Old 11-13-2012, 01:39 PM   #1
xxscaxx
Drives: 2013 SWP BRZ
DIY - Password:JDM Carbon Fiber Engine Cover Install
I was fortunate enough to be able to grab this piece fairly quickly from Password JDM. Its pretty easy to install but I figured i'd make a thread anyway.
Tools you will need:
socket wrench
10mm socket
extension
5mm Hex Bit socket (or regular 5mm hex key will work)
You should have received the engine cover and two new bolts with shiny and nice machined washers (I received gold as I ordered a bolt kit in all gold and gold strut bars).
Step 1) Unbolt Noise Generator - take your socket wrench and 10mm socket with an extension and unbolt these two bolts holding the noise generator down.
Step 2) Disconnect hose from Noise generator, tuck away generator for easier work area - Simply pull off this hose below, and tuck the hose end under the strut brace. you can then take the noise generator and tuck it in front of the fuse box like so.
Step 3 - Remove 10mm bolt on Fuel line bracket - You will be replacing this bolt with the included bolts. Place this bolt to the side. The other bolt will go into the empty hole on the black bracket underneath this fuel line bracket towards the back (thought I took a picture of this, you will see it regardless once you get the cover on)
Step 5 - Install cover - Now that the necessary bolts and items are out of your way, its time to install the cover. Its a tight fit, but it goes in. The easiest way to do this is start by sliding the cover UNDERNEATH the AC hose (the hose pictured above where I told you to remove the bolt from the fuel line bracket). If you try to install the other side first (like I did lol), you won't be able to pull the ac line up and over it without trying to bend the cover and thats the last thing you want to do.
Once you get the line above the cover, you want to install it at an angle, like so :
The reason is because you need to clear this bracket on the noise generator side:
It will want to hit but you can manage to get it in there if you put it in properly. Once you clear that bracket, it should go right into place with a little wiggling.
cover sitting in after clearing that bracket:
Step 6 - Re-Install Noise Generator - Reconnect the black hose to the generator, and then line the generator back up and bolt it back on. the cover goes UNDER the noise generator, and you use the same stock bolts. No bolts are supplied for this side.
Step 7 - Install supplied bolts on driver side - Grab the two supplied bolts and install them into their allotted holes. This is where you need the 5mm Hex key or socket.
[IMG]http://i15.photobucket.com/albums/a393/xxscaxx/Password%20JDM%20Parts/F092183D-36E1-47D4-9CE6-8866***2CEC9-14568-000005D01DD3C8BA.jpg[/IMG]
Step 8 - Stand back and enjoy your new cover Here you can see the two supplied bolts installed on the driver side.
xxscaxx is offline   Reply With Quote
Old 11-13-2012, 01:40 PM   #2
xxscaxx
I know someone will ask, so heres a shot of the clearance between the cover and the stock inlet.
another shot:
Old 11-13-2012, 01:58 PM   #3
gmookher
how much and where does one get one?
gmookher is offline   Reply With Quote
Old 11-13-2012, 02:02 PM   #4
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
That is incredibly sexy. A carbon fiber intake tube would really set this off (ala the one Airaid used in their SEMA car).
Old 11-13-2012, 02:35 PM   #5
Mari0
Car Enthusiast
Mari0's Avatar
Drives: tC 05 & 07, Rav4
that :happy0180:
Mari0 is offline   Reply With Quote
Old 11-13-2012, 02:41 PM   #6
OrbitalEllipses
Drives: Attitude
Slicker looking than when I initially saw pictures. Almost want to make another frivolous purchase...
Old 11-13-2012, 02:57 PM   #7
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Will this fit with an injen intake?
Chen is offline   Reply With Quote
Old 11-13-2012, 02:58 PM   #8
Turbowned
Turbowned's Avatar
That looks immensely better than stock! Now you just need an intake and a strut bar to complete the look. Or a supercharger, jussayin'
Old 11-13-2012, 03:13 PM   #9
password:jdm
password:jdm's Avatar
Drives: 2013 Subaru BRZ
xxscaxx, you my friend, are the man!!!! Thanks for the awesome write-up!
Btw the cover works with the injen intake and most of the aftermarket intakes on the market.
password:jdm is offline   Reply With Quote
Old 11-13-2012, 03:39 PM   #10
xxscaxx
hehe
No problem! I will get to the Strut bar writeup soon. I wanted to also put together a little guide for the dress up kit as well.
For those asking where to buy: http://www.ft86club.com/forums/showthread.php?t=21043
Old 11-13-2012, 04:07 PM   #11
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Looks good! Still debating between this and the kevlar model
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 11-13-2012, 07:30 PM   #12
OrbitalEllipses
Drives: Attitude
Kevlar.
Old 11-13-2012, 10:38 PM   #13
Dezoris
Dezoris's Avatar
I wanted this until I thought about how much heat it will trap in the intake manifold. Thoughts?
Thanks for the DIY BTW.
Old 11-13-2012, 11:40 PM   #14
Luke.Cariveau
"Fast Looking Slow Car"
Luke.Cariveau's Avatar
Drives: 13' BRZ
Wow! Look's amazing.
Luke.Cariveau is offline   Reply With Quote
Carbon Fiber-patterned Key cover... FR-S/GT-86 Cosmetic Modification (Interior/Exterior/Lighting) 10 07-25-2012 11:21 AM
