Old 12-03-2012, 10:32 PM   #1
Craig
Craig's Avatar
Drives: Asphalt FRS
RPM dip in 3/4/5 gear (AT)
I'll start this off with info:
FRS purchased mid august
Perrin Drop in filter installed 10/8
Zeta intake pipe installed 10/12
Car has approximately 4.2k miles on it today (12/3/12)
Car has 'crickets' and will be brought to dealership to address both that and the rear tap from the trunk
This problem has been occurring prior to both 'mods,' and I have removed them to test to see if the problem persists, and it does.
When driving in paddle mode, I find my car exhibits a strange RPM dip in 3/4/5 gear during acceleration. Example: Pull behind tractor trailer in 6th, slow down momentarily, check other lane, downshift once into fifth, then again into fourth, and proceed to accelerate into the next lane in order to overtake said truck. Whilst pulling through fourth, around 4k rpm, the car loses a noticeable amount of power, (Torque dip I presume) and the RPMs will drop anywhere from 200-500 rpms, then continue to climb as normal afterwards. This is noticed not only through watching the tachometer, but also the engine loses a noticeable amount of sound through this range.
This would also occur if I'm in slower traffic, shifting into 3rd to pass someone or pull into traffic etc.
Happens in 5th if I'm driving at a higher speed in sixth, and drop into fifth to pick up a couple MPH for whatever reason.
I attempted to take a crappy cell video of it today to show here, but traffic was s**t so I was unable to 'open her up'.
Was wondering if anyone had any idea what's going on here, also if I should bring it up when I go to have the TSB on the crickets taken care of.
Thanks ^_^
~Craig
Craig is offline   Reply With Quote
Old 12-03-2012, 10:34 PM   #2
OrbitalEllipses
Drives: Attitude
Something similar happened to me in my WRX; I could reproduce it on the same stretch of road flawlessly. Never figured it out, but I'm interested in what you find out. Yes, my WRX was automatic.
Old 12-04-2012, 02:58 AM   #3
Craig
Craig's Avatar
Drives: Asphalt FRS
I'll be sure to post here when I find something out. Doesn't make much sense that I'd be losing RPM at all.
Old 12-04-2012, 03:18 AM   #4
Moshpit37
FR-S Owner!
Moshpit37's Avatar
Drives: 2013 FR-S Ultramarine 6AT
Pretty sure you answered your own question: it's gotta be the torque dip. I have experienced the same issue but just assumed it was a product of that terrible torque curve and didn't think much more about it, other than "damn that torque dip sucks!"
Frances - 2013 Scion FR-S in Ultramarine
Owner's Journal
Moshpit37 is offline   Reply With Quote
Old 12-04-2012, 10:47 AM   #5
Craig
Craig's Avatar
Drives: Asphalt FRS
Wow, that's honestly pathetic if the torque dip is that bad. I'm going to end up having to get a tune to smooth it out cause it pisses me off that much... I'm still going to bring it up at the dealership when I go in for the crickets, and if anyone else in here has any other ideas...shoot ^_^
Old 12-04-2012, 01:27 PM   #6
Lytheum
Drives: 2013 BRZ Premium 6MT
wait so the rpms are going down while accelerating? if so that shouldnt happen. around 4k i think you should be coming out of the torque dip. around 3-4k youll notice the car doesnt have as much get up and go(rpm's will climb, but slowly)
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 12-04-2012, 01:54 PM   #7
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
It's been my understanding that the torque dip happens from 3-4k revs.
Sent from my Nexus 7 using Tapatalk 2
Freeman is offline   Reply With Quote
Old 12-04-2012, 03:53 PM   #8
Craig
Craig's Avatar
Drives: Asphalt FRS
That's what I thought, the Torque dip shouldn't drop the RPMs. Even if I open the trottle more through this area the problem persists, so it's not an issue of throttle response, I can't imagine why the RPMs would fall during a climb unless there's an underlying issue.
Old 12-04-2012, 05:03 PM   #9
BRZranger
I get this too if I drop one gear to overtake or pass. Whenever I pass or need to accelerate I drop two or three gears.
BRZranger is offline   Reply With Quote
Old 12-04-2012, 06:16 PM   #10
Lytheum
is it shifting back up a gear on its own?
Old 12-04-2012, 06:51 PM   #11
developer
Drives: BRZ Limited
Maybe you have confused the ecu with your intake and filter mods. If it were me I would leave them off and reset the ecu by disconnecting the battery for 15 minutes. Then let the car idle for 15 minutes. Then drive it for about 50 miles before reassessing the RPM drop. This should allow the ecu to relearn. Good luck!
developer is offline   Reply With Quote
Old 12-04-2012, 07:01 PM   #12
normanb21
Drives: black frs
My car did this a few times to me also. while accelerating in 3rd around 4k it felt like the car would cut out for a split second and then continue to accelerate. After I switched to non ethanol gasoline,(at 600miles) it has not happened since and the crickets are gone too.(now at 1400miles) Im guessing it has something to do with the USA ethanol gasoline.
normanb21 is offline   Reply With Quote
Old 12-04-2012, 07:09 PM   #13
normanb21
Drives: black frs
Forgot to add that my car has no mods and also wondering if this only happens with the auto trannys then could it be a transmission problem? Maybe some type of slippage?
Old 12-04-2012, 07:17 PM   #14
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
I've had a similar experience but it's not consistent. It catches me off gaurd and I generally attribute it to the torque converter and transmission related logic programming. It's like the computer's not sure what to do and it's not in total lockup.
I think it may also have something to do with throttle position. Does that make sense?
What is the approximate throttle position?
Be interesting to get some logs. Now that I've seen this, I'm going to be more conscious of it and will look to see if I can duplicate. If so, I may run some EcuTek logs. That is, if I have time. The car will be garaged once the first snow/salt hits which could be any time now.
CircuitJerk is offline   Reply With Quote
Reverse Gear not going into gear? MT joergasm Issues | Warranty | Recalls / TSB 22 11-29-2012 12:08 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 08:39 PM
MT doesn't like 2nd gear Nubbs Issues | Warranty | Recalls / TSB 18 08-30-2012 08:15 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 01:21 PM
