Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
FRS Stock Pioneer radio RCA outputs
I have the stock Pioneer radio in my FRS.
Generally, I am actually decently satisfied with how it sounds, the seamless bluetooth integration (phone & music streaming), the 90s look, and the USB/AUX inputs where they are. I am adding a Mountek phone mount to the CD slot (cause who uses CDs anymore?) to mount my iPhone 5 for navigation and occasional video duties. I would like to upgrade the speakers, increase power going to them, add a sub, and perhaps add some sound dampening/deadening into the doors and other places to reduce some of that hollow/light sound/feel to things. My question: I understand there are RCA outputs on the back of this Pioneer stock stereo for a sub-woofer output. Are they currently being utilized? I'm assuming they are not 4V+ outputs (probably 2V?), which are fine since I may still be using speaker-level inputs. Are the RCA outputs customization to output full-range? If they are full-range, I can then feed the RCA outputs into one 4-channel amp (which I would use for upgraded 6.5"s in the doors and probably tweeters on the dash) and have it pass through to a low-profile powered-sub which I hope can fit under the seat. Not sure where the 4-channel would go, maybe under the passenger seat. Do you see any potential gotchas with this setup? |
Hot Lava 6MT
Drives: Hot Lava FR-S
If you're looking to feed a 4 channel from the factory stereo, I would take the input from the factory amp and used tclips off the stock lines in, since the factory stereo does not have an amplifier (it's external to the stereo)
The factory RCA does not feel full range. |
Boosted Noob
Is there currently anything connected to the RCA outputs, stock? I'm assuming the box to the left of the spare tire is the amp for all the speakers in the car. Has anybody found or tried to draw up schematics of the stock stereo and speaker setup?
Drives: Ultramarine FR-S
Hey everyone. I had to bring this thread back to life..
I just got done installing my subwoofer, sub amp (rockford fosgate 300.1) and all necessary wiring. I ran the amps RCA cables from the factory pioneer head unit RCA output and it did NOT work. Has anyone ran their subwoofer amp from the stock RCA outputs on the pioneer radio? |
Drives: 2013 Ultramarine FR-S, AT
You need to turn on the RCA outputs. Turn the radio off, then push and hold the volume knob. There will be an option to turn on the sub output from there
Drives: Ultramarine Scion Fr-s
holy macaroni !! I'm glad i ran into this, i hooked up my system and it did not work. after breaking my head and some troubleshooting i found it was the rca output/ or cables. Now i feel kind of dumb i should of checked settings. This makes it a lot easier, thanks.
Does that only work when the rca is plugged into the head unit. I tried this the other day (with nothing installed into the head unit )
Yes, you need to have the RCA running from your head unit to the amplifier. The quality of the low frequencies is MUCH better this way than tapping from the speaker wires.
| Pioneer app radio | j.t. | Electronics | Audio | NAV | Infotainment | 31 | 01-26-2014 06:20 PM |
| FR-S BeSpoke Pioneer radio diagnostic screens | DrHouse | Electronics | Audio | NAV | Infotainment | 7 | 01-05-2014 09:42 PM |
| Pioneer radio upgrade question... | Jester | Electronics | Audio | NAV | Infotainment | 8 | 07-23-2013 05:04 PM |
| FR-S Base Pioneer Radio w/iPhone | Boxer-86 | Electronics | Audio | NAV | Infotainment | 7 | 10-06-2012 03:38 PM |
| stock nav head unit outputs | brzzz | Electronics | Audio | NAV | Infotainment | 2 | 07-13-2012 03:37 PM |
