Old 11-13-2012, 11:15 AM   #1
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
2014 Scion FRS engineering protoype.
http://www.roadandtrack.com/tests/dr...ring-prototype
Defined by its chassis balance and agility, the Scion FR-S has rediscovered driving fun we presumed long lost in the rubble of emissions control and health-and-safety chassis settings. This generic-looking two-plus-two coupé was devised as a result of a Toyota board meeting a decade ago, which had the single agenda of restoring the appeal of cars to young people. This old-school, rear-drive sports car, nicknamed 'Hachiroku', was the result and the rumor machine is predicting a drophead version before too long.
Turbo or Not?
The FR-S is produced in collaboration with Subaru (its model is called the BRZ, Toyota’s model is the GT86). Priced at $25,000, the FR-S uses Subaru’s 2.0-liter, flat-four-cylinder engine to lower the center of gravity, but with Toyota’s most advanced D-4S direct-fuel-injection system to up the power and torque to 197 bhp/151 lbs.-ft. Performance is modest, top speed is 140 mph, 0-60 mph in 7.6 sec, but in handling terms, this car matches and arguably surpasses models such as Porsche’s Cayman at twice the price.
And they can’t build them quick enough. Tetsuya Tada, the car’s chief engineer admits that some countries have a ten-year waiting list, even the Australian customers are going to have to cool their heels for three years.
“It’s a ridiculous situation,” he says.
It’s not the only thing requiring his attention. “One of the most common calls I have had”, he says “is for a turbo, but I have been hesitant about increasing power and torque.”
He’s right to hesitate. The FR-S sells itself on low-cost thrills and extra power would start an upward spiral of weight and price. What’s more over the next two years, Toyota wants to introduce a couple more sports cars, which will bracket the FR-S in price and power. Increasing the engine power too much would bring FR-S into contention with what Tada-san admits will be a new Supra model.
In fact, a turbo would be difficult to engineer for the Subaru flat-four-cylinder engine without seriously raising the center of gravity and Tada-san’s team is investigating other options. These include a supercharger, boring the engine beyond its 2.0-liter capacity and a hybrid system completely redesigned from the Prius THS system, which could also be used by Toyota’s Lexus brand. A test model FR-S is running in Japan with such a system, which uses the high-torque electric motor output to boost the engine in a similar way to Formula-One kinetic energy recovery systems. Tada-san also wants to reduce the weight of the FR-S by at least 220 lbs., although he says that greater weight savings than that will require the use of exotic and expensive materials.
Testing the Performance Enhancements
While performance enhancements are on test, we were recently given access to some of the chassis developments, which Tada-san is keen to introduce next year. These include 18 inch BBS aluminum wheels with Michelin 215/40/ZR 18 tires, an inch larger in diameter and five percent lower profile than the standard Prius tires that the FR-S normally runs on. There’s a body and rear wing aerodynamic kit, which mirrors the one supplied by TRD. The limited-slip differential is changed from a Torsen B of the standard car to a mechanical plate type and there’s a 4.3:1 differential as opposed to the standard car’s longer 4.1:1 diff.
Tucked discreetly into each B pillar are new door catches and B-post stiffeners, which have a more positive closing on a panel strengthened with either aluminum, carbon fiber or plastic. The effect is to turn the doors into part of the stressed structure. Toyota is also working on adjustable Sachs damper units, which weren’t fitted to the test car and Bridgestone and Dunlop are developing a unique set of tires for the FR-S. “We made no requests of them,” says Tada-san, “we just said give us something good.”
You’d be blind to miss that rear wing, which looks fresh off the set of Too Fast Too Furious. It’s part of a series of aero improvements that reduce drag and increase downforce although Tada-san says the FR-S aerodynamics are more complicated than that. He points to a complex series of tiny fins over the body which creates a wall of turbulence “that softly embraces the car”. He says this ‘wall’ effect contributes as much to the FR-S’s handling as the suspension or tires, and can be felt from speeds as low as 25 mph.
After criticism that the standard model sounds like a washing machine, the new free-flow exhaust is pretty fruity, but it’s a droning buzz and it won’t take long to tire of it. There’s not much changed in the cabin except for a natty set of TRD ancillary instruments, which take the place of the standard sat nav.
The Cost of Higher Speeds
Get out on the Spanish race circuit and you quickly feel the differences in the car’s behavior; the tires being most noticeable. They point into the turns more sharply than the standard covers and it feels as though the car is turning around your backbone, which is a classy combination. But there’s a cost and that’s because you always drive to the apparent grip. So while this development model holds on better than the standard car, you have to drive it with greater precision. At high speeds the back end tries to get away from you quite suddenly and while the new limited slip differential gives better control, you can’t help thinking that the standard car is more fun.
The other cost of the higher speeds is that the unmodified swinging-calliper disc brakes in the development car start to creak under the strain of repeated fast laps. The TRD performance upgrade package includes the option of larger vented disc rotors and monobloc callipers, which are well balanced and fade free.
The development car felt stiffer and rode better than the standard FR-S and Tada-san suggested this might be to do with the remarkable door stabilizers, which he eventually sees as being part of an individualization program, where customers can tell their dealers about their driving style and the door stiffeners are tweaked to suit.
The Bottom Line
You might wonder what on earth Toyota is up to, messing with the FR-S winning formula less than a year after its launch. Fact is, however, sports coupés are fashion items and fickle buyers don’t keep them on top for very long. The pot has to be kept boiling to attract new and repeat purchasers and that’s what Toyota is doing here. The tires are a mixed blessing (tell us something new here), the door stiffeners are interesting and the exhaust still needs work to sound more sporty and interesting. But in the end, the standard FR-S is such a remarkable car that it’s difficult to better.
