Old 12-13-2012, 09:48 AM   #1
nktech
Drives: 07 CLS 63AMG
Professional Installation for HID?
Guys, wanted to run something by you all. I have seen a lot of HID kit installs (PnP) and was going to do it myself however, at my dealer, I was told by one of the finance guys that if the kit is not installed professionally that it could void the warranty. He actually owns 2 FR-Ss and had his installed by a shop. Is that true because I don't want to have to pay someone to install it if I can do it myself.
nktech is offline   Reply With Quote
Old 12-13-2012, 09:54 AM   #2
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
You can do it yourself, do not pay someone to install it. Plus then you dont have to worry about someone else working on your car and you know you did it right. All you do is plug them into your OEM wiring and attach the ballast somewhere. Just remember to fold down your "squirrel finders" so you dont get that glow above the cut off line.
Now if you got a legit bixenon kit then thats a different story.
FR-Shadow is offline   Reply With Quote
Old 12-13-2012, 06:01 PM   #3
nktech
Something isn't right. I tried the install today. I have the 5000K H11 HID Kit from DDM Tuning and one side of the lights won't work. Any thoughts?
Old 12-13-2012, 06:08 PM   #4
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
void warranty on bulbs? lol!
i got full HID and LED on my car and my lights had condensation.
got new lights from dealer without questions. covered by warranty
your finance guy does not know what he's talking about i guess
they must send you a bad ballast of bulbs. trying switching the ballast from the other side to that side. or the bulbs
and see which one is broken
86_ZN6 is offline   Reply With Quote
Old 12-13-2012, 06:55 PM   #5
nktech
Switched ballasts and the same bulb won't light up. How slow is the RMA process at DDM, anyone know?
Old 12-13-2012, 07:08 PM   #6
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
did u reverse the polarity ? HID kit for toyota needs to reverse.
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 12-13-2012, 07:15 PM   #7
nktech
Do I switch up connection to the bulb or ballast
Old 12-13-2012, 07:18 PM   #8
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
just the stock wires to the ballast. try reversing it. i know for sure HID kit for toyota is reverse polarity. hope it works
Old 12-13-2012, 08:02 PM   #9
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
ya i had the same issue with 1 of my HID's, just flipped the plug (doesnt clip onto the OEM plug now) and it works fine
lbroskee is offline   Reply With Quote
Old 12-13-2012, 10:14 PM   #10
jstans84
Drives: Scion FR-S
Same with mine, just use a zip tie to hold them together.
Also to the OP, putting new bulbs in your headlight can't void your warranty unless they melt the housing or something crazy like that.
jstans84 is offline   Reply With Quote
Old 12-13-2012, 11:49 PM   #11
nktech
Thanks for all the help guys. I will give this a shot tomorrow morning and report back.
I knew that adding HID's doesn't do anything in terms of splicing or cutting factory wires or opening/damaging the headlights and I tried to make a case but he insisted on having it professionally installed...
Old 12-14-2012, 09:57 AM   #12
nktech
Just checked this at 7am this morning, couldn't wait (ofcourse) and I think one of the bulbs is bad for sure. I switched polarity and that one bulb flickers for a second and goes out. I examined the bulbs carefully and the one that does not light up, the middle section (bulbous part) is greenish/yellow so maybe thats an indicator for it not being good whereas the other one is clear.
Old 01-11-2015, 11:57 PM   #13
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Why are you guys putting it in reverse polarity ?
When I got my hid kit ..I installed it all positive with positive and negative with negative
All works fine
Young_makaveli is offline   Reply With Quote
Old 01-12-2015, 12:01 AM   #14
Chimera
Drives: FRS
this is a 2 year old thread
All works fine
Free professional photos of your clean FR-S / BRZ in Los Angeles alby13 Southern California 50 01-15-2013 01:12 PM
Professional detailers in South Carolina? rushdown Southeast 3 08-20-2012 10:27 AM
Professional Drivers Talk about BRZ at TAS+ BRX drift incar Zaku BRZ Photos, Videos, Wallpapers, Gallery Forum 1 01-28-2012 10:18 PM
