Old 12-17-2012, 10:09 AM   #1
GotM
GotM's Avatar
Drives: 14 Porsche Cayman S
86 AT vs 86 MT
Name:  86 AT vs MT.jpg
Name:  86 AT vs MT2.jpg
I did some basic modeling on the acceleration differences between the MT and AT for the twins.
-The MT has a slight advantage over the AT through all gears. The difference in 1st gears is ~1ft/s^2 delta. This is a fairly small difference.
-It looks like shifting at redline is going to give max acceleration. Except the 4th to 5th. But, the crossover is so small I would still use redline.
-I like how the AT goes through 60mph in 2nd, unlike the manual.
-You can see the slight weight advantage (really, really small) by comparing 5th MT and 4th AT.
-No, these cars do not top out this fast. No energy losses are accounted for in this model. I think some where in the 140s would be top speed, based on the 200hp.
Added:
The time to MPH chart. It looks like the MT has a slight edge on the AT after 60mph. But, I think this is too close to claim one is really faster than the other.
Previous cars:
2013 Subaru BRZ (2012-2017)
2009 BMW135 6MT (2009-2012)
1999 BMW M Roadster (2000-2010)
2004 Audi A6 2.7T (2004-2007)
GotM is offline   Reply With Quote
The Following 13 Users Say Thank You to GotM For This Useful Post:
Asphalt~86 (01-14-2013), Bonburner (02-04-2013), Captain Insano (12-18-2012), clzzical (12-23-2012), dem00n (12-18-2012), Efferalgan (07-29-2013), Guff (12-18-2012), p1l0t (07-21-2020), Sigh-on-Rice (12-27-2012), Simpleviet (07-05-2013), soros151 (12-18-2012), Wayno (06-09-2015), xcooperx (08-31-2015)
Old 12-17-2012, 11:04 AM   #2
Ingen
Drives: Ultramarine FR-S 6MT
Technical basis for the model?
I'm just curious
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 12-17-2012, 11:22 AM   #3
GotM
GotM's Avatar
The model used the following information:
1. Inside-Line dyno chart, at the wheel torque curve
2. Toyota/Subaru published gear ratios, final drive, weight specs.
3. Tire rack - Michelin HP tire specs (revs/mile, & diameter).
Model was a method to normalize to acceleration.
Previous cars:
Old 12-18-2012, 08:16 AM   #4
PrDarkKnight
Director of Awesome!! :)
PrDarkKnight's Avatar
Drives: Scion FR-S
did you do any 0-60 on both?
Life is all about the ride, so go full throttle baby!!
[SIGPIC][/SIGPIC]
PrDarkKnight is offline   Reply With Quote
Old 12-18-2012, 09:20 AM   #5
GotM
GotM's Avatar
I do have some time-to-speed graphs based on this model. But, since there are so many key variables missing, it would not give an accurate time to speed. I think this is better for relative comparisons. I will post the graph of time to speed a little later today.
Previous cars:
The Following User Says Thank You to GotM For This Useful Post:
PrDarkKnight (12-18-2012)
Old 12-18-2012, 09:28 AM   #6
Eurasianman
Chief
Eurasianman's Avatar
Drives: 2013 DGM BRZ Premium 6MT
Really wish the manuals had a taller 2nd gear. I've never had an issue with hitting the rev limiter until this car
Eurasianman is offline   Reply With Quote
The Following User Says Thank You to Eurasianman For This Useful Post:
hmong337 (07-31-2015)
Old 12-18-2012, 10:29 AM   #7
PrDarkKnight
Drives: Scion FR-S
i am wondering also if there is anyone who has done a 1/4mile with the AT in full manual mode with track control of?
[SIGPIC][/SIGPIC]
Old 12-18-2012, 10:57 AM   #8
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I don't, it would make city driving in 2nd gear much shittier.
Rayme is offline   Reply With Quote
Old 12-18-2012, 11:12 AM   #9
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
If you want that slightly taller gearing for 60mph in 2nd, up your tire profile 1 size or get a tune that raises the RPM a bit.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 12-18-2012, 11:13 AM   #10
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
i have, slow as balls 11 second 1/8th mile, 18 second 1/4
eh?
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 12-18-2012, 11:28 AM   #11
GotM
GotM's Avatar
I added the time to MPH chart to the first post. Keep in mind this is for comparison only, and does not represent the time to get to a certain speed. The start is not from 0, but ~11mph.
Previous cars:
Old 12-18-2012, 12:49 PM   #12
Eurasianman
Chief
Would you mind explaining?
Old 12-18-2012, 01:54 PM   #13
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Taller gearing to reach 60 mph (without changing redline) means a longer gear and less torque down low...
basicly it would be much too easy to bog the engine in 2nd.. I had a WRX that didn't like it AT ALL anywhere under 2000 RPM, it would shake the entire drivetrain, so I had to downshift in 1st and it sucks just driving around...or you go around the corner faster
The Following User Says Thank You to Rayme For This Useful Post:
radroach (04-04-2014)
Old 12-18-2012, 07:51 PM   #14
PrDarkKnight
Drives: Scion FR-S
eh?
damn! where you even trying? lo!l My brothers 2.4 lancer GTS does high 15s and I have beat it!
[SIGPIC][/SIGPIC]
