Old 10-30-2012, 09:56 AM   #1
pr086
Drives: fast
how does the low CoG translate...
we all know the car has a very low center of gravity, but how does that translate into things you FEEL while driving? what are some specific characteristics of how the car drives that can be directly linked to it's low CoG?
pr086 is offline   Reply With Quote
Old 10-30-2012, 10:13 AM   #2
Synack
Boosted
Synack's Avatar
Drives: Sideways
You'll be sure to feel that deer you just ran over
The Following User Says Thank You to Synack For This Useful Post:
Books (10-30-2012)
Old 10-30-2012, 10:20 AM   #3
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
The car handles like a go kart, firmly planted (with nannys on).
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 10-30-2012, 10:26 AM   #4
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Less body roll, and all the good things that comes with it.
Rayme is offline   Reply With Quote
Old 10-30-2012, 10:27 AM   #5
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
The big benefit from a low CG is less body roll in the corners. Because the car naturally has less roll, it requires less roll stiffness from the suspension. This leads to a better ride and more grip over uneven surfaces (street grip).
To put it more simply, you get less lean and better handling without having a jarring and bouncy suspension.
There are other less tangible benefits also. The lower CG reduces the car's tendency to "whiplash" when making quick course changes, increasing stability and hence safety. It also helps keep the car controllable when the rear breaks away. Better innate handling means less agressive alignments so tires can last longer. And a lower CG can reduce pitch (nose up/down) so braking is improved. So there are a lot of little benefits as well. A lower CG is always a good thing, just like lower weight benefits everything as well.
The Following 2 Users Say Thank You to Draco-REX For This Useful Post:
SpeedR (10-30-2012), steeloyangster (10-30-2012)
Old 10-30-2012, 10:39 AM   #6
SpeedR
First86 / boat thief
Drives: MKIV Supra
What he said ^
SpeedR is offline   Reply With Quote
Old 10-30-2012, 11:52 AM   #7
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
Don't Think You Would Run Over The deer So Much As Under It...
Cade01 is offline   Reply With Quote
Old 10-30-2012, 12:05 PM   #8
Synack
Boosted
Synack's Avatar
Drives: Sideways
Scoop it if you're lowered
Old 10-30-2012, 12:05 PM   #9
DarkSunrise
DarkSunrise's Avatar
All the above is true. In addition, CG has a direct effect on lateral weight transfer (and therefore lateral grip).
WT = weight of car x acceleration x CG height / track.
In pretty much every racing sport, you'll see teams try to minimize CG for these reasons. For Formula 1 cars, for example, CG height is engineered to be as low as 10-11".
Old 10-30-2012, 01:14 PM   #10
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
Best way is to experience it... take a moderate turn in an SUV and then do the same in your FR-S. It is less pronounced when comparing with a sedan, but definitely able to tell.
Books is offline   Reply With Quote
Can somebody translate this video? madfast BRZ First-Gen (2012+) — General Topics 1 09-03-2011 06:48 PM
