Old 12-17-2012, 10:45 PM   #1
MattF
MattF's Avatar
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
Rota grid 17x9 +35
So I got a good deal on some rotas. Now I have to figure out what tires to run. I am thinking 235/40s in the front and 245/40s in the back. I don't want to much of a stretch. However, I also don't want to pull the fenders or run extreme camber in the front. I have plans to run kw v3 coil overs in the future in a 1.5 inch drop all around.so what are everyone's thoughts here id a teaser pic as well.
MattF is offline   Reply With Quote
Old 01-20-2013, 02:28 PM   #2
TurboBrett
Drives: 13 BRZ
Ever get these with tires on there? Pics?
TurboBrett is offline   Reply With Quote
Old 01-27-2013, 07:28 PM   #3
MattF
MattF's Avatar
Have tires mounted but have not put them on the car is been to cold for summer tires will post pictures up once things warm up a little next week.
Sent from my SCH-I605 using Tapatalk 2
Old 01-27-2013, 07:56 PM   #4
fatoni
you really should be deciding on tires before rims but now that youre here, i recommend picking 4 tires of the same size.
Old 01-27-2013, 07:59 PM   #5
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Go for a square setup (same size tires everywhere). Makes it so that you can rotate your tires correctly and just makes your life easier overall. Plus you're lowering your car so it may look a little odd to have slightly larger tires in the rear. Up to you though. Just my .02
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 01-27-2013, 08:02 PM   #6
MattF
MattF's Avatar
Went with a square setup of 235's all around. Will have pictures of them installed when things warm up its all little too cold for summer tires in my area right now.
Old 02-08-2013, 10:49 PM   #7
MattF
MattF's Avatar
Here is a picture of them installed in my garage more to come when I take a trip to the park way tomorrow.
Old 02-09-2013, 11:11 PM   #8
MattF
MattF's Avatar
Here is a picture in the table rock state park from today. All i can say is what a difference good tires make with the way the car handles.
Old 02-10-2013, 05:48 AM   #9
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
looks nice, good choice on the color
Killerbee is offline   Reply With Quote
Old 02-10-2013, 06:09 AM   #10
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
how come you didn't want to go 235/40 front and rear?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 02-10-2013, 10:13 AM   #11
MattF
MattF's Avatar
Went with 235/45 for a meaty look.
Old 02-10-2013, 10:15 AM   #12
MattF
MattF's Avatar
Originally Posted by xBOXER View Post
specs?... suspension oem/coils, drop? camber, rubbing? TIA.
Car is on Tein s techs. Other then that it is stock. No rubbing issues at all.
Old 02-10-2013, 10:23 AM   #13
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
careful s techs are terrible springs they are mostly just for show. also be aware lowering the car more than 1 inch on stock struts can do major damage go read up on it from RCE, dont want your suspension getting screwed up .
DanoFA20 is offline   Reply With Quote
Old 02-10-2013, 10:33 AM   #14
MattF
MattF's Avatar
Haven't noticed them being terrible I have always run them on my 240s while I am saving up for coil overs. My long term goal is to run kwV3 coil overs.
Considering Rota Grid 17X9+42mm offset Vukodlac Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 09-09-2015 02:55 PM
Wheel Directory: Rota Grid 17x9.0 +42 BlaineWasHere Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 81 06-26-2015 08:12 PM
Group Buy - Rota Slipstreams or Rota Grid davidsolarbell Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 12-17-2013 12:04 PM
Wheel Directory: Rota Grid 2 17x8.0 +38 stvrjs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 09-02-2013 04:08 AM
Rota Grid 18x10 30et Nizz300Ft86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 17 08-14-2012 11:34 PM
