Old 12-16-2012, 08:23 PM   #1
matt29
Drives: 2013 Whiteout FR-S
Perrin catless, non-resonated headerback installed!
So here's the deal,
Two weeks ago, I had my Perrin non resonated catback installed, and it was phenomenal. Noticeable power/torque gain, and it had the deep sound I was looking for. So, I thought to myself, this performs and sounds great, so more exhaust parts should sound and perform even better! So I went ahead and ordered Perrin's catless front pipe and their overpipe.
Just had the front pipe and overpipe installed yesterday morning. Here are my initial impressions of the full catless, non-resonated Perrin headerback system:
1. Even more of a power/torque gain. This is great. Also, it feels like the car revs a little easier too now.
2. Sound. This is where things get a little bit complicated. The primary exhaust note is great. Similar to the non-resonated catback, but a little bit louder. Basically, it's the powerful rumble anyone would hope for when installing a high performance exhaust.
However, there is an unsettling "secondary" noise that happens when you load the throttle, and around 4k rpm that basically sounds like a rattle/rasp. It sounds like it's coming from the back of the car. I knew the catless front pipe would add a little bit of rasp to the system, but I didn't anticipate this unsettling rattle type sound under heavy throttle situations. It's like a whole separate sound from the normal exhaust noises. I had it installed by a reputable shop, and they checked it for leaks, fitment, etc, so I know it's not loose.
My question is, is this annoying noise a "break in" type thing that will go away over time, or is this just the result of removing the OEM front pipe? The OEM front pipe has a small resonator on it, and maybe that little piece is what eliminates this kind of sound? Also, would installing something like the CATTED version of Perrin's front pipe help this situation at all?
Any feedback is greatly appreciated.
Also, at the end of the day, this is really a subjective thing. Overall, I can't say enough good things about Perrin. The build quality/welding/fabrication all look excellent, and their customer service is unbeatable.
matt29 is offline   Reply With Quote
Old 12-16-2012, 08:28 PM   #2
636
636's Avatar
Drives: '23 CWP BRZ
Removing resonators will more than likely cause raspy sounds.
636 is offline   Reply With Quote
Old 12-16-2012, 08:44 PM   #3
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
It's probably drone. I know some people put sound deadening where the spare tire is. Without being in your car and hearing it for myself I can't really be more helpful
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 12-16-2012, 08:52 PM   #4
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I usually recommend either keeping a catted front pipe or a resonator in the exhaust, eliminating both is asking for rasp/drone.
Nice user title there Nelson!
JoeBoxer is offline   Reply With Quote
Old 12-16-2012, 08:53 PM   #5
ngabdala
Perrin Headerback Exhaust System F1point4 Engine, Exhaust, Transmission 183 10-04-2013 04:02 PM
Let there be NO DOUBT: Non Resonated PERRIN> Resonated Perrin HP gmookher Engine, Exhaust, Transmission 78 09-11-2013 10:42 AM
Perrin Headerback installed Tylub Engine, Exhaust, Transmission 60 02-26-2013 01:04 AM
New Invidia Resonated Catless Front Pipe RallySport Direct Announcements, Contests, Giveaways 8 02-04-2013 05:06 PM
