Old 11-01-2012, 10:26 AM   #1
MI FR-S
MI FR-S's Avatar
Drives: Ultramarine FR-S MT
Grabby Clutch?
Despite driving nothing but manual transmissions my whole life, this is my first rwd and first sporty car so I don't know whether this is normal or not:
When I test drove the car the shifting was a bit rough an jerky. Figured it was new car and me not being used to the clutch and it would smooth out after I'd owned it a bit.
Here I am, 2 weeks into ownership and I'm still having trouble smoothing out the shifts. Low speed and low rpm is manageable but anything over 2500 rpm is likely to be difficult.
When I start to bring the clutch pedal off the floor, there is nothing at first and then it will seem like about a 3rd of the total engagement happens almost at once. I then have to wait for a fraction of a second for everything to match speeds before bringing the pedal the rest of the way up (which is then smooth and prgressive)
At higher rpms there will be a noise (muted "thunk") from the rear (presumably the diff?) when the clutch grabs.
Any comments would be appreciated.
MI FR-S is offline   Reply With Quote
Old 11-01-2012, 10:57 AM   #2
mhigham
I think you are still getting used to it. The clutch is a pretty good one, so most of what you have learned from other cars is, lets say, off a little. I have driven nothing but manuals (save for a few cars) and they are all different. I almost couldn't drive this car well after getting out of a Focus manual.
The clunk is likely the LSD and maybe a bit of traction control. Nothing to worry about.
Mike
mhigham is offline   Reply With Quote
Old 11-01-2012, 11:54 AM   #3
MI FR-S
MI FR-S's Avatar
Mike
Not sure about that. I have had the LSD kick in and that was a different noise and feel.
Thanks for the input!
Old 11-01-2012, 12:01 PM   #4
xn7485
Drives: 1995 Acura Integra GS-R
IMO probably still getting used to it. Try adding a little gas as you let the clutch out.
Also, thread title reminded me of this thread: http://www.ft86club.com/forums/showthread.php?t=8040 where they adjusted the point where clutch grabbed. Instead of "nothing at first," it'll start engaging sooner. Might wanna check that out later.
xn7485 is offline   Reply With Quote
Old 11-01-2012, 12:09 PM   #5
gmookher
mileage?
gmookher is offline   Reply With Quote
Old 11-01-2012, 12:20 PM   #6
MI FR-S
MI FR-S's Avatar
Gah!
Should have mentioned in the OP that I did the pedal adjustment. Sorry.
And it did help becuase I'm no longer guessing where the Grab will happen
Reluctant to give it more gas because of all the slipping I'm feeling immediately after the first grab.
I sort of have two options right now:
Clutch really slowly and have a smooth shift but feel guilty about all the time being spent on the clutch.
Clutch quickly and have quick shift but it's jerky and feel guilty about all the shock the synchros are dealing with.
Edit: Mileage is 900 ish (first 300 were from the dealership bringing it up from Ohio if that makes a difference)
Old 11-01-2012, 01:19 PM   #7
gmookher
your grabby feel will change over the next 4000 miles
The Following User Says Thank You to gmookher For This Useful Post:
Bg8780 (11-01-2012)
Old 11-01-2012, 02:24 PM   #8
Bg8780
Bg8780's Avatar
Drives: '13 Black Subaru BRZ Limited
I've noticed this car doesn't hold the revs very long compared to other car I've driven. It feels like the car rather be shifted quickly.
Bg8780 is offline   Reply With Quote
Old 11-06-2012, 12:36 PM   #9
Brzce
Brzce's Avatar
Drives: WRBP BRZ Limited - Manual
Mine had the same thunk in the rear end. I had the dealership change the diff oil and it sounded / felt quite a bit better.
I forgot to ask - where in Michigan are you? Maybe would could drive each others' cars to see if they act the same. I'm in Ann Arbor if you are interested.
Airaid 511-307 Intake - installed 08sept12
Brzce is offline   Reply With Quote
Old 11-06-2012, 01:49 PM   #10
MI FR-S
MI FR-S's Avatar
The grabby clutch does seem to be getting better. Either that or I'm getting more accomplished at dealing with it.
I'll give the Diff a quick look this weekend when I'm doing the first oil change. See if there is anything obviously wrong.
There is a Michigan meet here: http://www.ft86club.com/forums/showthread.php?t=21304
Old 11-10-2012, 06:18 PM   #11
brbrz
Drives: 2013 BRZ Limited DGM
I also have noticed that the RPMs drop off quicker than other cars I have driven. I almost always undershoot the RPMs on the upshift. I also wish the throttle response was a bit better.
I attributed the clunck noise to play n the drive line but I don't know if that is normal. This is my first RWD that wasn't an old truck where everything shook, rattled and on most days rolled.
Sent from my Nexus 7 using Tapatalk 2
brbrz is offline   Reply With Quote
Old 11-23-2012, 06:47 PM   #12
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
I feel the exact same clunk, and also this is play in the drive train, I've had mine tho the dealer 3 times now for the issue, got fed up and I contacted Toyota Canada this week and they are now looking into it.
Thank good I'm not the only one that notices this!
Bu-Tang is offline   Reply With Quote
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
Clutch billysangi BRZ First-Gen (2012+) — General Topics 10 06-15-2012 02:29 PM
ATS carbon clutch collaboration model prototype clutch 86 & BRZ kanundrum Engine, Exhaust, Transmission 41 02-27-2012 03:48 PM
