Old 12-06-2012, 03:18 PM   #1
xxscaxx
Drives: 2013 SWP BRZ
DIY - FnA Automotive Rear Fog Light (Kit 1) Installation
Tools:
10mm wrench (optional)
flat head screwdriver
Electrical Tape
Wire Puller (optional)
Dremel with grinding accessory
Drill
7/64 Drill bit or small Drill Bit
Step Up Drill Bit
Sharpie
Channel locks (to clamp down wire taps)
Included in the FnA Kit 1:
Two (2) Wire taps
Bulb with harness with positive and negative wires
IMPORTANT:This kit is for a working rear fog light ONLY. They offer two other kits with other options that require a slightly bigger drill hole and different wiring.
Step 1
This depends on what you want to do. I have an aftermarket exhaust, so the rear light is easily accessible to me. So I removed the light assembly so I could easily drill a hole inside my hose instead of doing it outside in the cold. If you decide to remove this, It is held on with two 10mm bolts, and two push clips. Unbolt, pop out the clips, and then you have to push the tab down on the bottom and pull the light assembly out towards you.
If you decide to skip this and do it on the car, Get the car up on jacks. I’m not too sure if you have enough room to do this with the stock muffler in place, you might have to drop it.
Step 2 – Shaving Down the Plastic
You must remove the plastic nub first that is located in the center of the drill spot.
Take a dremel and shave this down like so:
Dremel Bit used:
Step 3 – Mark & Drill
Now that you have the nub out of the way, take a sharpie and try to mark dead center.
I used a 7/64 drill bit but you can really use any size you want, just keep it small.
Pilot hole made
Now grab your step up drill bit. For Kit 1, you need to make a 11/16 size hole.
Drilled out hole:
Make sure to clean out any shavings you create inside the hole. Just turn it over and shake/smack it a bit.
Step 4 – Installing the Bulb
To install the bulb, simply stick the bulb in the hole you just made. Push and twist, and it should seat in there nicely.
Time to go back outside. Re-install the light if you chose to remove it. If not, You now need to wire the kit up.
xxscaxx is offline   Reply With Quote
Old 12-06-2012, 03:19 PM   #2
xxscaxx
Step 5 – Run the wires
For this kit, all you have to do is run the wires from the bulb harness up into the trunk and tap them into the driver side taillight harness. I chose to route the wires in the same hole as the reverse light harness goes through (I don’t have a pic of this, but all you have to do is trace the harness from the bulbs that are installed on either side of where you had to drill).
To get to this, you need to remove the trunk plastic where the latch is. Three plastic clips hold it in place, then you firmly pull straight up on it. (don’t have a pic of this but will get one).
Pop the three clips out on the driver side trunk liner (one near the edge of the trunk, and the two by the emergency trunk opener button – you don’t have to remove these two, but it gives you more room to work with.
Unclip the harness for the emergency trunk button.
Here is the rubber seal I ran the wires through, the same spot the reverse light harness comes through. I used a wire puller to get the wires through. I ran the wires right along the reverse light harness, and zip tied them to it, right up through the hole and through the seal.
Here is a pic of it back in place and taped up so you know where it is in the trunk.
Pull the wires through nice and snug, making sure you have some wiggle room below in case you ever need to pull the bulb out and replace it. Zip tie the wires to the reverse light harness.
Step 6 – Tap the wires
Unplug the taillight clip. This kit is simple – Red to red, black to black. Use the provided wire taps.
Step 7 – Re-Install the trunk liner clips and plastic trim
Self explanatory.. make sure when you put the plastic trim back you line up the clips underneath before pushing down. If you don’t, your going to break them. You also have to pull the rubber seal over the plastic trim once you pop it in place.
Step 8 – Your Done!
Installed PICS
Old 12-06-2012, 03:19 PM   #3
xxscaxx
reserved in case of more pics added
Old 12-12-2012, 09:40 PM   #4
F n' A Automotive
F n' A Automotive's Avatar
Drives: 11 STi Sedan
Kits will be posted in the private classified for sale section under exterior modifications.
F n' A Automotive is offline   Reply With Quote
Old 12-13-2012, 02:07 AM   #5
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Maybe a dumb question, but if it's a rear fog light kit how to do switch the fog off and on?
Phaedrus29 is offline   Reply With Quote
Old 12-13-2012, 07:04 AM   #6
F n' A Automotive
Our kits are wired up to turn on and off with the tail lights. We are aware that some people prefer to use the kits as they're meant to be used with a switch for foggy weather, but we just haven't pulled the trigger on putting together a switched kit. We consider that more of an advanced install, which would take away from how we sell our kit on being very easy to install. However, if we get requests for custom orders, we are always more than willing to work with the customers to fill them. We're currently working with a member here to create an actual FT86 rear fog/brake kit that will utilize the existing housing socket!
Old 12-13-2012, 08:37 AM   #7
F n' A Automotive
http://www.ft86club.com/forums/showthread.php?t=24188 Here is the link to our Vendor Page!
Old 12-13-2012, 08:41 AM   #8
wbradley
Sarcastic SOB
wbradley's Avatar
Maybe reword the title of the DIY to rear foglight converted to working brake light.
Old 12-13-2012, 03:41 PM   #9
xxscaxx
Its not a working brake light. It turns on with the lights, and acts as a fog light, but without a separate on/off switch.
Old 12-19-2012, 12:34 PM   #10
F n' A Automotive
bump
Old 12-19-2012, 04:22 PM   #11
BRaZinDave
BRaZinDave's Avatar
Drives: WRB Limited AT, 1965 COBRA,
I have Kit 2 and it was a simple project to do. Looks great!
Something I noticed, and maybe someone else has too or maybe F n' A knows about it: When lights are in AUTO mode, after turning off ignition the tail lights stay lit for a bit like they are supposed to but the Kit 2 light does not. Any reason why?
BRaZinDave is offline   Reply With Quote
Old 05-15-2014, 11:40 AM   #12
UltraMarine86
UltraMarine86's Avatar
Drives: Ultramarine '13 FR-S
@xxscaxx we're the pictures with their high output bulb or just the regular bulb the kit came with?
Sent from my SCH-I605 using Tapatalk
UltraMarine86 is offline   Reply With Quote
Old 05-15-2014, 12:30 PM   #13
xxscaxx
It was just the regular bulb, but then they ended up sending me an LED bulb because the one provided seemed to melt the housing..but I prefer the LED since its a bit duller than the regular bulb. The regular bulb was brighter than the rear lights, unless you stepped on the brake, then the light output matched.. so its a bit more even now that the LED is in there since its not brighter than anything else.
ZILLA: (How-To) *REAR FOG LIGHT WITH BRAKE LIGHT* MOD! ZILLA DIY (Do-It-Yourself) Guides 117 09-19-2017 10:17 AM
GT86 rear emblem installation pdf Silverback Cosmetic Modification (Interior/Exterior/Lighting) 3 04-08-2014 08:40 PM
Five Axis Rear Deck Spoilers @Pure Automotive Performance Pure Automotive Exterior Parts - The Rest 208 11-26-2013 08:23 AM
rear brake light in the rear fog light section FR-Shadow Cosmetic Modification (Interior/Exterior/Lighting) 34 12-13-2012 10:52 AM
REAR FOG LIGHT MOD FR-ser Scion FR-S / Toyota 86 GT86 General Forum 14 09-04-2012 05:57 PM
