DADA
Drives: 2013
Has anyone run wires through doors?
I did a search but couldn't find anything regarding running wires through doors, I tried to run some 16 gauge speakers wires through the grommets and it goes in about half way then gets stuck , it gets stuck no matter which end I go in .
How did you run it?? |
Drives: Argento 6spd FR-S
Just use a wire puller, or coat hanger and take your time. its pretty easy tho. Im using 14g also.
Drives: silver, 4 wheels, goes wheee...
First, I loosened the bolt on the connecting rod that stops the door from opening too much.
Then I pulled the grommet off of both the car side & door side. I then found a thick braided steel cable (kinda like a brake cable off of a bike), but I was prepared to use a coat hanger wire. I used masking tape to tape the end of the speaker wire to the cable. Then I slathered Vaseline all over that masking tape. ... after that, it was fairly easy. - push through car wall, pull slack into space between car & door - push through rubber boot - push through opening in door (which goes into rubber sleeve) - carefully cut slit in sleeve in door area for new wire come out. Hope that all helps.
... I'd rather be driving...
#4 | |
DADA
Drives: 2013
I did lube an 8 gauge and managed to get it to the tip of the car boot but it wouldn't go anymore . |
#5 | |
#6 | |
Drives: 86 GT Manual - Sonic Blue
| 86 with Lamborghini Doors | quik1987 | Cosmetic Modification (Interior/Exterior/Lighting) | 102 | 04-10-2018 09:32 PM |
| lambo doors. What you think? | FLIPs_FR-S | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 04-10-2018 09:13 PM |
| BRZ and Lambo Doors | pinoyplaya | Cosmetic Modification (Interior/Exterior/Lighting) | 67 | 04-09-2018 08:24 AM |
| DIY Satellite Radio Install (No visible wires) | lukeg | DIY (Do-It-Yourself) Guides | 2 | 04-10-2015 12:58 PM |
| our doors are heavy... | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 75 | 09-30-2013 10:04 AM |
