Old 12-01-2012, 01:21 AM   #1
zooki
Drives: waiting on a 2021...
Bigger oil filter?
Had anyone sourced a larger oil filter for our cars? I've always figured the more filtering the better, especially now that the oil change intervals can be extended with the newer oils. It seems there is plenty of room for a taller filter under the hood. Any ideas?
zooki is offline   Reply With Quote
Old 12-01-2012, 07:51 AM   #2
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
I assume that you'd have to add more oil as well
dori. is offline   Reply With Quote
Old 12-01-2012, 08:18 AM   #3
whaap
whaap's Avatar
The bigger the filter the harder and longer it will take for the oil to go thru it unless you make the filter material thinner and then you haven't accomplished anything.
whaap is offline   Reply With Quote
Old 12-01-2012, 08:57 AM   #4
choi0706
Drives: t
canton mecca
choi0706 is offline   Reply With Quote
Old 12-01-2012, 09:31 AM   #5
zooki
Umm, I would think more surface area equals less restriction?
Old 12-01-2012, 03:06 PM   #6
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Once you black.....
The Following User Says Thank You to rice_classic For This Useful Post:
flippy (12-07-2012)
Old 12-01-2012, 03:14 PM   #7
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Originally Posted by rice_classic View Post
Once you black.....
Lol, didn't know our cars were trucks now.
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 12-02-2012, 01:20 PM   #8
zooki
If I could find one that size and it fit I would run it.
Old 12-02-2012, 08:24 PM   #9
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
OEMs are using smaller filters. Less volume to fill, and newer designs and materials have a lot less restriction. Using a smaller filter means oil gets to critical engine parts a lot faster, and even the smallest filters will far outlast the oil.
Use a quality filter. Having all the filtering capacity possible isn't going to help you if there is no debris to catch. If you look at the current trends from OEMs, the filters are getting smaller and smaller, and oils are getting thinner and thinner. It all comes down to efficiency, and there are numerous reasons why decisions like this are made. But by all means, if you want a big black filter on there... be my guest. I won't judge :P
Coheed is offline   Reply With Quote
The Following User Says Thank You to Coheed For This Useful Post:
AZP Installs (12-02-2012)
Old 12-02-2012, 11:02 PM   #10
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Agreed, we found the OEM Subaru filters to work just fine even on 7000 mile intervals as per the UOA that we ran on them. Beyond 7000, we found the Amsoil filters to be better.
-Mike Paisan
11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts.
Call directly as We carry almost every manufacturer now, so before you buy parts call us.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
AZP Installs is offline   Reply With Quote
The Following User Says Thank You to AZP Installs For This Useful Post:
SXE10 (12-04-2012)
effects of bigger wheels-video 315FR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 07-01-2012 09:50 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
Getting Bigger phenoyz Scion FR-S / Toyota 86 GT86 General Forum 4 05-30-2012 09:22 AM
Bigger Muffler Tips? dookie11 BRZ First-Gen (2012+) — General Topics 45 03-12-2012 06:37 PM
