Old 01-10-2013, 01:35 AM   #1
Oh Damn Andrew
Oh Damn Andrew's Avatar
Drives: 2013 Whiteout FRS
Eibach Sportline Springs Review
A review of the Eibach Sportline springs as a daily driver. Full article here
"In our earlier*review,*we raved about the stock suspension and how impressed we were with how well balanced the car is in stock form, so why touch it?
Not one to leave things stock, we wanted to get rid of the wheel gap without decreasing the cars handling characteristics. *We weren't looking to slam the car to the ground nor were we looking to put big money coil overs on our FR-S (not quite yet).
we searched for something that would:
  • Reduce wheel gap without sacrificing handling
  • Stay within our minimal budget.
The Sportline kit comes well labeled with replacement bump stops and dust boots. *Armed with a torque wrench, spring compressor, and some power tools, the install took about 2 hours. *Luckily, Toyota/Subaru engineers considered suspension modifications when making this car so accessing the bolts holding down the suspension was easy and straight forward.
Since the install, we have logged about 2000 miles on our FR-S. *Daily driving, the ride feels almost stock. *The suspension is slightly firmer. *Its hard to explain but the added firmness is proportional to the reduction in wheel gap...just a little bit. *Although bumpy roads and road transitions are exaggerated with the firmer springs and shortened strut travel. *The ride can get bumpy but it is bearable.
The FR-S is a low car to begin with, lowering it 1.4 inches doesn't require you do drive that much more cautiously than before. *For those accustomed to driving lowered cars, this is very worry free. *You won't have to fear speed bumps. *If you don't have a front lip, you probably won't scrape on most dips and driveways. *To date, the bottom of the car has not yet scraped and the front bumper has scraped on a dip once.
In hard driving situations, the stock FR-S has a slight tendency to oversteer. Aggressive cornering in a stock FR-S usually leads to a frantically flashing traction control light. *With the Eibach Sportline springs, *the rear seems more planted. *The tendency to oversteeer is reduced resulting in much more neutral handling. We have yet to take the car to the track. *We will definitely update our review once we do so."
Oh Damn Andrew is offline   Reply With Quote
Old 01-10-2013, 01:44 AM   #2
Khánh
Khánh's Avatar
Drives: sc00ter
very nice! are u currently running any camber-correct setup?
Khánh is offline   Reply With Quote
Old 01-10-2013, 01:48 AM   #3
g0lden
Drives: 2013 Scion FR-S Argento
Thanks for the write up. I've also looked into the Eibach Sportline springs vs coilovers. I'd rather do it cheaper since I'm more of a daily driver. Please let us know when you get the chance how it feels on the track. I prefer Auto-X :-)
g0lden is offline   Reply With Quote
Old 01-10-2013, 01:50 AM   #4
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
is this just the drop with no camber adjustment?
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 01-10-2013, 06:45 PM   #5
wWaldo
Drives: Asphalt Frs
I can't wait to get my FRS, and get these!
I had these on my genesis and I loved them! If you don't want to be slammed and just perfect these are the way to go!
wWaldo is offline   Reply With Quote
Old 01-11-2013, 03:24 AM   #6
Oh Damn Andrew
Correct. The car does not pull to any direction when driving but we will be getting camber bolts and alignment soon. We will update our review after alignment and track time.
Old 01-11-2013, 03:25 AM   #7
Oh Damn Andrew
Exactly! Great bang for the buck without decreasing the cars handling capabilities
Old 01-11-2013, 03:31 AM   #8
TRD_86
Drives: 2013 86 white
Look very nice !
TRD_86 is offline   Reply With Quote
Old 01-17-2013, 12:41 AM   #9
Oh Damn Andrew
Here are some quick comparison pics with a friends stock FR-S. Sorry the pics aren't a true comparison. We just happened to be parked next to each other.
Kinda hard to tell from the rear but you can see from the level of the muffler, how much lower the white FR-S is
Old 01-18-2013, 01:19 PM   #10
Ad8707
Ad8707's Avatar
Drives: 2013 frs whiteout
Would the sportlines compromise the life span of the stock struts..i want to do this but worried I'd ruin my struts and chassis
Thanks
Ad8707 is offline   Reply With Quote
Old 01-18-2013, 05:26 PM   #11
dun3
dun3's Avatar
Drives: 2013 Ultra Marine Blue FR-S
^I worry the same. I'm thinking I will go with Sportline springs, and Koni Yellows
dun3 is offline   Reply With Quote
Old 01-18-2013, 07:17 PM   #12
Khánh
Khánh's Avatar
Drives: sc00ter
good excuse to upgrade to better shocks! but I can see the stock lasting more than a year. .. so start saving $
Old 01-18-2013, 10:47 PM   #13
Zach
Drives: 13 FR-S Black MT
I have about 10k I believe on my sportlines installed on stock struts and so far so good.. great actually. That red car looks lifted!
Zach is offline   Reply With Quote
Old 01-20-2013, 05:24 PM   #14
ayetothejay
ayetothejay's Avatar
ok, guys I need some help here. I'm deciding whether to get sportlines or bc coilovers. I'm using my frs just for daily driving, I'm not going auto-x at all. I'm just looking for a 1.5" drop max without sacrificing much performance and rideability. I've narrowed down to this 2. Should I still go for coils if my main focus is basically getting rid of the wheel gap? I really don't like the slammed car look IMO. btw, I'm pairing that with 18x9.5 +38 wheels and 245/35 tires all around.
ayetothejay is offline   Reply With Quote
Suspension Review: Eibach Sportline Lowering Springs DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 129 07-23-2019 09:59 PM
FS: Eibach Sportline Springs in AZ AZ BRZ Brakes, Suspension, Chassis 14 02-05-2013 07:27 PM
Eibach sportline lowering springs.. frsguy707 Brakes, Suspension, Chassis 24 12-14-2012 01:01 PM
GTA FS: Eibach Sportline springs, BNIB l8apexr Canada Classifieds 14 12-05-2012 02:50 PM
Eibach Sportline Lowering Springs for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 4 07-06-2012 11:04 AM
