Southern California SoCal
Old 01-03-2013, 07:09 PM   #1
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
FRS to Bear Mountain.. Bad idea?
I'm going snowboarding this weekend and I was wondering would the FRS be a safe car to drive up there? As far as I know the weather conditions look fine and no chains are required. This is my first RWD car so anything I should know? Is it a bad idea/ anything I should do to prep like tape the car edges to prevent dings?
l0aded is offline   Reply With Quote
Old 01-03-2013, 07:12 PM   #2
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Traction control should keep you safe if you know how to handle the throttle (do not treat it as a ON/OFF switch). Not sure if they're doing chain-control, but that might stop you from getting there.
mit_peid is offline   Reply With Quote
Old 01-03-2013, 07:14 PM   #3
Hanakuso
Snow or ice on the ground? No, unless I had chains. Other then that I don't see a problem. I've never been to Bear with a lot of snow.
Hanakuso is offline   Reply With Quote
Old 01-03-2013, 07:21 PM   #4
l0aded
Addicted
l0aded's Avatar
No chains required as of now. Not sure if there is ice on the ground don't have much experience driving up there.
Old 01-03-2013, 07:23 PM   #5
l0aded
Addicted
l0aded's Avatar
Originally Posted by mit_peid View Post
Traction control should keep you safe if you know how to handle the throttle (do not treat it as a ON/OFF switch). Not sure if you're doing chain-control, but that might stop you from getting there.
TBH I could drive manual since I was 16 but this is my first manual car and I've had it about 2 weeks so far. I'm fairly confident in my ability but can you elaborate on the handle the throttle? Basically dont over-rev?
Old 01-03-2013, 07:30 PM   #6
Hanakuso
I think what he meant was basically do not lose traction because of rapid fast/slowdowns. Last month I was in Oregon and played around with the Jeep rental. RWD seems to be actually doable in the snow but if you gun it, it will wrap around you easily.
Old 01-03-2013, 07:47 PM   #7
mit_peid
Boosted Noob
mit_peid's Avatar
Talking
Exactly. Be very conservative accelerating, braking, and probably most importantly accelerating around a turn. I let my friend use my 4Runner with 4WD with All-Season tires this weekend in Lake Tahoe and he almost spun out twice taking turns. The car and its abilities are useful, but the driver and his brain/abilities are most important.
One thing you can do is use 1st to just get you moving, then immediately go into 2nd. You don't need too much torque. Traction is more important. Use mostly the bottom end of your tach and do not feel like you need to race anybody up to or off the mountain.
Most importantly, if you find yourself in an empty parking lot. Turn off all nannies and be sure to have tons of fun testing the limits of your FRS.
Old 01-03-2013, 08:00 PM   #8
ahausheer
Re-member
Drives: Toyota camry
If chains are not required you will be fine IF you drive slow and carefully. There will likely be patches of snow/ice particularly if you leave early or late and the road temp is below freezing. Trust me, I've spun and rolled due to ice and I had studded tires. The problem is that you find a speed where nothing happens and you think you can go faster, but you cant. Just go slow.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 01-03-2013, 08:11 PM   #9
l0aded
Addicted
l0aded's Avatar
Will do
Old 01-03-2013, 08:20 PM   #10
avp1
Drives: Traded BRZ for Supra
If you are on stock tires, forget about that trip. You need good snow rated tires to be comfortable on snow. Even then driving in the mountains would be hard - mainly problem with start moving. I would get 4x4 SUV if you need to go there.
avp1 is offline   Reply With Quote
Old 01-03-2013, 08:47 PM   #11
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Personally I wouldn't do it without snow tires.
Old 01-03-2013, 08:56 PM   #12
jacjac3
jacjac3's Avatar
Drives: WRB BRZ
Not sure if it was my wrx or my brz manual, but I read that you cannot use chains with the car. Could anyone validate this?
jacjac3 is offline   Reply With Quote
Old 01-03-2013, 09:03 PM   #13
BlaineWasHere
Grip>Drift
Drives: FRS
Since the WRX is AWD I could see how if it put extra resistance on one axle and not the other it could cause harm.
Old 01-03-2013, 09:04 PM   #14
White Shadow
Drives: 12,000 miles per year
You guys on the west coast have a Bear Mountain too?
White Shadow is offline   Reply With Quote
Blood mountain/ Helen FR-ser Southeast 2 10-08-2012 08:20 AM
White Mountain/Kancamagus Run NRGBalanced New England 35 07-16-2012 12:25 PM
Possible two-day FT86 drive in August: VT mountain passes Deslock NY / NJ / CT / PA 2 07-10-2012 03:09 PM
Bear grills is the MAN!! Niche79 Off-Topic Lounge [WARNING: NO POLITICS] 17 04-10-2011 12:12 PM
