Old 01-24-2013, 02:50 PM   #1
J-Money
J-Money's Avatar
Drives: GT-86
Transmission Oil Filler tool?
For instance if you get under the car to change transmision oil what the assembly called where you screw it on or whatever and it has a hose and you can squirt it into the hole to fill it? and guesses? i need one asap
J-Money is offline   Reply With Quote
Old 01-24-2013, 03:09 PM   #2
M1K3
M1K3's Avatar
Drives: vrooom...
Do you mean one of these: Oil Fluid Pump
M1K3 is offline   Reply With Quote
Old 01-24-2013, 03:15 PM   #3
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
I used one of these. http://www.gemplers.com/product/1562...0130124201515s
FRSFirestorm is offline   Reply With Quote
Old 01-24-2013, 03:16 PM   #4
ahausheer
Re-member
Drives: Toyota camry
^- That. Or get a length of tubing, stick it in the fill hole and snake it to the top of the engine and fill/pump from there.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 01-25-2013, 12:48 PM   #5
J-Money
J-Money's Avatar
Drives: GT-86
Yes! Thats what i Needed Thanks!
Old 01-25-2013, 01:54 PM   #6
Batman
Easy, Tiger.
Batman's Avatar
Drives: Tiguan, S4, SBC 350 Wrangler
I got mine about 20 minutes ago from autozone, does oil, tranny, fill up tires, etc..
Two V8s, one turbo, 12 Wheels total.
Batman is offline   Reply With Quote
Old 02-02-2013, 10:37 AM   #7
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
Originally Posted by FRSFirestorm View Post
I also am using one of these, they are called Suction Gun's....you can find them at autozone.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Center console accent filler panel JoeBoxer Cosmetic Modification (Interior/Exterior/Lighting) 39 03-30-2013 11:07 AM
Grimmspeed 86 Oil Filler cap disappeared? CrazyWookiee Cosmetic Modification (Interior/Exterior/Lighting) 8 08-03-2012 03:41 PM
What does this tool use to carscat Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 5 06-27-2012 09:24 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
Fuel Filler is on the Right!! Guaruja Scion FR-S / Toyota 86 GT86 General Forum 43 04-01-2012 05:55 PM
