Old 01-22-2013, 07:20 PM   #1
Andyx5044
Drives: Raven FR-S
DIY: how to remove your front grille (FR-S)
follow these steps.. you do not need to fully take off the bumper. just take off all of the rivets and screws then pull half of the bumper loose. you do not need to remove the side marker plugs either.
http://www.ft86club.com/forums/showthread.php?t=8788
now once the bumper is loose, reach from the top and remove the white foam guard. push the grille in on the edges until you here the edges pop out. this doesnt require a lot of force. when the grille is loose, twist it at an angle so that it doesnt scratch the paint and remove it out of the car.
also a good way to install a CAI
Andyx5044 is offline   Reply With Quote
Old 01-23-2013, 12:37 AM   #2
Synack
Boosted
Synack's Avatar
Drives: Sideways
I'll be doing this soon. Time to reveal the hidden intercooler.
Old 01-31-2013, 08:13 AM   #3
GT 86 Brah
u aware?
GT 86 Brah's Avatar
Drives: it like a turtle.
the hidden interfooler
GT 86 Brah is offline   Reply With Quote
Old 01-31-2013, 11:22 AM   #4
Synack
Boosted
Synack's Avatar
Drives: Sideways
No. I actually have an intercooler with my turbocharged FR-S.
Old 05-04-2013, 02:37 PM   #5
Ayrton
Ayrton's Avatar
Drives: 86 HS AFE filter, BRZ Xors, Kaymak
Thanks
Thanks for the info! Need to check my AC condenser after it was damaged.
Ayrton is offline   Reply With Quote
Old 05-04-2014, 01:37 PM   #6
poptopclk
Drives: Scion FR-S 10 Series
I need to just remove the front grille to install the remote antenna for a radar detector. Could someone just list the steps for just getting the grille out only ? TY
Will just STEPS: 5,6,7 and 8 from the link allow removal of the center of the bumper with attached grille? Like 2nd photo from 1st Post?
poptopclk is offline   Reply With Quote
Old 05-04-2014, 09:32 PM   #7
Maverick22
Maverick22's Avatar
Drives: 2013 Rocketbunny GT86
just pull on it. Its easier if you remove the bumper and push the tabs on the outer diameter inward from the inside, then push the grille out.
Maverick22 is offline   Reply With Quote
BRZ front grille mod bloomy116 Cosmetic Modification (Interior/Exterior/Lighting) 255 06-13-2021 08:58 PM
BRZ Front Grille Picture DIY xn7485 DIY (Do-It-Yourself) Guides 55 05-29-2020 08:26 AM
removing front grille (fr-s) request Andyx5044 DIY (Do-It-Yourself) Guides 6 01-26-2013 01:42 PM
FR-S Front Grille Options Borgore Cosmetic Modification (Interior/Exterior/Lighting) 21 11-14-2012 04:03 PM
Pics without front bumper grille? Synack FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 10-23-2012 12:18 AM
