View Poll Results: Which car will be most comparable to the FT-86/FR-S/BRZ?
370Z 4 2.55%
MX-5 Miata 59 37.58%
Genesis Coupe 8 5.10%
RX-8 66 42.04%
G37 0 0%
BMW 1 Series 7 4.46%
Other 13 8.28%
Voters: 157. You may not vote on this poll
Old 11-18-2011, 07:18 PM   #1
cassidy0998
cassidy0998's Avatar
Drives: '99 Ranger / '94 APU Supra / Ninja!
Which car is most like the FT-86/FR-S/BRZ?
Which car that's currently on the market do you feel has the most in common with the FT-86/FR-S/BRZ in terms of price/performance/looks etc. If you had to pick one car to compare it to, what would it be?
Or simply put, what will its closest rival be?
cassidy0998 is offline   Reply With Quote
Old 11-18-2011, 07:59 PM   #2
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
370z - Two seater 300hp+ pure sports car
MX-5 - Two seater convertible
Genesis Coupe - HEAVY RWD 2+2 with a bit of power
RX-8 - Midweight 2+2 with a low-torque Rotary
G37 - Expensive 2+2 Luxury RWD coupe
BMW 1 series - Expensive RWD compact car
RX-8 is really the only thing close, but its also going to be more expensive not to mention soon to be discontinued.
The MX-5 and Genesis coupe compete pricewise and will be the more direct competition.
The 370z is basically a setup up from the BRZ/FRS while the 1-Sieres and G37 are higher end cars and won't directly compete.
However, I wouldn't be surprised if people cross shop ALL of these cars...
Kostamojen is offline   Reply With Quote
Old 11-18-2011, 08:06 PM   #3
Neutral_Eyes
Softparker
Neutral_Eyes's Avatar
Drives: 2002 Mazda Miata
RX-8 or Silvia.
Neutral_Eyes is offline   Reply With Quote
Old 11-18-2011, 08:07 PM   #4
fatoni
the rx8 has more torque than the frs
Old 11-18-2011, 08:19 PM   #5
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Currently on the market, I believe it'll be the Genesis Coupe 2.0T
Old 11-18-2011, 08:21 PM   #6
Kostamojen
I said low torque, not less torque :p
The torque/HP ratio of the RX8 makes it more similar to the BRZ/FRS than the power numbers from the other cars.
Old 11-18-2011, 08:50 PM   #7
coyote
coyote's Avatar
Drives: Slowly
No contest - RX8.
coyote is offline   Reply With Quote
Old 11-18-2011, 09:04 PM   #8
Eldorian
Drives: 04 RX8
I vote RX 8.
Slightly bigger, slightly more powerful (to weight), slightly more practical (no idea here really, never seen an image of someone in the backseat of a Toybaru), but closest overall.
As a current RX8 owner, I'm considering the BRZ only if the back seat is usable for an average sized human male. If you can fit a 180 pound, 5 foot 11 man in the back (which you can easily in the RX8) I might be getting a new car.
Edit: Also, the driving position must be lower slung. I owned a Miata before the RX8 and I miss the driving position most of all.
Eldorian is offline   Reply With Quote
Old 11-19-2011, 12:26 AM   #9
cassidy0998
I pretty much agree with what you guys have said above. I too went for the RX-8. 2+2, price looks like it will probably be fairly close, more of a driver's car than a stoplight monster.
I know that the 370Z is a $30k+ car, but we don't know the price range yet, so I had to throw it in there. And since I threw the 370Z in there, the G37 is essentially a 2+2 version.. (even though much more expensive) so it went in as well.
Anyway, long story short - I've just heard a lot of people comparing the FT-86 to these cars. I tried to make the most realistic rivals list as possible.
What makes it kind of interesting though is that the RX-8 will have its final year (in the US) in 2013. What would be next on the list?
Old 11-19-2011, 12:55 AM   #10
Harinjo
Harinjo's Avatar
Nissan S13/S14
Harinjo is offline   Reply With Quote
Old 11-19-2011, 09:19 AM   #11
spin9k
spin9k's Avatar
Drives: RX-8
RX-8 obviously. It's the only 2+2 with similar power/weight. Be interesting to have a go at the track ... one day next season ... will it be close or not? Anyone wanna place a bet????
spin9k is offline   Reply With Quote
Old 11-19-2011, 10:33 AM   #12
MrVito
Grumpy Old Man
MrVito's Avatar
Drives: 2016 Halo FR-S, 2010 Tundra, 80 626
Though I voted RX8, since that seems to be the closest in performance for a new vehicle, I agree with the folks that said s13/s14. Though I would have to specify the Silvia K's/180sx. With an SR20DET in stock form, you're looking at very similar weight and power numbers to the FR-S/BRZ. Now the SR20DE and KA24DE powered s13/s14, no way, not even close.
BRZ/FR-S:
2570mm Wheelbase
4240mm Length
1285mm Height
1230kg
147 kW (200ps / 200hp) @7000rpm
151 lb-ft (205 N-m) @ 6600rpm
S14 Silvia:
2525mm Wheelbase
4498mm Length
1288mm Height
1253kg
162 kW (217 hp) @ 6000rpm
203 lb-ft (275 N-m) @ 4800rpm
(and as a fun note, both use a bore and stroke of 86mm X 86mm)
Then take into account the lower CoG, better weight distribution, of the FR-S, I would wager that performance numbers will be better than an S14 in the handling department, and trailing slightly in acceleration. Though a lot of that also depends on transmission and rear end gear ratio. Silvia's used a 4.08:1 rear end, not sure what the Subiyota will have.
2016 Halo FR-S, 2010 Tundra, 92 325i convertible, 80 Mazda 626, 62 Impala
MrVito is offline   Reply With Quote
Old 11-19-2011, 12:10 PM   #13
blur
ლ(ಠ益ಠ)ლ
blur's Avatar
Drives: E36 5.7 V8
I for one would say miata. RX8 is a close second... but typically weighs much more, has four doors, and has a slightly bigger base sticker price than FR-S.
I would call the FT-86 a Miata coupe.
I wish I was cool enough to have an FR-S
blur is offline   Reply With Quote
Old 11-19-2011, 06:42 PM   #14
Allch Chcar
Drives: N/A
RX-8 is the closest on that list, IMHO. The SR20DE N/A and Turbo Silvias are similar too.
The RX-8 is also a higher revving engine, at least in the high-output manual version. The pre'09s had 4.444 gears and the '09+ all have 4.777 gears. Though it is much heavier, 2012s curb at 3100lbs now.
I would bet the RX-8 would win most any race. But everywhere else including the DD kind of stuff, I am expecting/hoping the FT86 twins to beat it in all categories.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
