to go with another tire. 235 tire width minimum
edit: shit when I think about it, even 255 is pushing it
dori. is offline   Reply With Quote
Old 01-31-2013, 06:23 PM   #5
FR-Z STI
What about 17x7 all corners at 35mm offset. Would camber arms/bolts be necessary?
