Old 12-12-2012, 09:52 PM   #1
PrDarkKnight
Director of Awesome!! :)
PrDarkKnight's Avatar
Drives: Scion FR-S
cel with intake change
has anybody had this issue? I added a custom air intake tube using the stock air box withy a TRD hogh flow air filter. almost emediatly the cel came on, changed to the stock unit still qith the TRD and disconnected the battery to fix it. A buddy of mine told that since it's electronic throttle car I have to diconnect the battery, change the intake and then let it tddle for a couple of minutes so that the ecu can get used to the difference in air flow in the mix. Is this true? what do you recommend? thanks!
Life is all about the ride, so go full throttle baby!!
[SIGPIC][/SIGPIC]
PrDarkKnight is offline   Reply With Quote
Old 12-14-2012, 01:03 AM   #2
jacjac3
jacjac3's Avatar
Drives: WRB BRZ
Yea dude. It's recommended you restart the ECU with the battery trick. I had to do this on my WRX. Going to do the same for my brz. It will take your car about a week or two to learn to new changes. It's normal. Don't worry about it too much.
Drive it for about two weeks and see how the car is then before deciding to return back to stock parts.
Hope this helps
jacjac3 is offline   Reply With Quote
The Following User Says Thank You to jacjac3 For This Useful Post:
PrDarkKnight (12-14-2012)
Old 12-14-2012, 03:43 AM   #3
PrDarkKnight
Drives: Scion FR-S
thanks man! i hoped it would be that since a lot of aftermarket companies have had the same problem at first.
[SIGPIC][/SIGPIC]
Old 12-14-2012, 06:07 AM   #4
PrDarkKnight
Drives: Scion FR-S
The CEL came on again this morning, I re-set it and drove it with out passing 4000rpm. should I continue to do this until said time?
[SIGPIC][/SIGPIC]
Old 12-14-2012, 06:29 AM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Don't drive it! Remove that custom intake before driving it anymore.
Your ECU is telling you your car is running lean. The only way you can drive the car with that intake is getting a specific tune for it. So either get an ECUTek and get it tuned, or just go back to stock. You can hurt your engine running lean.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 12-14-2012, 09:37 AM   #6
PrDarkKnight
Drives: Scion FR-S
Thank You Man! i was looking into the EcuTek, You just decided my next Mod. What's interesting is that I used to have it on with out problems until I installed a Custom muffler delete, but the muffler delete by itself gives me no problems at all!
[SIGPIC][/SIGPIC]
The Following User Says Thank You to PrDarkKnight For This Useful Post:
Sportsguy83 (12-14-2012)
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 08:06 PM
When should i do an oil change? Ayaz2589 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 112 03-15-2013 01:25 PM
3,000 mi oil-change prest1ge Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 38 10-29-2012 07:13 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
