#1 | |||
Drives: Black 2013 FRS
Want to upgrade your headlights the right way? Read here.
So I decided to contact the guys over at Daniel Stern Lighting (http://www.danielsternlighting.com/) regarding the headlight bulbs in the FR-S. I wanted an effective, and reasonably priced upgrade over stock as I do lots of night time highway driving. I also wanted to make sure that I wouldn't be blinding oncoming motorists, I know how frustrating that can be.
When asked about the H11 Low Beam he said the following Quote:
DIY Can be found here: http://www.rx8club.com/do-yourself-f...socket-119161/ For the 9005 High Beam he said: Quote:
I also asked about the retrofit kits available from The Retrofit Source and he said: Quote:
TL R Version:Buy a set of Phillips H9's for the low beam and trim the inside of the plug molded onto the bulb. 55% more light without blinding people. DIY Here: http://www.rx8club.com/do-yourself-f...socket-119161/ Buy a set of 9011's for the high beam and do this (http://dastern.torque.net/Mods/HIRmod.html) 48% more light than stock with properly focused beam. Total cost of ~$150.00 or less and significant improvement. FYI if you're looking for ricer blue headlights that look "cool" this won't accomplish that. |
#2 | |
Ridge Racerrrrrrrrr
our car's projector as 4 screws that mount it to the headlight assembly. How can you f" 4 screw mounting points?
Drives: Asphalt AT
But if I don't blind people thats fewer people bitching about HIDs. First world problems.
#4 | |
The Answer
Drives: Mazda 2
Thanks for the info, but like aftermarket HID's, you still end up placing bulbs that were not designed for our housings, much like aftermarket HID's. I had my share of HID retrofit, I even build custom lenses for my 6th gen celica and I can say that if somebody wants to to a proper HID setup on the cheap, a 4000-5000 K aftermarket HID kit will work, and if you want to be really "good" to other drivers you can bend off the squirrel finders. (I'm talking about the stock FR-S headlights here).
Whichever way, you have to spend money and time thinkering with your headlights, but all theses solutions are good anyway.
#6 | |
Quote: In your FR-S? Your low beams take a 1350-lumen H11 bulb. You can easily, safely, and effectively replace this with a 2100-lumen H9 bulb, which you ought to be able to find locally by seeking the high beam bulb for a 2008 Chevrolet Malibu. Use a good brand (GE, Philips, Osram-Sylvania) and stick to colorless clear bulbs, not any kind of "whiter light" bulb such as the Sylvania Silver Star scam. Can also get online, http://store.candlepower.com/h-9.html .You may need to shave a small ridge of plastic off the H9 bulb's connector so that the H11 socket will snap on. Other than that, it's a direct swap. The only disadvantage is shorter low beam bulb life — the H11 is optimised for very long life with relatively modest light output, while the H9 is optimised for very high output with relatively short life. Note that the H9 swap is not universal; it works well in projector-type low beams but is not safe in most reflector-type low beams or in fog lamps of any type. 1350 Lumens to 2100! That's an increase of 55% in light output. DIY Can be found here: http://www.rx8club.com/do-yourself-f...socket-119161/ The DIY link details the cutting of more than the "small ridge of plastic..." Does this need to be done for the FRS fitment? |
#8 | |
Drives: Ultramarine FR-S 6MT
$150? MUCH less lol, my amazon cart right now is like $48 for 4 bulbs.
http://forums.nasioc.com/forums/show....php?t=2083911 He didn't do the front cover mod and doesn't seem to have run into any problems. Also, he has temperature data between the two lights!
| The Following User Says Thank You to Ingen For This Useful Post: | PNW FRS (01-15-2013) |
#9 | |
"New hotness"
Drives: WRB Limited MT BRZ
#11 |
Drives: sc00ter
FWIW, h9 was design to use for high beams... it uses more heat and energy, hence why it has low life span as compare to h11... just like back in the days, where 9006.9005 was popular.. people would modify high beam bulbs (9005) to fit in place of 9006...
if you do lots of night driving, will this extra heat be okay to the housing/wiring? |
#12 |
H9 bulbs on sale on Amazon
"Ingen" - thanks for the link to the other write-up. The temperature information was very informative; nice to know there is no significant heat build-up. Deeper into the thread, lots of good reports from users.
$7.03 and if you order $25+ (order 4), free standard shipping. [ame="http://www.amazon.com/Philips-Standard-Headlight-Bulb-Pack/dp/B00480KOP4/ref=sr_1_1?ie=UTF8&qid=1358307791&sr=8-1&keywords=phillips+h9"]Philips H9 Standard Headlight Bulb, Pack of 1 : Amazon.com : Automotive[/ame] For comparison, Autozone is asking $14 and change for 1 bulb. |
#13 | |
Yep. Should be fine. The link I posted has a second DIY where a guy only encountered a slight heat build up issue over 10 minutes with lights on and car not moving. |
#14 |
Drives: ISF
Theoretically some of the OP's / Daniel post may be accurate, but I disagree with the TRS diatribe. Practically, the visible end result is more valuable. I went the TRS route, with projectors and proper cutoffs. The product was well made, there is only one way to mount the lens and it is VERY secure (center of gravity.....please).
What I experience is MUCH better lighting than stock. No bulb vibration (impossible with the screws holding the lens in place), no gaseous interference from silicon (used factory adhesive) etc, etc, etc.
1993 MR2 Turbo - Red
1996 Supra Turbo - White 2011 ISF - Mercury Metallic / Black Suede 2013 Scion FR-S - Firestorm Red 2014 Lexus GS F-Sport - White / 2015 Lexus RCF - Blue (Nov Delivery) |
| The Following User Says Thank You to msile For This Useful Post: | SkAsphalt (01-16-2013) |
| how do you read the last digits of the VIN? | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 09-04-2012 06:00 PM |
| FR-S vs Yaris/Tercel, yes you read that right | regal | FR-S / BRZ vs.... | 2 | 08-13-2012 11:43 AM |
| Want to track your FR-S? Read this for my perspective! | Rejor11 | Tracking / Autocross / HPDE / Drifting | 9 | 08-03-2012 02:19 PM |
| Can anyone read Dutch? | Buggy51 | BRZ First-Gen (2012+) — General Topics | 14 | 12-28-2011 09:48 PM |
| Toyota READ THIS | Mr.Jay | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 12-09-2011 12:13 AM |
