Old 11-09-2012, 10:31 AM   #1
dawnst3ar
Drives: 2013 MT FR-S Asphalt
BRZ style spoiler on an FR-S
SO, I have to admit, I am a little nervous. I ordered a pre-painted BRZ-like spoiler last night to put on my FR-S. After calling a few body shops, no one is willing to do the work for me, so I will be doing a ste-by-step in this thread for you all when it comes in. In the meantime, does anyone have any tips for me?
By the way, I ordered it from carid.com, and paid $300.25 US for it. Comes with a three year warranty, and is supposed to have excellent instructions included:
http://www.carid.com/2013-subaru-brz...er-961541.html
I figure I saved at least $150.00 this way.
https://www.subaruonlineparts.com/pr...8ce2108391f058
Ok, it has been added to the car, here we go:
The spoiler came in a large box, and when I opened it, we found this:
I flipped it over to show the screws:
In the lid of the box, you will find some t-strips, along with VERY rudimentary instruction on installation:
From here, my next step was to find the tools I needed to do the job:
My trusty drill, with a 1/8" bit, a hex driver that fit the screw heads, my step-drill bit, masking tape, and silicone sealant.
*Not shown* touch up paint I got from Subaru just before this all started.
Now it was time to get to work.
The first step was to take the screws out, but I noticed something:
The strip around the outside edges was not in place. Poor quality control, if you ask me. I carefully pulled it all off the spoiler and placed in back the way it should have been, around the outside edges. Once this was done, and all the screws were removed, I began installing the t-strips:
Now, this bit is important ****MAKE CERTAIN THAT THE STRIPS ARE FLUSH IN THE HOLES.**** If you don't, the spoiler will not fit right, and I think you will end up with bad spacing when you drill. also, you MUST remove all the screws from the underside of the spoiler, or they will
A) scratch the crap out of your hood when you are fitting it onto the car
B) again, the fit will not be right when you put it on there.
Also, you might note that I did not put strips in all the screw holes. This was another quality control issue - they simply didn't send enough strips, and I felt that four would hold it just fine.
Once you have the tstrips in the holes tape them in place:
Now, take the whole thing and set it on the trunk. Work out the fit carefully - make sure that you have it lined up the way you want, and tape the tstrips to the trunk to hold them in place
Double-check, triple-check, and check it again just to be sure. Once you are sure that it EXACTLY where you want it, remove the spoiler, taking care to leave the strips behind:
Now, be afraid, be very afraid:
Take a deep breath, carefully insert the 1/8" drill bit into the t-strip holes and drill away:
Once this is done, remove the tape and the strips. (You can exhale now, too, BTW)
Next, take the step bit and de-burr the holes. This should give you a nice clean screw hole.
Now pop the trunk. Look at the holes you have created. On either edge of the lid, you will see that the holes went through a second layer of metal. The screws aren't long enough to reach all the way through, so you will need to use the step-bit to make them large enough to be able to put the screws through to the spoiler.
Now, line up the spoiler holes with the ones you have made and screw it all down. I will warn you, the screws that I was sent were slightly larger than the 1/8" holes, so you will need to use a little elbow-grease, and you will have to expand them a bit to get through. Take your time on this part, and you will make it through.
Now, you have installed the spoiler, and all that is left is the cleanup. Cover the exposed screws with the silicone to lock them in place, and to lessen exposure to air/water.
Also, hit each of the big holes you made with some touch-up paint to cover the bare metal you exposed in drilling through the sheet metal. Close the trunk and step back to admire your handiwork:
I hope this helps you all. I will say that while I did not think the quality control was great from the manufacturer, I do think that the fit was perfect. The paint matches perfectly, and it looks really good, imho.
dawnst3ar is offline   Reply With Quote
The Following 2 Users Say Thank You to dawnst3ar For This Useful Post:
BabaYaga (08-29-2014), zoomzoomers (12-26-2012)
Old 11-09-2012, 10:57 AM   #2
White64Goat
I would assume that it will come with templates for drilling any holes. Just double/triple check before drilling, especially on curved areas. Remember to use touch up paint on the drilled holes before you install the spoiler. Don't forget to use a small center punch to mark the holes before you drill so the drill bit doesn't walk. Only takes a light tap. Use some masking tape around the edges of the holes to be drilled in case the bit does walk. Take your time and go slow and you should have no problems.
The Following User Says Thank You to White64Goat For This Useful Post:
dawnst3ar (11-09-2012)
Old 11-09-2012, 11:03 AM   #3
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Subscribed. Great find for sure. Very interested to see how well the paint matches.
Old 11-09-2012, 11:23 AM   #4
BrewCity-FR-S
Drives: 2013 Raven FR-S
Why didn't you go with the FR-S spoiler available on the same site?
http://www.carid.com/2013-scion-fr-s...er-961530.html
BrewCity-FR-S is offline   Reply With Quote
Old 11-09-2012, 11:28 AM   #5
Wolfking
Wolfking's Avatar
Drives: Asphalt FRS
No need to be nervous...it's the same car! You'll be fine.
Wolfking is offline   Reply With Quote
Old 11-09-2012, 11:33 AM   #6
just86
just86's Avatar
Drives: 2013 genesis rspec
Actually is an 86 spoiler
just86 is offline   Reply With Quote
Old 11-09-2012, 02:27 PM   #7
dawnst3ar
They didn't have the correct paint code for my car in the Scion. When I talked with their rep, they are the same anyway.
Old 11-09-2012, 02:28 PM   #8
dawnst3ar
Huh, I'll be ordering a center punch today. Thanks for the tips!
Old 11-09-2012, 02:47 PM   #9
dawnst3ar
I know, it's just.....drilling holes in the trunk, ya know?
Old 11-09-2012, 05:02 PM   #10
dawnst3ar
So I just got an e-mai9l that the order is shipping. They apparently had one already painted, and it will be on it's way today. Talk about quick!
Old 11-10-2012, 08:50 AM   #11
Roberto12
Drives: scion fr-s argento
I have a BRZ type spoiler on my car, I had to drill and everything. Just make sure you have steady hands when drilling
Roberto12 is offline   Reply With Quote
Old 12-26-2012, 01:31 PM   #12
dtevin
Drives: white frs
First of all, thanks for posting this! I've been studying this for awhile as I'm installing mine.
how does it hold up in rainy conditions? does the weatherstripping tape prevent all water from leaking in? I'm installing mine right now and it's difficult to get all the weatherstripping tape to touch the trunk all around.
btw, it looks awesome! It really puts the finishing touch on the car.
dtevin is offline   Reply With Quote
Old 12-26-2012, 01:33 PM   #13
Jaylyons1
Jaylyons1's Avatar
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
There so many better looking wings. I am not a fan of the BRZ wing.
Jaylyons1 is offline   Reply With Quote
Old 12-26-2012, 02:47 PM   #14
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
I have the BRZ wing, and I'm BEGGING for someone to swap with. I just want a clean trunk.
-Acree
Acree is offline   Reply With Quote
The Following User Says Thank You to Acree For This Useful Post:
chenshuo (04-08-2013)
New rear spoiler choice: Carsmo rear spoiler Ray@Carsmo Cosmetic Modification (Interior/Exterior/Lighting) 46 08-10-2012 02:20 AM
86 Style DIG1992 Scion FR-S / Toyota 86 GT86 General Forum 3 08-06-2012 03:15 PM
Photo request: FR-S/BRZ with a GT style spoiler skoodge FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 06-05-2012 03:12 PM
Ugly Rear Spoiler - Spoiler Delete? iLuveKetchup BRZ First-Gen (2012+) — General Topics 31 02-01-2012 10:57 AM
