Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 01-13-2013, 12:31 AM   #1
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
86 or BRZ
Interesting picture, I certainly feel the 86 is far better looking.
Note the angle of bonnets.
Ryan86 is offline   Reply With Quote
Old 01-13-2013, 01:05 AM   #2
Burrcold
Drives: Subaru BRZ Limited
I will respectfully disagree of course Also it's not a fair comparison in my opinion. The angle of the 86 is tilted further down, giving it a more aggressive "face". That being said, I'm sure many will disagree with me, but that is why it's great that we have two flavours to choose from!
Old 01-13-2013, 02:16 AM   #3
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Biased or not I prefer the 86's more aggressive look but the BRZ's blue is simply stunning.
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 01-13-2013, 02:18 AM   #4
Vic_RSA
The voice of reason...
Vic_RSA's Avatar
Drives: 2012 Toyota 86 6MT Standard
I prefer the 86's indicator arrangement as in my opinion it is more visible than the BRZ's integrated units.
Vic_RSA is offline   Reply With Quote
Old 01-13-2013, 06:36 AM   #5
NamSin
Drives: Toyota 86 Auto Satin Pearl White
I suspect their might be some kind of fish eye lens effect on the 86 picture since the windscreen looks much smaller than the brz's and in fact they are the same
NamSin is offline   Reply With Quote
Old 01-28-2013, 01:42 PM   #6
Ryan86
Road Warrior
Ryan86's Avatar
Interesting
EVO: Toyota GT86 vs Subaru BRZ Comparison
The Toyota GT86 and Subaru BRZ are near-identical cars with different personalities. Henry Catchpole has to tell them apart – and pick a winner
Text: Henry Catchpole / Photos: Dean Smith
January 2013
Klitschko, Brownlee, McRae, Dimbleby, Schleck, Chuckle – trying to choose between two brothers and decide which is the better is something of a sticky subject. You feel that even if it can be done – even
if it’s sometimes quite an
obvious decision – it probably shouldn’t be spoken about for the sake of some sort of familial harmony: ‘Each has his own strengths and is special in his own way, so let’s move on, nothing to see here.’ But only one of the Subaru BRZ and Toyota GT86 can go into the group test (E30 M3 vs Integra Type-R and Clion 200) over the page. So we must decide.
In this case the two Japanese protagonists are more like twins than mere brothers, so splitting them is even trickier. Their 197bhp boxer-four engines, for example, are identical, as are their gearboxes (this manual BRZ being more enjoyable than the auto we tried previously). They’ve even got the same Michelin Primacy tyres. The interiors might have been kitted out differently in these two particular cars, but apart from the badges on the identically shaped and sized steering wheels, both could be dressed up to match.
So, what is distinguishing? The front grilles are clearly different – one appears to be upside down, although we’re not sure which one. The thick strip of plastic behind the Subaru’s number plate does make it look like it’s got a bit of a moustache, which could be good or bad depending on
your thoughts on what Nigel Mansell would have looked like with a small registration plate accessorising his soup strainer. You can also have the BRZ in Mica Blue, which for some will mean that it is an instant winner, but if we were to choose on bodywork alone, it would have all the kudos of the NME deciding that one half of Jedward is better looking than the other.
No, it all comes down to the way they drive, and even this is initially tricky to distinguish. Drive at six-tenths in either car and it really doesn’t matter which you choose. There’s bundles of grip from both
chassis and a nice neutral
feeling to the way each car dissects a series of bends, with neither remotely ruffled when you get on the throttle. In the wet, as roll stiffness effectively increases to 100 per cent, both cars are a doddle to slide when you turn the stability control off. Both are a lot of fun.
The two cars only truly begin to diverge when you increase your commitment and really start to push them dynamically in the dry. The difference is in the set-up, with the Toyota having a slightly softer front end and a slightly stiffer rear (and therefore by deduction the Subaru being mildly stiffer at the front and faintly softer at the rear). This means that initially you get a little more positive feeling from the
steering of the BRZ as its sharper nose dives into corners, with a bit more bite the
moment you turn the wheel. This extra grip doesn’t seem to diminish either; the harder you push, the harder it grips because as the car turns, the softer rear leans and digs its tyres harder into the tarmac. Understeer simply never materialises.
