Drives: 86 White GTS
18x9.5 +30 in the rear
Can anybody running 18x9.5 +30 offset in the rear on here confirm that they fit without camber adjustment? Any need for guard rolling?
Photos would be great. Please state what tyre size you are running as well if you can. |
Drives: 2003 Subaru Outback
I know 18x9.5 +38 with a 285/30/18 works in the rear without trouble.
ye i know +38 is fine without camber adjustment or guard rolling but not sure about +30
Ok, enough people have asked about rolling the fenders...they come rolled from the factory...
| The Following User Says Thank You to Supermassive For This Useful Post: | _F-R-S_ (01-16-2013) |
oh really? i was told that the fronts were but not the rears from someone who has a toyota 86
Drives: 13 whiteout scion frs
Drives: Raven Scion FR-S
so if i have an 18x9.5 +40 on my rears with a 265/35/18 will fit without camber adjustment and running oem alignment and height specs? could i even do a 275?
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
#8 | |
http://www.frsproject.com/tire_size.php <---Use this Last edited by Tansey86; 01-17-2013 at 01:47 AM. Reason: Found Auto Fitment Calculator |
| The Following User Says Thank You to Tansey86 For This Useful Post: | sal (01-17-2013) |
#9 | |
#10 |
Drives: bicycle
bump because i'm wondering as well
#11 |
bump
#12 |
If in doubt,flat out
Drives: 2013 brz
The fenders aren't rolled the lip is just non existent. Any bat work would give you a pull and likely turn out like shit.
#13 |
Crawford fit a 285/30/18 with a 18x9.5 +38 wheel. Width wise it will fit probably up to a 295 on each side, its a matter of height with the sidewall(i.e, a 285/40/18 would probably not fit)
| Wheel Directory: XXR 530 18x9.75 +20 | alexfrspr | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 28 | 02-09-2017 08:02 AM |
| Wheel Directory: SSR Professor SP3 18x9.0 +24 / 18x9.0 +20 | RZ86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 05-18-2013 04:14 AM |
| Enkei 18x9.5 +38 Front and Rear Pictures | maj75 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 32 | 12-10-2012 03:02 PM |
| F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires | SsmoothyMonster | Wheels and Tires | 17 | 09-24-2012 01:52 AM |
| 17x9 +35 front .... 18x9.5 +38 rear | kinryu | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 06-30-2012 02:19 AM |