Just when you’re thinking that, however, Tada-san points out that customers are already demanding chassis upgrades and more power and while the TRD after market upgrades are available, they are very expensive. The modifications on the TRD performance car we drove, would cost well in excess of $20,000, yet the development car, complete with uprated Sachs dampers would retail for about $26,000. That’s compelling argument enough in itself.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
The Following 16 Users Say Thank You to feldy For This Useful Post:
ApoNono (11-13-2012), bestwheelbase (11-13-2012), Chad (11-13-2012), cobrabyte (11-14-2012), Dadhawk (11-13-2012), Freeman (11-13-2012), GMT (11-15-2012), Guff (11-13-2012), M&M_Hwy9 (11-13-2012), PrDarkKnight (06-29-2013), racecaresuaceb (03-31-2013), Snoopyalien24 (11-13-2012), SuperDave (06-29-2013), SVTSHC (11-13-2012), tomato86 (11-15-2012), vh_supra26 (11-13-2012)
Old 11-13-2012, 11:19 AM   #2
RaceR
Drives: 2010 Cooper S, 74 Beetle
I was considering to post this again. The previous thread disappeared even tough it was active.
Lots of good news here if you ask me!
RaceR is offline   Reply With Quote
Old 11-13-2012, 11:58 AM   #3
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
If they are already looking to change the model next year then our current year will become pretty rare. I'm not sure if I'm a fan of that rear wing.
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 11-13-2012, 12:09 PM   #4
Razz
Razz's Avatar
Drives: Fast
It's an option package.
You can still get the regular FRS
Razz is offline   Reply With Quote
The Following User Says Thank You to Razz For This Useful Post:
SupraLove (11-13-2012)
Old 11-13-2012, 12:16 PM   #5
Tanuki
Turtle Factory
Tanuki's Avatar
Drives: Mint M3
"There’s not much changed in the cabin except for a natty set of TRD ancillary instruments, which take the place of the standard sat nav."
I think the article has too much crossover between GT86 and FRS and really doesn't define what the FRS will get specifically when compared to the GT86.
Tanuki is offline   Reply With Quote
The Following 4 Users Say Thank You to Tanuki For This Useful Post:
Chad (11-13-2012), Guff (11-13-2012), Saber_TRD (11-13-2012), SVTSHC (11-13-2012)
Old 11-13-2012, 12:27 PM   #6
pr086
Drives: fast
thats what i was thinking. no telling what we'll actually see on the FRS.
pr086 is offline   Reply With Quote
The Following User Says Thank You to pr086 For This Useful Post:
Guff (11-13-2012)
Old 11-13-2012, 01:05 PM   #7
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
"Tada-san also wants to reduce the weight of the FR-S by at least 220 lbs"
that is super nice
DuMa is offline   Reply With Quote
The Following 5 Users Say Thank You to DuMa For This Useful Post:
bestwheelbase (11-13-2012), Chad (11-13-2012), Guff (11-13-2012), Snoopyalien24 (11-13-2012), SVTSHC (11-13-2012)
Old 11-13-2012, 01:12 PM   #8
Dezoris
Dezoris's Avatar
Where are they going to cut 220lbs? The car is already a tin can.
The Following User Says Thank You to Dezoris For This Useful Post:
Tanuki (11-13-2012)
Old 11-13-2012, 01:22 PM   #9
pr086
Drives: fast
that is super nice
this is the only thing i'd be pretty upset about if i were a year 1 buyer.
The Following 2 Users Say Thank You to pr086 For This Useful Post:
cobrabyte (11-14-2012), Tanuki (11-13-2012)
Old 11-13-2012, 01:28 PM   #10
Borgore
Enthusiast Member
Borgore's Avatar
Drives: Toyota FT86
I think the car was put back into public prototyping for the next model year too early. Either they want to make the car a lot better than the previous year or they want to continue the hype and build something with performance in mind.
Borgore is offline   Reply With Quote
Old 11-13-2012, 01:33 PM   #11
HunterGreene
Hail Magnet
HunterGreene's Avatar
More Aluminum panels would be the first thing I would think of, though how that would affect safety ratings I don't know.
Interesting article!
Old 11-13-2012, 01:33 PM   #12
pr086
Drives: fast
it was kind of hinted at in the article, but i would hate for the fun and feeling that is getting such great reviews from the 2013 model to be dulled
Old 11-13-2012, 02:12 PM   #13
Mari0
Car Enthusiast
Mari0's Avatar
Drives: tC 05 & 07, Rav4
Wasn't there an interview with Tada-San saying that ALL future upgrades will be available as add-on options to previous buyers (to show the early adopters that they care basically).
My guess is, we will finally get some of the TRD goodies the rest of the world enjoys. They are all add-ons.
Mari0 is offline   Reply With Quote
The Following User Says Thank You to Mari0 For This Useful Post:
Old 11-13-2012, 02:17 PM   #14
jesperswe
Drives: GT86
That's what i like most here
jesperswe is offline   Reply With Quote
The Following 3 Users Say Thank You to jesperswe For This Useful Post:
bestwheelbase (11-13-2012), Guff (11-13-2012), Shagaliscious (11-13-2012)
JDP Engineering FRS CF Front Lip howiedoit Cosmetic Modification (Interior/Exterior/Lighting) 94 03-26-2017 02:32 PM
2014 Scion FR-S Convertible rendering wrxgoose FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 38 09-15-2012 07:19 PM
Freed Engineering FR-S FreedE Member's Car Journals 28 08-01-2012 12:54 PM
Edmunds 2014 Coolest Cars 2014 FR-S Convertible Wizneber Scion FR-S / Toyota 86 GT86 General Forum 21 07-26-2012 08:51 PM
