Old 01-21-2013, 08:22 PM   #1
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
Need clarification on a noob question.
What is the biggest difference between a header back exhaust with cat and a cat back exhaust?
bdanisi is offline   Reply With Quote
Old 01-21-2013, 08:27 PM   #2
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
A header back is replacing the exhaust from the header....back.
A cat back is replacing the exhaust from the cat....back
Tansey86 is offline   Reply With Quote
Old 01-21-2013, 08:29 PM   #3
Tiremonkey0824
Drives: 2013 Argento 6mt
Headerback means that everything after the header is replaced, and cat back means everything after the cat is replaced. So the difference is that the header back will not only replace your muffler and the pipe after the cat, it will also replace the over pipe right after the header and the front pipe.
Tiremonkey0824 is offline   Reply With Quote
Old 01-21-2013, 08:29 PM   #4
FR-S Matt
A significant amount of horsepower gain versus very little horsepower gain. The front half of the exhaust is the most restrictive. The back half more or less is for sound.
Old 01-21-2013, 08:35 PM   #5
CrazyWookiee
Drives: Whiteout FR-S
Hopefully this diagram helps illustrate what everyone above is saying.
Headerback: Over Pipe + Front Pipe + Midpipe + Muffler
Catback: Midpipe + Muffler
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
Old 01-21-2013, 08:38 PM   #6
Ch3cho86
Ch3cho86's Avatar
Drives: Scion FR-S
no one understand his question. The difference is that the aftermarket cat on a headerback (with cat) exhaust is in most cases a highflow Cat = more HP than a catback exhaust without touching the sotck Cat (more restrictive)
Ch3cho86 is offline   Reply With Quote
Old 01-21-2013, 08:38 PM   #7
bdanisi
You Made Bro?
bdanisi's Avatar
Drives: Raven 86
Whoa so I want a complete header back system then... Is this still legal in ca? Also how much more usually is it for header back vs cat back? And does header back void my warranty?
Old 01-21-2013, 08:44 PM   #8
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
I don't recall any of them having CARB approval yet. I'm not from cali, so some others here might have more accurate information.
Voiding warranty will depend on the service tech you get. It would be difficult for them to prove replacing your exhaust damaged whatever part you're trying to get replaced under warranty- but if they make that kind of claim the onus is on you to prove them wrong afaik.
Ravenlokk is offline   Reply With Quote
Noob Air Filter Question GhostofAkina Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 03-09-2013 09:47 PM
Complete noob under-the-hood question! Scik Engine, Exhaust, Transmission 12 06-21-2012 10:07 PM
Noob lowering question. bazguitarman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-21-2012 03:53 PM
Noob question fitcious Cosmetic Modification (Interior/Exterior/Lighting) 2 05-02-2012 11:18 PM
[Noob Question]Will you be able to swap BRZ and 86 headlights? Slide Cosmetic Modification (Interior/Exterior/Lighting) 41 02-18-2012 01:26 AM
