| Member's Car Journals Car journals by our members. |
Drives: '84 MA61 Supra, '88 Mercedes 500SEC
My 7MGTE MA61 Supra
Delete this if it's irrelevant:
Well I bought it like this, with a 7MGTE and full 3" exhaust from the turbo back. ![]() I put the unpainted front nosecose back on for RWC and rego. http://img82.imageshack.us/img82/7619/buffy3jo0.jpg Then it blew it's 3rd (this one being metal) headgasket. After some time someone decided it was cool to run into me. http://img247.imageshack.us/img247/3010/p1060087zj9.jpg Thankfully for insurance, it then looked nice! ![]() Then I added a bigger intercooler and Ed's old brake and wheel pack: ![]() Then it had all the paint and interior ripped out, and became this: ![]() ![]() ![]() Then after three years, at Sandown the 4th headgasket went on the back straight at just over 200km/h. So the engine was fully rebuilt w/ forged pistons and a full balance. New everything... Plus I did most of the work myself which was great fun. 1984 Toyota Supra 7M-GTE W58 5 speed New headgasket with aftermarket bolts and the proper torque New Engine specs: 2990cc 7MGTE Arias Forged Pistons (Std size) ARP Head Studs ARP Rods Bolts 8.4:1 Compression ratio Fully balanced pistons, crank and rotating assembly Cometic Multilayer metal headgasket Gates Racing Timing Belt ACL Race series bearings New Timing belt idler and tensioner pulleys New Water pump 600x300x76mm intercooler 2.5" flowed aluminium piping aluminium Cold air induction in box in front guard Full 3" exhaust and dump pipe Exedy 5 puck sprung-centre button clutch 7MGTE flywheel redrilled, dowelled and balanced to fit Custom throwout yolk and assembly Speco Boost, Oil pressure and Oil Temp, mounted in din position.... Highflowed CT26E Turbo Bosch Blow off Valve Previous setup : Greddy Profec B @ 12psi Apexi SAFC II Standard AFM RC Engineering 550cc injectors 227rwkw @ 5830rpm Current setup: Haltech E11v2 EMS 15psi Very conservative ignition timing 800cc SARD injectors 3" Straight through lukey muffler 236rwkW @5900rpm, 592Nm @ the engine from 3200-5000 rpm. Flat as Rolling stock: Polyurethane bushes KYB AGX adjustable dampers 7kg/mm coilover springs (Front) 4.7kg/mm custom AJPS springs (Rear) 17x7.5" +0ET BBS deep dish wheels Front and Rear Whitelight adjustable swaybars Truetrac 3.9 LSD diff New and balanced tailshaft Kelway strut brace "Ed's" Brake setup: Front Brakes: MS65 Front hubs 326mm DBA T3 4000 series rotors Bendix Ultimate pads 4-piston Alloy Calipers RA60 Strut tubes for 2deg. Negative camber Rear Brakes: MS123 Rear hubs 308mm UZZ30 Soarer rotors Bendix ultimate pads 2 piston GTR calipers Custom setup for stock handbrake Interior: Swap for Black stripey interior Momo Course steering wheel with custom celica dragon badge Custom new gearboot Exterior: Colour change to Black Internal aerial 3.0 turbo badge on grille 3.0i decal on rear of car Windows tinted dark as legal Fully engineered and legal What is left to do: Well it finally blew the W58, so I am going to puta new one in, lower the boost to 12psi and possibly add a 3.58:1 diff ratio in. Then the rear camber kit Then 4x 235/40/17 Direzza Star Spec tyres Then, hopefully, finished ![]() Here are all my other videos of the car. All of which were done on the racetrack or a private road. I am not a hoon..... . http://www.youtube.com/view_play_lis...5C1B3CF23E4090 ![]() ![]()
- 1988 Mercedes-Benz 500SEC - 200kW Euro Luxury
- 1984 7MA61 Supra - 300kW/600Nm - 1983 JZA61 Supra - 2JZ screamer - Sold :'( - 2012 ZN6 86 GTS - Hopefully coming in 2012... |
Drives: Moped
Good choice on the color change
wheel gap
Drives: whiteout frs, 04 xrs
awesome!!
Night Owl
Drives: 2013 Subaru BRZ
Such a clean MK2! I've always liked the 7M-GTE over the 2JZ..there's just something special about that motor that I can't put my finger on. Take good care of her!
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
Looks good and sounds great.. I've always been a fan of the older supra's
Señor Member
Drives: white BRZ 6MT
that's sexy man. love it.
but sorry had to LOL at the M series being legendary for blowing headgaskets
Drives: 83 Toyota Supra, 16 FR-S RS2.0
Nice, I keep my MkII as a stock/daily driver, wish I had the time to do similar to yours. Mine needs a respray soon, I'm gonna use the Hot Lava color. BTW, your wheels look fantastic!
Eric G |
Drives: White Out FR-S
Beauty, I had a blue/navy two tone MK2 with a 7M-GTE swap myself. I sure miss her.
Black Blood of the Earth
Drives: The Porkchop Express
Interior and engine bay shots?
It's all in the reflexes.
#10 |
Drives: Asphalt Scion Frs 6MT
I love it almost bought one... would love to own was a project, does yours have the hand pumped lumbar support and the wired flashlight? I love the gadgets this car had
#11 |
I love me some MKII Supra! Yours is nice!! Sounds like it's fast and well-sorted, too! I thought about getting one and swapping a 3SGTE into it, but then the twins came out and I stopped wanting to mess with old cars.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#12 |
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Love what you've done to the car. Dont like the engine though, hated my MKIII just for the engine that was driving me mad. Well, on the otherside, my MKIII was not well maintained by the preowner, so I guess your engine will be better :-)
The wheels and the color just matches perfectly the 80s badass look. Please look well after her, cars like that should stay on the road forever
My GR86 Car Journal: https://www.ft86club.com/forums/showthread.php?t=153879 My old GT86 Car Journal: http://www.ft86club.com/forums/showthread.php?t=22222 |
#13 |
Thanks guys.
Yeah I will dig up some engine bay/interior shots. It's basically just stripey black standard interior - with pneumatic lumbar support pump and all ![]() The idea was a car that looked fairly stock, but performed far from it... I just need to get this gearbox fixed so I can drive it again!
| what would be a better buy new frs or used mk4 supra | supramaster12 | Scion FR-S / Toyota 86 GT86 General Forum | 81 | 02-28-2013 02:47 PM |
| New Supra and Sub-86? 12/4/2011 | Zaku | Other Vehicles & General Automotive Discussions | 46 | 12-12-2011 03:36 PM |
| Girl in a Supra... | Nerfie | Off-Topic Lounge [WARNING: NO POLITICS] | 14 | 11-03-2011 06:06 PM |