By comparison, the Toyota has a marginally softer
feeling to the steering and less positivity as you turn in to a corner fast. Carry yet more speed and the nose actually begins to leak away its grip, the steering lightening a little in your palms as it does so. This then requires you to back off the throttle a fraction, or unwind a bit of lock to restore grip to the front tyres. In short, it will understeer.
What I’m about to say next might surprise you. We
prefer the Toyota. Yup, the
understeering GT86 is our choice for the thrill of driving. That’s because when the front tyres start to scrub, it’s
comforting; it signals where you are with grip levels and lets you adjust the weight
balance more effectively. In short, it gives you something to work with, whereas the BRZ at its limit just seems to grip and resist your attempts to get it moving around.
Because the GT86 is stiffer at the back, it also unsticks into oversteer (with a combination of momentum and power) more easily and progressively than the Subaru, which will eventually oversteer but feels
more snappy and less happy doing so, wanting to pivot around a point closer to the front wheels. It’s all stuff that happens right at the outer
limits of the cars’ repertoires, and unless you’re on a dry trackday it won’t matter most of the time because those limits are surprisingly high.
But we need to separate the two somehow, because only one can meet the bona fide bunch of heroes waiting for it in the group test that follows. The Toyota gets the nod.
Via: http://www.evo.co.uk/carreviews/carg...ubaru_brz.html
Old 01-28-2013, 01:53 PM   #7
whaap
whaap's Avatar
I like the FR-S mostly because it does a better job in disguising the moustache/bumper. Also between the two it looks to me to be the one more aggressive.
whaap is offline   Reply With Quote
The Following User Says Thank You to whaap For This Useful Post:
Ryan86 (01-28-2013)
Old 01-28-2013, 02:30 PM   #8
norsamerican
norsamerican's Avatar
Drives: WRB BRZ
my choice was based on creature comforts, and the service department at my local dealer. I wanted heated seats, navi, alcantara seats and red stiching. The headlights on the BRZ are fantastic. I think the front bumper is great on both cars but i dont plan on keeping it on the car so either one would have worked..then again i wanted those comforts.
Plus ive never really honestly been a fan of scion. Yes i know its actually a toyota..but ive never fit in with the scion crowd.
Old 01-28-2013, 02:33 PM   #9
just86
just86's Avatar
Drives: 2013 genesis rspec
We all know 86 looks better.. Front looks like my 2013 camry
just86 is offline   Reply With Quote
Old 01-28-2013, 03:34 PM   #10
jbsali
jbsali's Avatar
Drives: 2014 Subaru BRZ (Limited)
i prefer the 86. Not a fan of the FRS Headlights though. I would pick the 86/FRS because it shares the heritage (brandwise) with the gt2000 and ae86... even though the car is mainly built by subaru lol.
jbsali is offline   Reply With Quote
Old 01-28-2013, 03:44 PM   #11
Razzle
Razzle's Avatar
Drives: Toyota 86 (High) - White
The BRZ's font bumper is upside down :|
Razzle is offline   Reply With Quote
Old 01-30-2013, 10:43 AM   #12
sav
sav's Avatar
How brilliant is this advert?
[ame="http://www.youtube.com/watch?feature=player_embedded&v=MzjEnxg3GYE"]Gymkhana BRZ - YouTube[/ame]
95RON SAV Tuned
Old 01-30-2013, 11:09 AM   #13
Alang
Alang's Avatar
Drives: 2013 Toyota 86 2.0 Std.
Amazing!!!!
Adding power makes you faster on the straights, subtracting weight makes you faster everywhere - Colin Chapman
Alang is offline   Reply With Quote
Old 01-30-2013, 11:45 AM   #14
Ryan86
Road Warrior
Ryan86's Avatar
@sav, that bloke looks just like you man......
