DBA vs AP?
Hi guys! I've been a long-time lurker on this forum and decided that I'd contribute with this question: which system is better value for money?
Living in australia, I can purchase the DBA rotors (2-piece t3's) without warranting a hefty international shipping cost/tax and they are relatively cheap compared to the other brand! So people, shoot me your thoughts and suggestions! Cheers! Mswhong |
Drives: FR-S, BR-Z, 86
One is just a rotor upgrade(DBA) versus a full brake kit (AP-caliper/rotors/pads).
For street use you'll be fine with just a rotor/pad upgrade. |
#3 | |
I was planning on purchasing fedoro pads and some steel braided lines as well and that whole set up costs between (approx) US 1.5k-2k whereas the AP kit costs around 3.5. Do you think that 2k-1.5k difference will be justified with the AP kit? Or will the DBA+fedoros+steel lines suffice? |
#4 | |
Drives: Attitude
Remember, the AP kit (the 4 pot, not the 6 pot) is hard-anodized and has no dust boots...street use in the SALT will destroy them. The 6 pot kit is bling bling; it certainly works, but you're going to need massive power to utilize those huge discs (that add weight!). |
#5 | |
I plan on using this car as a regular track, yet, high performance street vehicle. I just wanted some advice on which system i laid out in the previous posts is best value for money. And yes, the 6-pot kit is where i want to be (ideally lol), but considering that I have no plans on going forced induction for another 3 years (australian regulations regarding probationary/learner drivers prohibit the use of turbo'd/sc'd or high performance vehicles) i don't see the need for them
Drives: Attitude
Start with discs, pads, fluid, lines. If you need more, you know where to go!
alrighty then that settles it i guess, dba rotors + fedoro pads it is :P
#8 | |
Because compromise ®
Drives: Red Herring
May I ask where you got 4.5k? I work it out at around 3k with freight and tax. |
#10 |
Drives: Attitude
$3k holiday price or something. 3.5K USD regular price for the 6 pots. If you're not seeing salt, I'd consider the competition kit. I still suggest rotors, pads, and fluid first. Lines if you feel like it.
#11 | |
Also, I don't know what car modification classes you have over there, so you may also check and see what is allowed and what isn't if you plan on competitively racing. I can attest that a properly designed big brake kit is never overkill. However, depending on the racing type, a stock setup with upgraded pads and fluid will get you far. If you say you aren't doing any major power adders in the near future, it is safe to go the rotor/pad route, or even more economical pad/fluid route. |
